BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 328i removing MAP/TMAP sensors
      05-09-2015, 11:18 AM   #1
mobproctor
Drives: 2014 328i
Any tips on how to remove these sensors? They are on super tight.
      05-09-2015, 03:06 PM   #2
Heel328
Heel328's Avatar
78
Drives: 2013 328i 6MT
Don't have my car - how are they attached .. or do you have a picture?
2013 328i 6MT
1995 S6*
1993 S4*
1984 944*
1988 16V GTI*
      05-09-2015, 04:04 PM   #3
Brenanj1
Drives: 2015 F30 320i
Flat head driver to lift up tabs... Also pull the grey locking pin out a click.
      05-11-2015, 11:33 AM   #4
Thumper333
Thumper333's Avatar
Drives: 2018 M240i X-Drive
Asked the same thing
http://f30.bimmerpost.com/forums/sho....php?t=1122719
If that's the connector you are talking about, yes, the general consensus was to slide a flat head in from the rear.
Have not had a chance to do it yet as the car goes into the dealer Tuesday to try to get the Dinan Shockware installed (they stated they can not confirm it will work on a diesel as they never tested it, but see no reason why it wouldn't. LOL)
You just pull that little gray clip out until it clicks, like 1/4" then slip the flathead in to depress the latch, hopefully.
I should be installing my piggyback Wed after work, can report back then.
2018 M240i X-Drive | Sunset Orange Met
2015 328d X-Drive Touring M-Sport (Traded)
2015 Audi S4 Sepang Blue P+ | DSG | Tech Package | Adaptive Suspension | B&O
2015 Audi S3 Misano Red | 19" Sport pack w/Mag Ride | B&O
1983 Porsche 944 All stock
      05-13-2015, 09:22 AM   #5
Thumper333
Thumper333's Avatar
Just did it last night.
Pull out the gray clip on top, it moves about 1/4" and clicks. Then slide a thin flathead into the lower section of the slot on the rear upper (right side of picture). There is flap you have to gently press UP to release the catch. It took me a few tries, in the end I got it by pushing the connector in (back towards the firewall) and then pulled it off. Like the catch has a little hook.
      05-14-2015, 01:13 AM   #6
ramparts
ramparts's Avatar
1222
Drives: M40i
Do you need to remove this to change the tyres ?
      05-16-2015, 10:16 AM   #7
seahawk892
Drives: BMW 320i xDrive
Different connectors
I'm trying to unclip my connectors as well, and they appear to be different. Has anyone seen these?
      05-18-2015, 02:44 PM   #8
Heel328
Heel328's Avatar
78
That looks similar. Make sure the tab/lock is pulled out, then slide a small flathead screwdriver under the other side to help release it.
2013 328i 6MT
1995 S6*
1993 S4*
1984 944*
1988 16V GTI*
      05-19-2015, 02:04 AM   #9
seahawk892
Tab/lock?
Thanks for responding.
Where is the tab/lock? I see a grey tab on the AFE instructions and in the picture another user captured above, but not on my setup.
      05-19-2015, 12:55 PM   #10
Thumper333
Thumper333's Avatar
You're tab is black where mine is grey. It is on the top center of your clip, it slides in and out like a slide whistle. Pull it out 1/4" it will click, then slide the screwdriver in under the flap and press up, then push/pull the housing smoothly out.
      05-19-2015, 12:59 PM   #11
Bahn360Photo
Fitness Gene
Bahn360Photo's Avatar
Drives: 2018 M4
2006 bmw m5  [10.00]
2016 bmw z4 35is  [8.33]
2000 bmw m5  [10.00]
2018 BMW M4  [10.00]
1987 BMW 325 Conver ...  [10.00]
+1 or i found it useful using an angled needlepoint tool
Effective 11 Min Home Workouts?????
No equipment?????
20 years of experience
Spartan Race winner
PROtrainer!
Click the link??
https://www.youtube.com/c/FitnessGene
      05-19-2015, 01:04 PM   #12
Thumper333
Thumper333's Avatar
Here, circled it for you.
      11-20-2024, 10:03 AM   #13
bmwmvpstyle
Drives: 2021 X3 M40i
Thumper333 Your advice helped, was able to do this in my M40i. thanks! It was a pain before I used a flathead tool
