BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > [TUTORIAL]Retrofit rear lights BMW F30/F31/F80 LCI
Studio RSR
      09-17-2015, 02:26 PM   #1
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Here is a complete TUTO to mount new full LED taillights for BMW F30 /M3F80
For BMW F31 is the same, there is just the exterior lights that are different
Left outer side taillights (63217372209)
Outer side right taillights (63217372210)
bmw see if gutters are 2 to change
[BUY]
Here are the reference pictures and pieces to buy
Outside left side taillights (63217369117)
Right side outside rear lights (63217369118)
Left inner taillights (63217369119)
Inside right rear lights (63217369120)
Cache left gutter (51497410819)
Cache right channel (51497410820)
Case 2x socket interior lights (61136984758)
2x connector for indoor lights (61138364834)
And cables to power the internal fires right and left towards the box next to the battery
[REMOVAL]
Removing hinge filling:
Removing side trim battery:
Removing Tailgate trim and fires:
[CHANGE] Before making the changes you must unplug the battery +
Here the change to External lights on right and left
there is just a move son as indicated with the homing
Left light:
Black / white to No. 1
Black / yellow to No. 2
Brown to No. 3
Gray / purple to No. 4
Right light:
Black / Gray to No. 1
Black / blue to No. 2
Brown to No. 3
Gray / yellow to No. 4
this photo shows the original location plug as above
Now he'll have to take that leave 2 son of internal fires left and right side to the rear case REM located next to the battery
This manipulation was used to transplant on foreign flashing
Right socket box:
Son connect purple / gray location 1 to REM(A174)prise(A174*14B)black / gray location No. 12
Left socket box:
son connect the blue / red location 1 to REM (A174)prise(A174*12B) black / white location No. 17
Photo of the socket located on the rear casing
Here the change to the interior lights left and right with the new outlet box (61136984758)
2 connectors that will connect to the rear module, the other 8 are the original ones that must be removed from the old black jack (4-pin) to the new green connector (6 pin with 1 not used)
Left light:
connector and cable add
son blue / red slot No. 1 to the REM box (A174) taken (A174 * 12B) black / white location No. 17
connector has moved from the original black jack (4-pin) to the new green jack (6-pin)
black / purple to No. 6
Brown to No. 3
Yellow / black to No. 4
Green / yellow to No. 5
Right light:
son purple / gray location # 1 to the REM box (A174) taken (A174 * 14B) black / gray location No. 12
Green / red to No. 5
Brown to No. 3
Yellow / purple to No. 4
Black / blue to No. 6
[CODING]
The coding of new fires is not required, since there is no error on the idrive but against there will flicker flashing at each startup
If like me you do not want flickering lights here is the mod has to do with the E-sys software
Flashing Rear:
REM 3061 FRA_H_L_KALTUEBERWACHUNG /nicht_aktiv
REM 3061 FRA_H_L_WARMUEBERWACHUNG /nicht_aktiv
REM 3061 FRA_H_L_IS_LED /aktiv
REM 3061 FRA_H_R_KALTUEBERWACHUNG /nicht_aktiv
REM 3061 FRA_H_R_WARMUEBERWACHUNG /nicht_aktiv
REM 3061 FRA_H_R_IS_LED /aktiv
Reverse lights:
REM 3061 RFS_L_KALTUEBERWACHUNG /nicht_aktiv
REM 3061 RFS_L_WARMUEBERWACHUNG /nicht_aktiv
REM 3061 RFS_L_IS_LED /aktiv
REM 3061 RFS_R_KALTUEBERWACHUNG /nicht_aktiv
REM 3061 RFS_R_WARMUEBERWACHUNG /nicht_aktiv
REM 3061 RFS_R_IS_LED /aktiv
Brake lights outside:
REM / 3061 / BL_L_KALTUEBERWACHUNG /nicht_aktiv
REM / 3061 / BL_L_WARMUEBERWACHUNG /nicht_aktiv
REM / 3061 / BL_L_IS_LED /aktiv
REM / 3061 / BL_R_KALTUEBERWACHUNG /nicht_aktiv
REM / 3061 / BL_R_WARMUEBERWACHUNG /nicht_aktiv
REM / 3061 / BL_R_IS_LED /aktiv
Interior Brake lights:
REM / 3061 / BFD_L_KALTUEBERWACHUNG /nicht_aktiv
REM / 3061 / BFD_L_WARMUEBERWACHUNG /nicht_aktiv
REM / 3061 / BFD_L_IS_LED /aktiv
REM / 3061 / BFD_R_KALTUEBERWACHUNG /nicht_aktiv
REM / 3061 / BFD_R_WARMUEBERWACHUNG /nicht_aktiv
REM / 3061 / BFD_R_IS_LED /aktiv
Rear fog lights
REM / 3061 / NSL_L_KALTUEBERWACHUNG /nicht_aktiv
REM / 3061 / NSL_L_WARMUEBERWACHUNG /nicht_aktiv
REM / 3061 / NSL_L_IS_LED /aktiv
REM / 3061 / NSL_R_KALTUEBERWACHUNG /nicht_aktiv
REM / 3061 / NSL_R_WARMUEBERWACHUNG /nicht_aktiv
REM / 3061 / NSL_R_IS_LED /aktiv
Final result
