03-14-2015, 07:46 AM | #1 |
Rep 68
Drives: 2013 F30 328i
Active Sound Design (ASD) Retrofit progress
Featured on BIMMERPOST.com Hi guys Here are some videos of my retrofitted ASD in action. First half of first video, comfort mode, barely noticeable (the way I want it). 2nd half of first video, sport mode, more noticeable. Second video I messed around with F80 M4 settings. Way too aggressive and noticeable, especially on my aftermarket amp & speakers. What also sucks about the M4 setting is that the volume is constant on Eco-Pro,Comfort and Sport. Probably because M4 has different way of adjusting driving modes. Original post: Hi guys I thought I'd post of this thread to share my progress on retrofitting Active Sound Design to my 2013 328i MSport. To start off with I ordered the module. It has various part numbers, but apparently they are all the same: 65129352264*; 65129326555; 65129343317; 65129353021; 65129362445; 65129362445; 65 12 9 322 712 (03/12 -> ); 65 12 9 302 536 (03/12 -> 07/13).* I could not get a part number for the connector so I will be making up my own. Next up I got the pin assignments from ISTA Rheingold: Here is the inside of the connector: I then transposed all the pin assignments onto an image to make my life easier: I then continued to only connect power and the CAN signal. ISTA detects the new module ISTA before: ISTA after: E-SYS detects the new module: After this I flashed the ASD module. I used a modified FA where I changed the production code typekey to 3C17 to ensure it is a production code that included ASD. Here is the FDL edit view afterward: Next thing I must connect the feed from NBT head unit and output to the AMP. I first need to spend some time to make proper connectors so will update all you guys once I progress further. Very excited to see this retrofit work! Last edited by vitchie; 03-14-2015 at 07:56 AM.. |
03-14-2015, 08:49 PM | #3 |
Rep 3,089
Great thread. I love reading about DIYs like this. Looking forward to your progress.
03-15-2015, 08:42 PM | #6 |
Rep 103
Not really. It is about the car making the 'right' kind of noise. Back in the day they would work intake/exhaust, now they just play recorded sound through the car speakers. This is becoming commonplace even in 'high end' vehicles such as the M cars.
03-18-2015, 12:04 PM | #12 |
Rep 265
If the actual sound sucks, but the ASD component is faithfully recreating the actual engine sound based on engine parameters...I don't follow you....
03-18-2015, 12:21 PM | #14 |
Rep 68
03-18-2015, 12:23 PM | #15 |
Rep 68
I paid R3000 (Around $290) for the part, new from dealership. Then paid R100 ($10) from a scapyard for the connector. It's nearly impossible to get a ASD connector. In the end I got a HiFi amp connector (From E92, even amp connector from E46 will work). You just have to trim off some of the guides on the outside of the connector.
03-18-2015, 12:24 PM | #16 |
Rep 68
Just a quick update. The module is connected and it is working. I must say it is quite a bit lounder than I expected. Might be because I am running aftermarket amp & speakers. Will first try and change selected engine and turning amp gain down a bit to balance it out.
All in all, this mod was a lot easier than I anticipated. |
03-18-2015, 12:40 PM | #17 | |
Rep 962
03-18-2015, 12:46 PM | #18 | |
Rep 1,035
03-18-2015, 01:03 PM | #19 |
Rep 265
03-18-2015, 01:04 PM | #20 |
Rep 265
I had been reading about how other car makers like Ford (with the Mustang) solved this problem, and while I didn't get into the specifics, they basically funnel noise into the car past the sound barriers vs using the BMW strategy of simulating the noise.
03-18-2015, 01:33 PM | #21 |
Rep 68
03-18-2015, 03:46 PM | #22 |
Rep 68
Hi guys
Here are some videos of my retrofitted ASD in action. First half of first video, comfort mode, barely noticeable (the way I want it). 2nd half of first video, sport mode, more noticeable. Second video I messed around with F80 M4 settings. Way too aggressive and noticeable, especially on my aftermarket amp & speakers. What also sucks about the M4 setting is that the volume is constant on Eco-Pro,Comfort and Sport. Probably because M4 has different way of adjusting driving modes. |
