BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > iDrive displaying wrong vehicle picture
      11-06-2014, 04:14 AM   #1
dazzle_rsa
Drives: F30 320i HU_Entry
Hi everyone
Hoping some guru out there can help me with this.
I did a retrofit from a HU_Entry to a HU_NBT, everything was successful.
The only nuance that is frustrating me is that all the pics of the car on the NBT (i,e. ECO pro and PDC) show an X5 when I am in a 3-series. Does anyone know how to change this to a 3 Series?
Thanks in advance.
      11-06-2014, 05:35 AM   #2
BeatB
Austria
Drives: BMW F30
I think if this is the case that your nbt is from another model, then maybe you should also code for example the ecu for pdc (REM)..
Another question from my side. I am also about to retrofit NBT coming from HU_Entry. Did all old cables (bluetooth, microphone, FM antenna, USB) fit without any problems in the new NBT unit, plug out and plug in without cuting the cables? I know only the issue about roating the USB connector for 90 to get USB working.
Thx
      11-06-2014, 05:57 AM   #3
dazzle_rsa
Thx
Hi
Thanks for the suggestion, will give it a try. Not sure what exactly to code thought.
To answer your question:
My old HU was without a Combox, and it was literally a plug and plug (except the USB). Was amazed at how easy it was. Completed it in around 25mins start to finish.
Then just added 609 to the VO and everything worked!
      11-06-2014, 07:01 AM   #4
BeatB
Austria
Drives: BMW F30
Thanks for the answer. I also dont have a combox .
Start ESYS -> Select expert mode -> click READ VO (FA) -> Read SVT, select for example the ECU: REM and click "code"
      11-06-2014, 08:24 AM   #5
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
483
Drives: 2016 M235i xDrive Cabriolet
Originally Posted by dazzle_rsa View Post
Hi
When you VO coded HU_NBT, it should pick up your vehicle model from your FA. Are you sure you VO coded the NBT? My first NBT was from an F31 wagon and as soon as I used my FA to VO code HU_NBT, it was a 3 series sedan.
      11-06-2014, 08:53 AM   #6
dazzle_rsa
Hi Aritaurus
I am pretty sure I have done it correctly. It wasnt picking up any of my ODO reading until I added 609 to my VO, now that is all working.
How would I know if it hasnt been done properly? Am I meant to add anything else?
      11-06-2014, 09:58 AM   #7
BeatB
Austria
Drives: BMW F30
After adding VO option 609, you are not done. Coding of the NBT is necessary. You did this step?
Sorry, but it sounds to me that you only added VO 609 and saved it.
      11-06-2014, 10:06 AM   #8
dazzle_rsa
Hi Beat
Not sure I understand what you mean by code the NBT ?
If you need go through various options on the cheat sheet, then yes I did that.
Would you mind explaining a bit more for me?
Thanks.
      11-06-2014, 11:42 AM   #9
vithy
Drives: 2016 F30 328xi
Did you use the FA from your car or use the FA from the Donor Car? If so thats why you see X5 picture on PDC and ECO menus.
I dont think you VO Coded it correctly. Are you using Emulator?
Hi Beat
Thanks.
      11-06-2014, 12:15 PM   #10
dazzle_rsa
Hi man
Yeah I read the FA from the car and edited that.
Not sure how else you would or could do it?
Don't have the emulator yet. It's still on its way.
      11-06-2014, 01:32 PM   #11
steve@codemybimmer
Hong Kong
483
Hi man
After you added 609 to the FA, did you right click HU_NBT and select Code?
      11-06-2014, 01:48 PM   #12
dazzle_rsa
NO I didn't. Was I meant to ?
      11-06-2014, 02:12 PM   #13
steve@codemybimmer
Hong Kong
483
Yes, you need to do that or else the settings on you FA will not propagate to the NBT.
      11-07-2014, 02:53 AM   #14
dazzle_rsa
Hi
Ok, I have right clicked on HU_NBT and sleceted CODE, but it is still the same ?
Any other ideas?
      11-07-2014, 04:00 AM   #15
BeatB
Austria
Drives: BMW F30
Select HU_NBT Folder -> then code on the right side as it is showing in this attachement
      11-07-2014, 04:02 AM   #16
dazzle_rsa
Thanks, Yup, that is what i did.
But I will go and try again, maybe I pressed something wrong.
thanks again.
Will feedback
      11-07-2014, 05:50 AM   #17
dazzle_rsa
thanks again.
Will feedback
ok so i did it again, it coded with the following info:
Caf's suchen
Tal wird generiert
Abarbeitung wird gestartet
TAL execution started.
MCDDiagService<id=84900, job=com.bmw.psdz.jobs.uds.MCD3_ReadFlashTimingPara meters, service=RDBI_FTP - ReadDataByIdentifier FlashTimingParameter, description=error: timeout, link=Physical request to ECU with address 0x63>
[] use default timing parameters as an exception occured
[] - [Exception - HU_NBT - 63] negative response error:
code: TIMEOUT P2/T2 occurred
description: P2 timeout on Service RDBI_FTP has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; ECU: HU_NBT_63_ETHERNET
severity: ERROR
ExecutionID=2014/11/07-13:44:22.380
[] prepareTALExecution started
[] prepareTALExecution finished
[] prepareVehicleForCoding started
[] prepareVehicleForCoding finished
MCDDiagService<id=46900, job=com.bmw.psdz.jobs.programming.zgw.MCD3_GetSVKf romECU, service=RDBI_SVK - ReadDataByIdentifier SVK, description=error: timeout, link=Physical request to ECU with address 0x63>
[HU_NBT - 63] There was an error during TAL execution, please check the log files.
[HU_NBT - 63] - [Exception - HU_NBT - 63] negative response error:
description: P2 timeout on Service RDBI_SVK has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; ECU: HU_NBT_63_ETHERNET
severity: ERROR
[] finalizeVehicleCoding started
[] finalizeVehicleCoding finished
[] finalizeTALExecution started
[] finalizeTALExecution finished
TAL execution finished
TAL-Execution finished with status: "FinishedWithError". [C207]
TAL execution finished. Duration: "14s". [C206]
Abarbeitung beendet
its not changed though
hmmmmm
      11-07-2014, 05:51 AM   #18
dazzle_rsa
also get this:
Transaktions-Report: Aktion: Codieren
HU_NBT [63]
cdDeploy NotExecutable
cafd_00000ded-003_009_015 NotExecutable
not sure what the issue is??
      11-07-2014, 07:00 AM   #19
BeatB
Austria
Drives: BMW F30
Is the cars build date correct?
      11-07-2014, 07:08 AM   #20
dazzle_rsa
Not sure. How do I check that?
      11-07-2014, 08:33 AM   #21
steve@codemybimmer
Hong Kong
483
Go back to your FA and there should be a folder called zeitkriterium. Make sure that it's set to 07/13.
I had the same problem with mine because it was using 03/12 which was a build date where NBT was not available at the time.
      11-07-2014, 08:46 AM   #22
dazzle_rsa
i find Zeitkriterium under Fa - FZAuftrag - Type and it says "1113"
i see date above it in another folder called Header which says 11/06/2014
not sure if i am looking in the right place (FA Editor) after reading and saving the VO. or if i should be changing anything?
