08-11-2015, 04:15 PM | #265 |
BMW Fanatic
331
Rep 1,076
Anyone know if the gentleman function can be activated/ or has activated it on the F30? Apparently it's a F01 type of thing only.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
08-11-2015, 04:18 PM | #266 |
BMW Fanatic
331
Rep 1,076
Another thing. For coding the easy entry, EINAUSSTIEGSHILFE gives me these 2 options: "Modus_FA" & "Modus_BF" not "Modus_FA_SLV ". Tried the "Modus_FA" and nothing happened. I have EasyEntry options listed though. "EASY_ENTRY", "EASY_ENTRY_TTB" & "EASY_ENTRY_BEI_TUER_HINTEN_AUF". Anyone know if these will get it working?
Edit: EASY_ENTRY_BEI_TUER_HINTEN_AUF translates into EASY ENTRY FOR REAR DOOR OPEN. Given the car is an F32, I hope fellow F30 owners try this out, could be a cool feature.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 Last edited by 963mw; 08-11-2015 at 04:26 PM.. |
08-11-2015, 04:36 PM | #267 | |
Rep 1,481
Setting EINAUSSTIEGSHILFE to "Modus_FA" did not work for me either. It should be the same on your F32.
2015 Mineral Grey ///M4 6MT
08-11-2015, 04:52 PM | #268 | |
BMW Fanatic
331
Rep 1,076
08-11-2015, 04:59 PM | #269 |
Rep 1,481
It might depend on the firmware version of your ECU. My CAFD for the driver side seat is CAFD_00000B5_012_004_015. In any case, Modus_FA_SLV is Werte=03.
08-11-2015, 05:01 PM | #270 |
BMW Fanatic
331
Rep 1,076
Will try that out tomorrow, hopefully it'll work.
08-11-2015, 05:09 PM | #271 | |
Rep 640
2018 Audi RS7 4.0T
2006 BMW e46 330Ci Convertible ZHP 2010 Audi S5 4.2L [Sold] 2014 BMW 335i xDrive M-Sport [Sold] 2010 Audi A6 3.0T [Sold] |
08-11-2015, 08:04 PM | #272 |
Rep 98
I've got 3 problems.
1) HU_NBT 3000 VOLUME_POPUP_DISPLAY aktiv (Show volume level on screen when adjusting) I activated the volume. And it does not appear at all in idrive. The bar does not appear. It has something to activate the most? 2) HU_NBT 3003 CE_DEVICE_SPEECH_RECONGNITION aktiv (Activates Siri Eyes-Free Button (Hold down voice recognition button) I enable this option. But already "aktiv". I tried to turn and fails. The error "could not be activated vocal system" something like that, when hold down voice recognition button. 3) FEM_BODY 3060 BLINKZYKLEN_ANZAHL_TIPP werte = 04 werte (the triple blinker blinks to any amount.) That never seen. This option does not appear in the FEM_BODY. I can not change because it is invisible. The car is a 328 13/14. I do not know what I step. For I am helping a friend. Any suggestion?
08-14-2015, 06:45 PM | #273 | |
Rep 109
The production date of the car determines the firmware versions of its ECUs. Updating with higher I-level doesn't necessarily update all ECU's firmware. My car has the very recently updated firmware with the current I-level of F020-2015-07-502. But the firmware of its SM ECU is still old as it uses the same version of CAFD it used two years old. My question is -- Is it possible to flashing only one ECU (in this case SM) without changing others? Last edited by valley_nomad; 08-14-2015 at 07:11 PM.. |
08-14-2015, 07:02 PM | #274 |
Rep 1,481
I just did this without issues for KOMBI, which seems a more critical ECU than SM.
08-14-2015, 07:13 PM | #275 |
Rep 109
08-14-2015, 07:18 PM | #276 | |
Rep 1,481
All the details are here if you are interested: http://www.bimmerfest.com/forums/sho...7&postcount=55
08-15-2015, 12:45 AM | #277 | |
Rep 109
08-15-2015, 08:41 AM | #278 | |
Rep 1,481
If you do not have a charger, you can use another car's battery as an external power source and keep the motor running on that car.
