BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > F30/F32/F33 Classifieds (For Sale / Trade / Wanted) > Members Classifieds > Electronics: Audio / Video / Phone / Alarm / Navigation / Radar > Hi-FI AMP Harness
      08-29-2015, 12:15 PM   #1
CAF10
Drives: F10
Hi-FI AMP Harness
BIMMERPOST / Classifieds
Asking Price:
None
Item Interest
BMW HI-FI amp connector harness for upgrading to aftermarket amplifier. Please note this amp connector harness will only work with OEM 42-pin Hi-Fi AMP connector and will not work on vehicles equipped with Harmon Kardon (HK) sound system. It is designed for plug-n-play application without cutting or splicing factory wiring harness for installation of aftermarket amplifier(s). All wires are thin-walled automotive wire specification meeting or exceeding OEM wire size, 18 AWG for all signal and output wires and 12 AWG for subwoofer output wires. Signal wires are equipped with high quality gold plated metal male RCA connectors, not the cheap plastic one. All wires are crimped and soldered to ensure secure connection. Two different configurations are available for specific installation needs. The basic version comes with four channels signal output (FL, FR, RL, RR) and a remote wire. It is designed for those who just want the singal wires from the IDrive unit and run their own speaker wires for high power application. The deluxe configuration utilizes all existing OEM wirings for plug-n-play installation for full seven channels if desired, (Front left, Front Right, Center, Rear Left, Rear Right, Left Sub, and Right Sub). Both version can be configured with optional relay for multiple amps/dsp remote turn on application. All wires are labeled and come with connector pins assignment documentation. Please refer to ebay listing http://www.ebay.com/itm/161809291201 for ordering information.
      08-29-2015, 10:59 PM   #2
Marc417
Drives: Alpine White 328i MY14
CAF,
I'm new to audio and would like to upgrade my amp.
My question is - with this, I'll be able to buy any 8ch amp and use it?
- Marc C.
      08-30-2015, 01:13 AM   #3
CAF10
Drives: F10
Marc,
Yes, this is a slight improvement to the "Technic" harness that other members have been using to upgrade to aftermarket amp. That's a ton of info on this forum on amp upgrade. Most people used a six channel amp and skip the center channel all together. Please make sure the amp you purchase accept differential input as most modern amp can. You will need to add your own power and ground wire to complete the installation. I hope this help.
      06-04-2016, 12:22 PM   #4
CAF10
Drives: F10
Underseat subwoofer connector harness is now available.
Ebay item no. 162092370709
      07-02-2016, 08:06 PM   #5
graphitegt
Drives: 2013 550i xdrive GT
Happy Independence Day weekend!
Do you know if your harnesses fit the F07 based HiFi system?
      07-06-2016, 12:24 AM   #6
CAF10
Drives: F10
I believe so, F07/F11 shares the same equipment for hifi audio. You can verify if it has the same 42 pins connector at the amp.
      04-12-2017, 06:12 PM   #7
eruiz
Drives: 2008 M3 coupe - Alpine White /
Is this useful for E84?
I have a 2014 X1 with hi fi system, non i-drive, I m planning to add a JL audio XD600/6, does this harness work?
thanks
      04-12-2017, 06:12 PM   #8
eruiz
thanks
      10-13-2017, 07:03 AM   #9
twodoor
twodoor's Avatar
Drives: F30 2013 2.0d xdrive
Do you have the "deluxe" harness for 2 subs and 4+1 speakers? I couldn't find it on ebay and would like it shipped to Romania.
I have the stock HiFi and want to upgrade the amp:
