09-15-2015, 04:01 PM | #1 |
Rep 26
Disabling PDC and rear camera
Does anyone know if it's possible to completely disable the parking sensors and rearview camera in a 2013 F30? I know that I can hit the button to turn it off, but it comes back on the next time the car is shifted into reverse.
I'm hoping to find a way to do this so that my car can be used for a driving test (I know it's crazy, but bear with me) and the DMV requires that all cameras and sensors be disabled once the car is turned on. |
09-15-2015, 04:42 PM | #2 |
Rep 16,079
09-15-2015, 08:14 PM | #4 |
Rep 1,560
Can you just pull the fuse?
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
09-19-2015, 09:29 PM | #5 | |
Rep 26
09-20-2015, 09:51 AM | #7 |
Rep 4,446
Drives: '23 X1 28i xDrive
Who wants to go thru this hassle for 1 hour driving exam? There has to be a better way--most cars don't even have "coding" as an option, but 1000s of people take driving exams every year. OP--call the DMV and ask them what they typically do.
09-20-2015, 11:39 AM | #9 |
Rep 105
The camera is easy: piece of electrical tape over it. You can also just be hyper diligent about turning it off via the button when it turns on. With so many cars with this feature, I wouldn't worry too much. You could also drive someone else's less sophisticated car!
09-20-2015, 11:51 AM | #10 |
Rep 4,446
Can't you just hit the "Options" button and shut down the screen?
09-20-2015, 01:45 PM | #12 | |
Rep 26
09-20-2015, 01:46 PM | #13 | |
Rep 26
09-20-2015, 01:49 PM | #14 | |
Rep 26
It's easy to hide the visual aids by just using a paper to block the nav screen. It's only the incessant beeping of the sensors that's my last issue. |
09-20-2015, 04:51 PM | #15 | |
Rep 1,772
2. It would take me 5 minutes to code it out 3. Several responses more than 5 minutes of collective knowledge and no full solution. By the time you have read through all the responses and called the DMV I would have finished coding my car. 4. I don't see you suggesting anything "better" to do 5. And I presume we are talking about his F30, which can be coded. |
09-20-2015, 06:50 PM | #16 |
Rep 4,446
09-20-2015, 06:53 PM | #17 | |
Rep 4,446
09-20-2015, 07:06 PM | #18 | |
Rep 4,446
09-20-2015, 07:10 PM | #19 |
Rep 5,316
Drives: G80 M3 6MT
Just pull the fuse for the navigation, thats the easiest way.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
09-20-2015, 07:15 PM | #20 | ||
Rep 26
09-20-2015, 07:32 PM | #21 |
Rep 4,446
I agree 100%. But I've had 3 cars with back up cameras, and none of them can be disabled with the flip of a switch. In every one of them, you would have to select another function after you put the car in reverse. You are not the first one in this situation. So I have to believe that the rule is stricter than the practice. But there has to be some way to confirm this.
09-20-2015, 09:14 PM | #22 | |
Rep 26
camera, pdc, sensor |
