07-30-2015, 09:07 AM | #1 |
Rep 5
Launch Control Coding
Just after a little help if possible, new to the coding.
I have tried to use Launch Control without sucess so assumed that LC wasnt activated. i have since gone into the setting and it appears to the active, am i looking in the right place. |
08-02-2015, 10:47 AM | #3 |
Rep 117
I'm having this same problem. I have coded LC, and I have the sport automatic transmission, but I still can't activate launch control.
My current I step is f020-15-07-502. Anyone ever successfully code launch control on a pre March build f30? |
08-03-2015, 11:41 AM | #5 |
Now in the dark side !
65
Rep 1,136
Just coded the LC=1, and it works.
Already had the Sport AT. Did you drive atleast a couple of miles before trying to use the LC ? Won't let you on a cold car.
Present: 2011 Porsche Carrera S Cab, white (Now on the dark side!)
BMW X3 M40i (wifey) Past:2012 335i Sport Black, 20" 356 wheels, M Sport Aero, MPE (Sold -kinda missed) 2010 X5 35d Black fully loaded (Sold) 2007 335i sedan Antracite (Sold and missed !) |
LittleSamurai4.50 |
08-03-2015, 02:40 PM | #6 |
Rep 5
08-03-2015, 02:40 PM | #7 |
Rep 117
08-04-2015, 12:03 PM | #8 |
65
Rep 1,136
June 13th 2012, so no pre-march here either.
08-04-2015, 09:44 PM | #9 |
Rep 117
So you didn't do anything else differently apart from coding lc aktiv?
I don't understand why mine isn't working. I'm following all the right steps to perform it. My car is up to temperature and after >10 miles. And I drive a march 2013 build f30 335i...... So if it's working on your 2012, it should work on mine. Argh! |
08-04-2015, 10:44 PM | #10 | |
Rep 640
Also, you need to have your vehicle be driven first for 6 miles (10 km) uninterrupted to get to optimal engine temperature. Then: 1. Place driving mode in Sport+ or turn off traction control. 2. Move transmission into Sport. (Should say S1 on your instrument cluster.) 3. Firmly and fully press the brake pedal and hold. 4. Floor the throttle past resistance point into kick down. (You should feel a little click on the pedal.) 5. Your instrument cluster should say "Launch Control Active" 6. Fully release the brake pedal and keep the throttle floor. 7. Enjoy. Those are the steps I tell everyone else and it seems to work for them. Hope this sorta helps...
2018 Audi RS7 4.0T
2006 BMW e46 330Ci Convertible ZHP 2010 Audi S5 4.2L [Sold] 2014 BMW 335i xDrive M-Sport [Sold] 2010 Audi A6 3.0T [Sold] |
LittleSamurai4.50 |
08-04-2015, 11:01 PM | #11 | |
Rep 117
Thank you. I appreciate the instructions. How do I flash the updated egs? Where do I get it from? My current I step is f020-15-07-502. Does that indicate what my current egs is? Also, do I run the risk of bricking my ecu? I'm not sure if this is coding is flashing the ecu. Apologize in advance for the noob questions... |
08-05-2015, 01:10 AM | #12 | |
Rep 640
2018 Audi RS7 4.0T
08-06-2015, 11:43 AM | #14 |
65
Rep 1,136
As Halsifer stated, I just coded the LC to aktiv in the EGS, and it did work.
And, as stated, I already had the Sport AT. Are you sure you have the sport AT ?
09-08-2015, 04:44 PM | #16 |
BooGooBird
17
Rep 79
09-08-2015, 04:46 PM | #17 | |
BooGooBird
17
Rep 79
Thanks!! |
09-09-2015, 02:26 PM | #18 |
Rep 640
Read through the How-to documents you received when you obtained the E-Sys software.
2018 Audi RS7 4.0T
10-22-2015, 11:33 AM | #20 |
Rep 29
Launch control RPM adjustment
So i was able to code in the LC to AKTIVE and it works on my 2013 F30 335i Sport line with the Sport Automatic Transmission.
My question is, can you adjust the RPM's like you can on the M models? I tried using the cruise control to adjust it but the RPMS sit at 2k and wont budge. I didnt know if there is another way to bump them up on a non M car. |
10-22-2015, 05:31 PM | #21 | |
Human
932
Rep 1,200
The M has a double-clutch auto, while ours is a normal slushbox. In ours, the engine speed while preparing for launch control is given (and limited) by the torque converter stall speed. The more torque you have, the higher the stall speed will be. On mine (diesel) for instance it's ~3K RPM...
2023 BMW M4 CP xDr | 510HP / 650Nm | Isle of Man Green | Photo album
Sold 2018 BMW M4 DCT / ZCP| 450HP / 550Nm | Sakhir Orange | Photo album | Tribute Sold 2014 BMW 435xd | 360HP / 710Nm | Estoril Blue | Photo album 2010 BMW Z4 sDrive35i DKG | 306 HP / 400Nm | Space Gray | Photo album |
