11-09-2014, 03:54 AM | #1 |
Rep 1,894
Europe NEXT 2015-1 Maps are now available
As the title suggests, the latest NBT maps are out. Upgraded to them last night, head over to the Nav/BT forum to find out how to generate your own FSC code.
11-09-2014, 04:10 PM | #4 |
Rep 1,502
Drives: M4 CP SSII/SS
I've had a search but only found a note to say the European maps are not yet available. Could you post a link please? Many thanks in advance.
Current: F82 CP SS/SS
11-09-2014, 04:58 PM | #5 |
Rep 1,894
The map is 100% avaliable, here is snapshot of mine:
This is where I got it from: http://www.e90post.com/forums/showthread.php?t=995629 |
11-10-2014, 04:02 AM | #7 | |
Rep 597
See this thread - http://f30.bimmerpost.com/forums/sho...d.php?t=949582 |
11-10-2014, 04:49 AM | #9 |
Rep 2,808
I have had a read through the above post, it relies on the fact you can get your .fsc file from your car using a ENET cable. There are other ways using software only but I read it and couldn't work out what is needed any tips would be appreciated.
Current: G26 i4 M Sport Pro, Tech Pk, Sunroof
Previous: 2016 440i MPPSK, 2014 330d Saloon F30, 2013 Audi S4 Avant, 2011 Mercedes C350 |
11-10-2014, 04:58 AM | #10 |
Rep 1,894
There are a number of ways to get your fsc code, but some of the methods didn't work for me. As per gr4z comment, you will need the ENET cable, esys software and PSDZdata (just get the lite version). Send a mail to Shawn in the coding forum for the software. You will not need a token unless your planning on FDL coding.
The beauty, is once you have you DE (for NBT) or 1B (for CIC) file, you just generate off that file against the new maps as they come. You will need to edit the XML file so the app knows about the new map source. If it helps I can put on mini guide on how to generate your FSC code for NBT (NEXT Maps) or CIC (Premium Maps)? |
11-10-2014, 05:12 AM | #11 | |
Rep 1,502
11-10-2014, 05:19 AM | #12 | |
Rep 1,502
ps and don't worry about dumbing it down... I'm pretty dumb
11-10-2014, 05:25 AM | #13 | |
Rep 2,808
11-10-2014, 05:39 AM | #15 | ||
Rep 1,894
11-10-2014, 08:19 AM | #16 | |
Rep 1,502
Then it seems I need a hex de-coder and an NBT.exe file plus some editing of text for the 2015-1 maps... Still quite a bit to do then
11-10-2014, 08:27 AM | #17 |
Rep 597
There is a tool out there that is a bit simpler - it downloads the 1DE file from your car and then you use another tool to generate the map.
See http://cartechnology.co.uk/showthrea...74410#pid74410 |
11-10-2014, 08:30 AM | #19 | |
Rep 2,808
11-10-2014, 09:07 AM | #21 | |
Rep 626
11-10-2014, 10:21 AM | #22 | |
Rep 597
</SgbmId> <SgbmId id="NAVD_000014B9_255_001_049" SWID_FscShort="00A90006" name="Road Map EUROPE Next 2015-1" supplier="NTQ" sop="01.03.2015" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> See the attached. |
