BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Dinan flash + dp's and other mods?
12-18-2007, 10:07 AM | #1 |
Perf BMW mag issue 147, 159
414
Rep 6,803
I wonder what would happen cause I doubt they have different flashes for other mods....
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
12-18-2007, 10:13 AM | #2 |
Rep 1,723
it will blow up.. your boost will spike to 23 psi
u didn't know? jk... that is another setback.. you will gain hp with the new mods, but not more like you should with a custom map/tune. I would think though, if this reflash gets huge.. lets say people dyno 275 stock and show gains on the dyno of like 340 whp or something obsurd, and many people get it.. then maybe they will reflash your ecu with your mods for like $300 or something for every reflash, or $500. |
12-18-2007, 10:20 AM | #4 |
Rep 4,484
Dinan will probably void your warranty too.
That's the problem with the Dinan flash. Getting it voids the BMW warranty and Dinan then covers it. But you add another significant mod (like DP's) and Dinan then too will void your warranty. Dinan could potentially void your warranty with an intake too. |
12-18-2007, 10:53 AM | #5 |
"posting from my recliner"
102
Rep 7,241
The Dinan Limited Warranty Specifically Excludes:
•return shipping charges, •towing charges, •rental car fees •damage to a component or assembly due to the installation of replacement parts with specifications that differ in any material respect from the original vehicle manufacturer’s or Dinan parts, •damage resulting from the unauthorized modification of a Dinan part or assembly, •damage resulting from the use of other manufacturer’s products in conjunction with Dinan products or systems, •damage to the clutch due to power shifting or abuse, •brake rotor warp, •friction materials, •maintenance services and parts when replaced during maintenance such as spark plugs, lubricants, fluids, engine tune-up parts, replacement of filters, coolant and refrigerant, •mechanical adjustments or repairs which result from normal wear and tear, •drive-belts, •light bulbs, •damage due to the failure to perform maintenance services at the specified intervals or in accordance with the instructions in the owner’s manual from the original vehicle manufacturer or Dinan’s product instructions, •damage attributable to negligence, improper installation, improper treatment or treatment contrary to the instructions in the owner’s manual from the original vehicle manufacturer or Dinan’s product instructions, •engine damage resulting from altered boost pressure, •damage resulting from the use of improper or contaminated fuel, •damage occurring through corrosion resulting from weak or improper coolant, •damage to a Dinan component as a result of a collision or improper collision damage repairs, •any vehicle operated in any competitive event, •custom-designed competition parts, •damages resulting from loss of time, inconvenience or loss of the use of the vehicle, •damage resulting from environmental influences, flood, accident, fire damage, or road salt corrosion, •re-manufactured or refurbished products or components (these products are clearly identified as re-furbished and are warranted for the period specified for that particular product
Ping Golf Club demo tech |
12-18-2007, 12:13 PM | #6 |
First Team
Rep 9
Could you run a Dinan and a SSTT?? Just take out the TT when you go in for service. Would you be able to feel the benefit of both of them??
2008 335 E93 Space Gray| Gray | Popular Gray| 6M | Premium | Sport | Nav | CA | CWP | Sirius | iPod| Delivery Jan 2008
12-18-2007, 12:17 PM | #7 |
Rep 56
Obviously, not the whole warranty. DINAN would step in for claims resulting from the ECU reflash only. BMW is still on the hook for all other work. More or less, they complement each other.
12-18-2007, 12:27 PM | #8 |
102
Rep 7,241
You can not add any performance parts to your engine unless they are from BMW or Dinan. It is the easiest way for Dinan to get out of a warranty issue.
Right from Dinan......"•damage resulting from the use of other manufacturer’s products in conjunction with Dinan products or systems"
12-18-2007, 12:35 PM | #9 |
184
Rep 1,702
Drives: Audi TTRS, 335is
Maybe Dinan will offer their own DPs for a reasonable (by Dinan's standards) price of $3999
12-18-2007, 12:42 PM | #10 | |
102
Rep 7,241
+installation
12-18-2007, 01:10 PM | #11 |
414
Rep 6,803
hahaha... the catted ones might run another grand or so..
12-18-2007, 01:21 PM | #12 |
Rep 18,218
NO! You wouldnt ever want to do this. Would result in too much boost.
12-18-2007, 03:13 PM | #14 |
Rep 4,484
Basically what it comes down to, if you spend extra for the Dinan flash and there powertrain warranty that they cover because BMW voids your powertrain warranty from the flash...you have to be happy with just that and get zero other performance mods, or Dinan will use that other mod as their excuse but legal excuse to NOT cover your car's powertrain warranty.