There is also the possibility of adding the option as if the LCI rear lights were original
just add to the HO-wort (HELC) file and REM code
On the other hand, the 2 blue and green wires of the original bmw wiring (61122410220) are now connected to the A174 * 13B socket.
right side
blue wires location n ° 1 to the REM box (A174) socket (A174 * 13B) location n ° 5
left side
green wires location n ° 1 to the REM box (A174) socket (A174 * 13B) location n ° 13.
If After adding HELC and REM code it does not work check the following lines
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_PWM_LEVEL_1 = 13.7V [Default]
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_PWM_LEVEL_1 = 13.7V [Default]
REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_L_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_L_PWM_LEVEL_1 = 100% [Default]
REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_R_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_R_PWM_LEVEL_1 = 100% [Default]
REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_L_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_L_PWM_LEVEL_1 = 13.5V [Default]
REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_R_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_R_PWM_LEVEL_1 = 13.5V [Default]
REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_L_FIXED_PWM = fixed
REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_L_PWM_LEVEL_1 = 13.5V [Default]
REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_R_FIXED_PWM = fixed
REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_R_PWM_LEVEL_1 = 13.5V [Default]
REM_01 > LceLampMapping2 3063 > MAPPING_RUECKFAHRL_L_PWM_LEVEL_1 = 13.7V [Default]
REM_01 > LceLampMapping2 3063 > MAPPING_RUECKFAHRL_R_PWM_LEVEL_1 = 13.7V [Default]
REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_6_OUTPUT = sl_2_l
REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_7_OUTPUT = sl_2_r
REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_8_OUTPUT = bfd_l
REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_9_OUTPUT = bfd_r
REM_01 > LceOutputChannels 3061 > BFD_L_CCM = ccm_blinker_l
REM_01 > LceOutputChannels 3061 > BFD_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > BFD_L_UE_SPG_SCHUTZ = dimmed
REM_01 > LceOutputChannels 3061 > BFD_R_CCM = ccm_blinker_r
REM_01 > LceOutputChannels 3061 > BFD_R_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > BFD_R_UE_SPG_SCHUTZ = dimmed
REM_01 > LceOutputChannels 3061 > BL_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > BL_L_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > BL_L_UE_SPG_SCHUTZ = nicht_aktiv
REM_01 > LceOutputChannels 3061 > BL_R_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > BL_R_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > BL_R_UE_SPG_SCHUTZ = nicht_aktiv
REM_01 > LceOutputChannels 3061 > FRA_H_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > FRA_H_L_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > FRA_H_L_WARMUEBERWACHUNG = aktiv [Default]
REM_01 > LceOutputChannels 3061 > FRA_H_R_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > FRA_H_R_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > FRA_H_R_WARMUEBERWACHUNG = aktiv [Default]
REM_01 > LceOutputChannels 3061 > NSL_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > NSL_L_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > NSL_L_UE_SPG_SCHUTZ = aktiv [Default]
REM_01 > LceOutputChannels 3061 > NSL_L_WARMUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > NSL_R_CCM = NEW_ccm_nsl_r
REM_01 > LceOutputChannels 3061 > NSL_R_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > NSL_R_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > NSL_R_UE_SPG_SCHUTZ = aktiv [Default]
REM_01 > LceOutputChannels 3061 > NSL_R_WARMUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > RFS_L_CCM = NEW_ccm_rfs_l
REM_01 > LceOutputChannels 3061 > SL_2_L_CCM = Fxx_ccm_sl_2_l
REM_01 > LceOutputChannels 3061 > SL_2_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > SL_2_R_CCM = Fxx_ccm_sl_2_r
REM_01 > LceOutputChannels 3061 > SL_2_R_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > SL_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > SL_R_IS_LED = aktiv
Appreciate 15
      09-17-2015, 04:35 PM   #2
Daftasabrush
Fool
Daftasabrush's Avatar
England
1857
Drives: F31 340i
That's an amazing amount of work and skill, well done!
