05-27-2015, 08:18 PM | #1 |
Rep 176
Shell V-Power® NiTRO+ Premium Gasoline
I don't have a link to the info, but received an email about this new Shell fuel. I use Shell only where I live due to good price and I consider it a good gasoline. This grade looks good. Wonder what the price premium will be.
05-27-2015, 09:47 PM | #3 |
Rep 234
Looking at the spec sheet it appears to just be another set of detergents and solvents added, no more power, no nitro. But with direct injection I guess every bit of cleaning you can get is good.
05-27-2015, 11:00 PM | #6 |
Go Spurs Go
3882
Rep 2,872
05-27-2015, 11:04 PM | #7 |
Rep 215
Drives: 2015 BMW M4 - 6MT Triple Black
I have a family friend that owns and operates 100s of gas stations and said its all the same. He even puts regular in his Ferrari and Porsche etc saying even the octane thing is a gimmick since it's only a difference of a percent point or two.
05-27-2015, 11:11 PM | #8 |
Rep 11
05-27-2015, 11:26 PM | #9 |
Rep 224
05-28-2015, 04:18 AM | #10 |
Rep 435
Drives: 2017 BMW M4CP SO
It has higher octane rating, at least in UK. I use it because it's one of few fuels available that match BMW's recommended octane rating.
05-28-2015, 06:39 AM | #11 |
Rep 95
Thats BS, your engine will knock with lower octane. Try it. High compression engines do not run well on regular. And if this idiot drives a ferrari, he can afford $5 per fill up.
05-28-2015, 06:56 AM | #12 |
Rep 412
Most modern cars can retard the timing (at the expense of power) to run on lower octane. But nothing says "I bought my car exclusively as a status symbol" like running 87 in a 6 figure car, though! Probably buys the cheapest tires that fit his wheels, too.
05-28-2015, 07:58 AM | #14 | |
Rep 868
2022 BSM G80 Comp X-drive |
05-28-2015, 08:46 AM | #15 |
Rep 1,208
It's not really a gimmick. Of course the names that companies give their gasolines are sometimes a bit 'hyped-up', but most marketing is that way in any industry.
I'm a consultant in the energy and natural resources industry and I have worked in both upstream and downstream (refining) ends and I can attest to when new technologies are developed to refine the oil/gas, of course they want to let the consumer know. |
05-28-2015, 11:47 AM | #17 |
Rep 482
If gasoline retailers were honest, they would say "Gasoline additive package update 2015-May-v2" or something like that.. and you cant Trademark it, put it on signage and build ad campaigns around it. So we get all these stupid names. "MAXTRON QUADRO NITROTECH ALPHA --- THE ULTIMATE POWER OF INERT GAS ADDED TO A COMMODITY PRODUCT"
But yeah octane matters. I also would not be surpriseed that any given gas station sells lower octane, or dilluted solution to be a lower octane without anyone noticing on occasion. |
05-28-2015, 12:27 PM | #18 |
Rep 2,995
Lot of misleading info flying around here. A few notes:
1. Top tier gas vs. Lower detergent gas makes no difference on valve deposit build up in direct injection cars because the problem is that no gas vapor hits the backside of the valves (or not enough at least). 2. Detergents are mainly interested in maintaining high performing injectors so that combustion remains efficient. However, injector performance is much more a function of design, build quality, fuel filtration, and other elements than about fuel quality. This is why some cars can run 300,000 miles on original injectors without a problem while others develop poor injection by 100,000 miles. 3. Low quality gas is not a big deal because there are reasonable, minimum quality standards in place for all gas. If you are paranoid, run an additive every 3,000-5,000 miles - however, know that that is against manufacturer recommendations in most cases. 4. Cars can adjust to different octane levels to a very modest degree. However, they can't infinitely adjust. Maintaining a good octane is important, even in today's vehicles. Conversely, you can't run e50 in a stock car (which will have a much higher octane) and expect a good result. |
05-28-2015, 10:21 PM | #19 |
Rep 215
Well then why does the east coast where my brother live exclusively sell 93 octane as premium and the west coast where I live exclusively sell 91 octane as the premium? If it really made a difference then it would be consistent across the U.S.
05-28-2015, 10:30 PM | #20 |
Rep 524
Emission laws. That is some very poor logic.
05-29-2015, 09:42 AM | #21 |
Rep 215
exactly, a couple points has zero impact on modern cars and is strictly marketing. But then again what does my buddy know, he only owns a few hundred gas stations? And what do you do for a living??? The way you talk you are definitely a yes man working for someone, not an entrepreneur
06-02-2015, 01:03 PM | #22 | |
Rep 163
Slap your buddy across the head for putting low octane fuel in his Ferrari and stay far away from his gas stations. An independent owner that thinks along those lines, is most probably cheating his customers by ordering only the lowest octane gas and selling it off as the higher. Last edited by MCanadaE46; 06-02-2015 at 01:17 PM.. |
