BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > ER F30 N55 Charge Pipe Install - Install Guide and Suggestions!
      07-20-2015, 04:48 PM   #1
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
I was asked to start a new thread for the ER F30 Charge Pipe. I am attaching the official install guide, and anybody who wishes to post any tips or tricks or advice please feel free...
Mike
      07-20-2015, 06:32 PM   #2
ocN55
ocN55's Avatar
Drives: '15 M235i 6MT/ '16 M3
Has anyone ever triggered a light or code with a ER CP or FMIC?
      07-20-2015, 08:31 PM   #3
Mike@N54Tuning.com
I have not heard of any and we've probably sold 1000+ units over the N54/N55 platform.
Only time a code pops up with an FMIC or CP install is if the couplers are not tightened down, usually with FMICs on the cold side and it just pops off triggering a boost under code. Beyond that nothing I have seen.
Mike
      07-21-2015, 11:48 AM   #4
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
If installed correctly, it will not trigger any lights. Are you getting any codes after installation of the CP and / or FMIC?
Start/Stop Buttons $19.95 *** M3/M4 Tips $199 *** Carbon Fiber Mirror Caps $139 *** Carbon Fiber Engine Cover $350
Phone 725-221-5267 || website www.x-ph.com
      07-23-2015, 08:25 AM   #5
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Have both, and neither have triggered anything.
SOLD: 2012 335i Mineral Gray
      07-24-2015, 02:34 AM   #6
Jera_Jakerz
Jera_Jakerz's Avatar
Drives: 2014 BMW 335i xDrive
If you don't tighten the clamps enough it can through some boost leak codes.
JB4 Stage 2 | aFe Magnum FORCE Intake System DRY | ER Chargepipe | ER CATLESS Downpipe | ATM Intercooler | BMS 2.3 Gal Meth Inj kit | Bilstein B14 | OEM Slotted/Dimpeled front rotors | Cool Carbon brakes | Go Fast Bit DV+ | Pure Stage 2 Turbo | Pure inlet
      07-24-2015, 10:07 AM   #7
samhatti
Drives: bmw 435i M-Sport
The biggest painin the ass will be disconnecting the factory charge pipe from the intercooler. What I did was take a tiny scredriver and pop it under the connection then with both hands push and wiggle the tabs towards the front of the car. Once its off. I would pull the charge pripe through the the tiny hole. its not hard once youve done it once.
PS no beed to disconnect the other side of the intercooler.
      07-24-2015, 11:46 AM   #8
Mike@N54Tuning.com
Thanks for the suggestions!
Mike
      07-26-2015, 12:40 AM   #9
ocN55
ocN55's Avatar
Mike could you also post a guide dedicated to the ER FMIC?
FBO M235i r
F80 M3
      07-26-2015, 03:51 PM   #10
Mike@N54Tuning.com
Sure.. Will post it up.
Mike
      04-30-2016, 06:39 AM   #11
Alano_Mpower
Drives: Bmw 435i
Mike
were is the pdf?
      05-19-2016, 12:21 PM   #12
Boostin335
Drives: sl600 z06 supra sti 996tt m3
Hey Mike - with just a Jb4 no other mods on 93 octane is a CP needed, or only if you are going downpipes, tracking the car, E85 etc
      05-19-2016, 12:31 PM   #13
mike@x-ph.com
It is always recommended to upgrade the CP when tuning the car but from my experience with our customers it is only mandatory if you are running map 2 or higher boost
      05-19-2016, 06:25 PM   #14
Mike@N54Tuning.com
These fail stock, so I usually tell customers once you tune a charge pipe should be on the list for future mods. Do you have to do it right away, probably not, but by raising boost you are putting more stress on component that has been show to be failure prone.
I would never call it a MANDATORY upgrade but one that is highly recommended.
Mike
      05-22-2016, 11:25 PM   #15
335_paul
335_paul's Avatar
51
Drives: 15 335/17 ZCP M3/17 Bentayga
quick question, In what direction must the MAP sensor on the ER chargepipe be installed, does it matter? facing down like stock?
thanks!
| 2015 BSM M Sport 335i | 2017 Mineral Grey ZCP/fully loaded M3 | 2017 Orange Flame Bentley Bentayga |
Follow me on Instagram: @hsdvisuals
      05-23-2016, 01:58 AM   #16
Fast400
Fast400's Avatar
Drives: X4 M40i G02
2014 BMW  [0.00]
thanks!
That's the only way your plug will reach...
      05-23-2016, 02:00 AM   #17
Fast400
Fast400's Avatar
Drives: X4 M40i G02
2014 BMW  [0.00]
For the ix models, I found it easier to pull the original charge pipe from the top. You'll have to remove the black plastic cover on the driver side (one screw). Took me 5 minutes from the top vs 20min thru the bottom.
      05-23-2016, 08:02 AM   #18
335_paul
335_paul's Avatar
51
thanks!
So make it faced down like stock? Sorry I totally forgot about that small detail during install lol
      05-23-2016, 09:49 AM   #19
Fast400
Fast400's Avatar
Drives: X4 M40i G02
2014 BMW  [0.00]
Yes. Same direction you took it off
      05-23-2016, 11:01 AM   #20
335_paul
335_paul's Avatar
51
Ok thanks!
      05-24-2016, 12:31 PM   #21
shivaswrath
Drives: 2012 335i
Reuse your O-rings and gaskets!
      05-25-2016, 01:06 PM   #22
Mike@N54Tuning.com
+1
Mike