08-16-2015, 08:53 PM | #279 | |
Rep 109
I just realized that I may need more tricks than simply flashing SM ECU as the new firmware that uses desired (or easy-entry codeable) CADF may not be available for flashing the car with its original production date regardless of its I-Level. I may have to change Zeitkriterium in FA. But how can I find the earliest production date from which the specific version of SM ECU CAFD is used by the firmware? Is there some existing documentation that describes the relationship among Zeitkriterium, I-level, cafd and swfl (and btld?)? |
08-16-2015, 09:14 PM | #280 | |
Rep 1,481
Others will know more about this, but since you are not modifying the options in your FA/VO, I do not think you need to change the Zeitkriterium: after all, the KOMBI software and CAFD I used for flashing my car are newer than the Zeitkriterium in my FA.
08-17-2015, 01:28 AM | #281 | |
Rep 109
Update: I found that SM ECU module part number was changed on 7/2013. So flashing my old ECU with new firmware is not possible ;-( In other words, the Easy Entry feature is not possible by flashing/coding for F30 produced before 7/2013 Last edited by valley_nomad; 09-02-2015 at 06:27 PM.. |
09-02-2015, 12:47 PM | #282 |
Rep 1,479
Drives: 2020 M340Xi (G20)
Halsifier,
Thanks to SquidlyBoy's post elsewhere on this forum, Easy Access now works on my 2014 F30: 2014 F30 328i m-sport (production date: 08/19/2013) - for me, I just changed these 3: FDL Coding: SM2 -> 3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = Modus_FA_SLV SM2 -> 3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 28 SM2-> 3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3C Note: this last value (EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS) could unintentionally disable this feature if your seat encroaches within this many mm from the rear end of the rail. Some suspect this is a safety thing to protect the knees of your passenger in the rear seat. By default this value is 0x64 (100mm). If this feature doesn't work, change this value to something smaller like i did - e.g. 0x3c (60mm) - it allows your seat to go back further and still keep this cool feature iDrive: - under Settings ->Doors/lock: "Last seat position automatic" box is checked New Behavior: Turn off the engine and open the door: Seat automatically slides back a few inches, allowing easy exit Turn on engine : Seat automatically slides forward a few inches, getting your seat into driver's position It works like a champ on my 2014 F30 328i as well!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
09-10-2015, 06:57 AM | #284 |
Rep 129
Confirmed that F34 Active Spoiler retraction speed can be coded.
HU_NBT -> 3100 -> V_ASP_IN Again this value needs to be converted to hex to work. The default is 46 hex which converts to 70 kmph. If you want it to be 88 kmph that would convert to a hex value of 58. |
09-11-2015, 04:00 PM | #285 | |
Rep 640
However, I do not recommend people to set "Last seat position automatic" to be enabled with this feature. Reason being because it would sometimes not return to driver stored position. For example, if you had the door opened and started the vehicle, then turned off the vehicle before the seat moved up to Driving Position, it will remember that Easy Entry Position as the new stored driving position. So when you get back in your vehicle, it will not move the seat forward until you push and hold the stored memory button, because you turned off the vehicle before the seat moved forward. So with "Last seat position automatic" disabled, it will always return to the Stored Position in the seat memory.
2018 Audi RS7 4.0T
09-11-2015, 04:01 PM | #286 | |
Rep 640
However, I do not recommend people to set "Last seat position automatic" to be enabled with this feature. Reason being because it would sometimes not return to driver stored position. For example, if you had the door opened and started the vehicle, then turned off the vehicle before the seat moved up to Driving Position, it will remember that Easy Entry Position as the new stored driving position. So when you get back in your vehicle, it will not move the seat forward until you push and hold the stored memory button, because you turned off the vehicle before the seat moved forward. So with "Last seat position automatic" disabled, it will always return to the Stored Position in the seat memory. Can you not already select music and call people on your HUD?
2018 Audi RS7 4.0T
