BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Rear suspension worryingly lower on one side
      12-14-2014, 09:25 AM   #1
dopper99
Drives: Golf R Mk8
Exclamation Rear suspension worryingly lower on one side
Just noticed today worryingly the rear drivers side seems much lower than the passenger side. I have ACS springs fitted.
No idea how long its been like that and only just noticed it. I've nothing in the boot and no-one sitting in the car to bias the weight to one side and the drive is quite level. I've not measured it, but it looks a good 10mm difference to me.
Current:
Golf R Mk8
Previous:
Golf R Mk7.5
Mercedes AMG C63 S Coupe
F80 M3 Competition Pack
      12-14-2014, 09:27 AM   #2
dopper99
Drives: Golf R Mk8
Below was took just after the ACS springs were fitted in exactly the same place on my drive. Looks like its dropped to me, above.
Current:
Golf R Mk8
Previous:
Golf R Mk7.5
      12-14-2014, 09:32 AM   #3
MWA
MWA's Avatar
Drives: AY M4
It does look lower.. by off chance could tyre pressure have a play in this? otherwise this reminds me off E46's with rear coils breaking...
Hope its nothing serious for you
      12-14-2014, 09:48 AM   #4
MarkG_M5Comp
Supreme Being
MarkG_M5Comp's Avatar
Drives: M5 Comp
Just whizzed outside and took picks of mine - SAME!
What have you done, now I'll start stressing.
That said, like me you have revered up the driveway - I always notice the car is uneven after reversing.
Don't stress mate.
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring
      12-14-2014, 10:17 AM   #5
dopper99
Drives: Golf R Mk8
Good point about the tyre pressures. Just checked and the the rears are virtually identical, about 0.2 PSI difference. I've just pumped all the tyres up again to the correct pressure and the car still looks like the pics above.
Current:
Golf R Mk8
Previous:
Golf R Mk7.5
      12-14-2014, 10:18 AM   #6
dopper99
Drives: Golf R Mk8
@MarkG335 how bizarre, yours seems the same!!!
Current:
Golf R Mk8
Previous:
Golf R Mk7.5
      12-14-2014, 10:26 AM   #7
F30AM
F30AM's Avatar
Drives: F30 330d M Sport sDrive
Oops!
Previous: Superman 330d sDrive M Sport + Toys
Present: Red Tornado Golf 7R 5 Dr, DSG + Toys
      12-14-2014, 10:27 AM   #8
jusdorange
YOLO
jusdorange's Avatar
Monaco
443
Drives: #mw
Is the ground level??
      12-14-2014, 10:30 AM   #9
F30AM
F30AM's Avatar
Faulty xDrive cars or faulty springs or both.
      12-14-2014, 10:30 AM   #10
Nick the Greek
France
2011
Drives: M135i. I don't do diesel.
Where's Lorcan when you need him?
Can't still be in the pub surely?
      12-14-2014, 10:31 AM   #11
Nick the Greek
France
2011
The first three words only would have done it F30AM.....
      12-14-2014, 10:40 AM   #12
F30AM
F30AM's Avatar
Now don't you think this requires an appreciate from you?
      12-14-2014, 10:42 AM   #13
Nick the Greek
France
2011
Done.
Trust it will be reciprocated.......
      12-14-2014, 10:42 AM   #14
moonshine
moonshine's Avatar
Scotland
853
Drives: 718 Boxster S
have you any steering lock on?
I noticed the rear suspension ride height seems to vary a lot from side to side depending if there is Left, no, or right lock applied on my drive with adaptive suspension.
      12-14-2014, 10:58 AM   #15
dicky.hillary
dicky.hillary's Avatar
Drives: G30 520D SE
I had that with my F31 on standard M-Sport Suspension. It can be caused by the fuel in the tank sitting more on one side, its a saddle tank. Apparently BMW allow 10mm difference from level when the tank is either full or empty.
      12-14-2014, 11:04 AM   #16
d4springer
d4springer's Avatar
Drives: F80 M3 CP SS/SO
Isn't the battery on that side as well? Maybe added to the weight of the steering column etc.. I think these cars are setup mainly for LHD so when the driver sits in the car it's perfectly level. Try moving it and see if it changes (maybe give it a clean whilst your at it )
Current - F80 M3 CP SS/SO | M Performance Extras
Prev - F30 330D M Sport | White | M Performance Kit | Various Extras
Prev - E92 330D M Sport | Black | Highline
Older - E46 330i | Silver | AC Schnitzer, E36 328i Coupe | White
      12-14-2014, 11:07 AM   #17
HighlandPete
Drives: BMW F11 535i Touring
You are parked on a slope, how flat is the drive? Really flat? Only takes the opposite front position of the drive to be down a few millimetres and the car will sit like that.
I see my drive as flat, but park in different positions and I see changes in ride heights around the car.
I'd suggest you try and get on a different piece of flat ground before you panic.
HighlandPete
      12-14-2014, 11:16 AM   #18
sweels
Drives: G20 M340i
I noticed this on my e39 several years ago (although that was perhaps just saggy due to 100k plus miles!) But I have also read on other forums that bmw set their cars up for LHD i.e. having just a driver on the left (which means it's even worse when just a driver is in our rhd models- and if they do this, given the cost of building for rhd anyway,surely do an rhd suspension setup?!)
Of course being an xdrive with no upgraded springs mine is about 3 feet high on both sides, so a 10mm difference hardly shows up!
      12-14-2014, 11:19 AM   #19
Lorcan
The artist formerly known as AC Schnitzer UK
Lorcan's Avatar
3541
Drives: The Yellow Peril
HighlandPete
+1. Don't panic. Check it out on a properly flat surface and let me know if you're still concerned.
      12-14-2014, 11:36 AM   #20
Nick the Greek
France
2011
Ha!
He's back from the pub!
      12-14-2014, 11:44 AM   #21
pdk42
Eh? Team member
pdk42's Avatar
Drives: F31 335i
HighlandPete
Absolutely. If the ground isn't prfectly level then any ride height observations will be misleading.
      12-14-2014, 11:45 AM   #22
Lorcan
Lorcan's Avatar
3541
ACS staff outing last night, followed by a route march up the Norfolk coast led by Wing Commander Rossiter this morning
