03-30-2021, 08:00 PM | #375 |
Rep 4
I just wanted to report that I had success with my F82 M4 thanks to this thread!
I am in Canada, so no TPMS enabled from factory, just FTM. I have the MK100 DSC/ABS module, so theoretically, all I had to do was add 2VB to FA and code my modules. In the end, I got this to work, but here were some of my stumbles: I did end up VO coding, FEM, ICM, DSC, HU_NBT and KOMBI modules, although I suppose you could also FDL code these and it should work as well. Initially, after I coded and tested by driving and doing a TPMS reset, it wouldnt go past 0% and error out. This is because I was following the PDF instructions (in reverse, since instructions were how to disable TPMS and go to FTM) from someone that posted up on this forum - however their instructions did not include coding for FEM module. After coding FEM, progress on TPMS reset went to 49% and failed... For sensors, I used the Autel MX sensors. It turns out that two of my sensors were not programmed correctly (were programmed as HUF, while the other two were non HUF). Once the sensors were all programmed to non HUF and taking for a drive, progress went past 49, and I now have temp and PSI on my display! Thanks for everyone who posted information on this forum about this. If I can help in any way, please let me know. |
04-05-2021, 01:48 PM | #376 |
Rep 1
I have succesfuly retrofited my F25 2011 with TPMS module 6871056 and wheel pressure sensors 6856227.
Added 2VB to FA, and coded the following: BKOMBI: ST_TYR_RDC_TMEOUT - aktiv ST_TYR_RDC_ALIVE - aktiv HU_CHAMP: RDC - aktiv RPA - nicht_aktiv RDC_SAFETY - aktiv ICM: IcmKod_B_S2VBA - verbaud I wasn't able to code RDC module as I was getting the error "Failed to get CAFs for SWE" but it turned out there is no need to code it, finaly. Last edited by alxlg; 04-05-2021 at 01:59 PM.. |
04-15-2021, 02:52 AM | #377 | |
Rep 21
Hello, I have an identical problem as described by HARJ. I see you were able to help him, can you please explain to me how to solve the same problem with RDC? Thank you in advance |
04-15-2021, 03:32 AM | #378 | |
Rep 2,302
It doesn't matter from which BMW the VO is or which equipment ((except 2VB must be available). I was even able to assign the CAFD when I only loaded the sample VO that was created during the E-Sys installation (FaListSample.xml to be found under C: / Data / FA). If it works you have to assign the CAFD, but may not code. You then have to load the Original VO (CAFD is still there) and code the RDC ecu. |
starmanbl6.00 |
04-15-2021, 04:00 AM | #379 | |
Rep 21
Thank you so much, I will try that, I have also some FA, need to try one with 2VB... Edit: Thank you once again, that did the trick Last edited by starmanbl; 04-15-2021 at 04:37 AM.. |
atzebmw588.00 |
04-15-2021, 09:45 AM | #380 |
Rep 3
Hello everyone
Do not attach the TPMS sensor to the tire Is it possible to put it in 4 places in the car and check if it works? And does the sensor work if it is not attached to the tire? |
04-15-2021, 12:06 PM | #381 | |
Rep 2,302
They need overpressure min. 1 bar and the rotation. |
04-21-2021, 01:17 AM | #383 |
Rep 2,302
04-21-2021, 02:50 AM | #385 |
Rep 2,302
06-28-2021, 11:02 PM | #386 | |
Rep 11
As you said for the early 2014 vehicle the Remote Control Receiver does not work with TPMS for MK100 DSC, I found the part number for Remote Control Receiver indeed changed after 2014.03, so for these vehicles is it possible to upgrade Remote Control Receiver to later one without upgrade Key, FEM and so on? Because as your post, it seems necessary to replace all of them to work with new Remote Control Receiver? Thanks. |
06-29-2021, 04:14 AM | #387 | |
Rep 4
07-03-2021, 04:05 AM | #388 | |
Rep 464
Instead, retrofitted an RDC module (i.e. the separate module that attached to the fuel tank strap) to enable RDC functionality.
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
07-04-2021, 10:14 AM | #389 | |
Rep 4
atzebmw, how did you get inject a CAFD file into the RDC ecu having the FA and SVT files? I presume it is a problem related to the version of the psdzdata Thanks for your help |
07-04-2021, 01:06 PM | #390 | |
Rep 2,302
Or you can load a VO/FA from the sample list which is installed by E-Sys. Then you can inject a CAFD. But then you may not code the RDC ecu. You have to leave the program open, load your original VO/FA and then you can code the RDC ecu. |
AlvaroSH1.50 |
07-05-2021, 08:10 AM | #391 | |
Rep 4
When I load the FaListsSample.xlm I get 20 options. Which one should I activate? I can't find a specific option for an F10 searching in the field "entwicklungsbaureihe". I only see from F001 to F007. Or can I choose any option? Now, choosing any of them, several options appear when doing detect caf for swe . But I am not sure if I can do it whith any of this 20 options Thanks |
07-05-2021, 09:22 AM | #392 | |
Rep 2,302
For the best it should be a FA from an F10, but it‘s not that important. When the „detect CAF for SWE“ works choose one CAFD you like or the CAFD with the highest numbers or the bottom one. But think of not to code the ecu now! First load your FA and then code the ecu. Or maybe i can send you an FA from an F10 today in the evening. |
AlvaroSH1.50 |
07-05-2021, 03:15 PM | #393 |
Rep 4
Hi,
TPMS working with no errors. Thanks so much atzebmw. I used FaListsSample.xlm to inject CAFD. The only problem has been that it did not reset correctly from the idrive. I reset, pressure and temp show correctly, turn off the car and when turning it back on, the pressure failure error would appear and it had to be reset again. So I disconnected the battery for a while and problem solved. 36106876227 control unit and 36106856227 sensors working with no issues on a 2012 F30. Thanks again atzebmw |
atzebmw588.00 |
07-06-2021, 03:58 AM | #394 | |
Rep 11
So for those vehicle before 2014.03 retrofit 315 key to 433 is too expensive and complex, the best way is using RDC control unit. Thanks for your reply. |
07-06-2021, 11:11 AM | #395 |
Rep 9
Guys, I have an Alpina D3 2014 and would like to retrofit TPMS. It is NBT but I'm not sure on the wiring side how I go about the connection. Does anyone have pics of the wiring they have created?
07-08-2021, 04:57 AM | #396 | |
Rep 14
Hi Mate! I have the exactly same issue. Sometimes stuck on 0% sometimes on 49%. I’m using china sensors. How did u change the sensor to HUF? Can you explain? Thanks in advance! |
