BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > B58 (340i) Engine Technical Drawings and Details
      06-01-2015, 05:23 PM   #1
E90Fleet
South Africa
1235
Arrow B58 (340i) Engine Technical Drawings and Details
BIMMERPOST
     Featured on BIMMERPOST.com
Diagrams on B58 engine. Also see more info on the BMW 340i model @ http://f30.bimmerpost.com/forums/sho....php?t=1124143
Pictured:
Turbo
Oil Pan
Oil Filter
Charge Air cooler
Cam cover
Engine cover
Coolant pump and heat management unit (note pump is mechanical, not electrical)
Compared to N55:
New cylinder head design (better cleaning so less carbon buildup on valve stems)
New charge air cooler (Intercooler)
New type of thermostat
Dedicate turbo electric coolant pump
Mechanical coolant pump (from electric)
Modified oil filters
Smaller, faster valvetronic
BMW if you are reading, I need a job, Please.
Appreciate 6
kern4173826.00
      06-01-2015, 05:40 PM   #2
E90Fleet
South Africa
1235
Turbo gets its own cooling pump (part no 4)
Regular coolant pump shown above is mechanical, not electrical like older engines
      06-01-2015, 05:45 PM   #3
greekcs
greekcs's Avatar
Drives: 2020 M340i xDrive
closed deck?
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD
2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive
      06-01-2015, 05:49 PM   #4
E90Fleet
South Africa
1235
Belt run
      06-01-2015, 05:51 PM   #5
E90Fleet
South Africa
1235
Cylinder Head with new smaller and relocated valvetronic actuator (9)
      06-01-2015, 05:56 PM   #6
smithf80
smithf80's Avatar
Drives: '18 F80 M3 6MT
2018 F80 M3  [5.00]
So what are the big differences here from the N55.
I like that is a mechanical pump, one less electronic thing to fail (as water pumps in general are known to fail on BMW)
      06-01-2015, 06:08 PM   #7
E90Fleet
South Africa
1235
Everything
Appreciate 8
      06-01-2015, 06:11 PM   #8
Eddien123
Drives: F30 335 6MT
Everything
Wow this seems like a motor that can take some abuse. I've never heard of a turbo having its own designated cooling system.
      06-01-2015, 06:29 PM   #9
E90Fleet
South Africa
1235
The BMW V8 and V12 engines have dedicated turbo electric coolant pumps
Same on I8 engine (B38)
      06-01-2015, 06:43 PM   #10
Golden Arrow
Golden Arrow's Avatar
Drives: F36 430i GC
Everything
+1
You answered my question before I could ask it.
I'm glad BMW has made a change to hopefully address the carbon buildup issues. I've seen some really gunked up valves.
2017 430i GC
2013 335i
2004 330ci
2003 330xi (Forever in my heart )
      06-01-2015, 06:45 PM   #11
Eddien123
Drives: F30 335 6MT
The BMW V8 and V10 engines have dedicated turbo electric coolant pumps
What BMW V10 engine is turbod?
      06-01-2015, 06:51 PM   #12
E90Fleet
South Africa
1235
Sorry, typo, meant N74 V12
      06-01-2015, 07:29 PM   #13
Daftasabrush
Fool
Daftasabrush's Avatar
England
1796
Drives: F31 340i
Is the orientation reversed? If so, how does one replace a timing chain and ancillaries?
      06-01-2015, 07:36 PM   #14
E90Fleet
South Africa
1235
Yes, the VANOS, upper and lower timing chains and oil pump chain are now on the rear of the engine.
Probably an engine out procedure to change now.
      06-01-2015, 07:49 PM   #15
drexplode
drexplode's Avatar
Drives: G82 M4C PB
any pictures of the fuel system?
      06-01-2015, 07:57 PM   #16
E90Fleet
South Africa
1235
Injectors plug directly into metal fuel rails.
No more connecting metal hoses
3 Injectors per rail
      06-01-2015, 09:13 PM   #17
MikeTerp
Drives: 2016 F30/340
Thanks. Very interesting!
      06-01-2015, 10:59 PM   #18
scrape1
Drives: '14 228i M Sport, '04 X3 3.0i
Oh, wonderful. Having the timing chain in a place that requires pulling the engine to replace worked out well with the N47
This might be a deal breaker for me is I want a car I can keep for a long time.
      06-02-2015, 01:35 AM   #19
Eddien123
Drives: F30 335 6MT
Oh ok. Thanks I didn't know that.
      06-02-2015, 09:36 AM   #20
Golden Arrow
Drives: F36 430i GC
It's interesting that BMW has gone to a mechanical, belt-driven turbo cooler at a time when drag on the engine is taken so seriously because of fuel economy standards.
2017 430i GC
2013 335i
2004 330ci
      06-02-2015, 10:33 AM   #21
Weaselboy
Weaselboy's Avatar
Drives: 2021 540i
Thanks for posting this E90Fleet. Interesting info.
That new oil filter looks abut twice the size of the current version.
      06-02-2015, 11:01 AM   #22
S4NoMore
S4NoMore's Avatar
2011 BMW 335i  [0.00]
2016 BMW 340i  [0.00]
2015 BMW X3  [0.00]
1991 BMW 318i  [4.33]
I was going to say that new filter looks small, maybe half the size. I think it's thinner. It also looks to be in a very tight spot, changing that should be... interesting.
I don't see the charge air cooler, did OP mean to say intake manifold?
The mechanical water pump appears to have an actuator, I have to believe BMW wants/needs to retain the on-demand nature of the flow for efficiency.
Copyright ©2000 - 2022, vBulletin Solutions Inc.