      09-17-2015, 05:23 PM   #3
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Thank you
      09-17-2015, 06:28 PM   #4
knightsabers
knightsabers's Avatar
Australia
454
Drives: Audi R8 v10 Spyder
Nice work, David
      09-17-2015, 06:40 PM   #5
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by knightsabers View Post
Nice work, David
Thank you to you too for information
      09-18-2015, 02:53 AM   #6
david51
david51's Avatar
France
538
Drives: bmw M3 F80
      09-18-2015, 08:43 AM   #7
rtruhlar
Czech_Republic
Drives: BMW M3 F80
Will this work also on F80?
      09-18-2015, 10:10 AM   #8
david51
david51's Avatar
France
538
Drives: bmw M3 F80
yes it is exactly the same
      09-18-2015, 10:21 AM   #9
KGB_123_99
Drives: '17 330ix M-Sport, '09 528ix
This is awesome stuff! Thanks!
      09-18-2015, 10:29 AM   #10
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Thank you
      09-27-2015, 09:47 PM   #11
Eat.Sleep.Race
Out Boosting...
Drives: F30 335i M-Sport
Awesome!!!
Alpine White M-Sport F30
      09-28-2015, 03:26 PM   #12
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by Eat.Sleep.Race View Post
Awesome!!!
      10-04-2015, 04:41 PM   #13
instalher
25cent millionaire
instalher's Avatar
Drives: 2020 m4 comp vert
2020 bmw  [0.00]
  [9.00]
  [0.00]
  [9.50]
2018 bmw 230i xdrive  [8.50]
now if we can get the parts for under 1k Canadian this is a feasible upgrade.
Diegs1422.00
      10-15-2015, 02:41 PM   #14
SHAZED
Instagram: Shazed0121
SHAZED's Avatar
Drives: F30 BMW 320D M Sport 2015
Just what I was looking for
Thank you very much mister..!
      10-16-2015, 04:56 PM   #15
david51
david51's Avatar
France
538
Drives: bmw M3 F80
      10-25-2015, 09:06 PM   #16
Bluesummer
Bluesummer's Avatar
Taiwan
588
Drives: slower than Ayrton Senna
2017 BMW X5M  [0.00]
2015 M4  [0.00]
2011 E82 135  [0.00]
2011 M3  [0.00]
2007 335  [0.00]
Does anyone know what's necessary to convert back to Pre LCI? I prefer those better... call me weird :P
IG:d.violet.m3
      01-06-2016, 06:48 PM   #17
VinnyA320
VinnyA320's Avatar
Drives: F80 M3
Hey guys. I ran a new wire from each inner lci taillight to the box by the battery. Which slots do i put the wires in for the inner turn signals/ brake lights to work? The locations in this guide are currently already used in my F80 for the slot numbers.
Everything else is working besides that. Thanks!
      01-07-2016, 11:49 PM   #18
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Hello
you talk about interior flashing?
      01-08-2016, 08:05 AM   #19
VinnyA320
VinnyA320's Avatar
Drives: F80 M3
Hello
Yep. Already had it done. Thanks anyways! Did your method use flashing or tapping for the inner turn signals?
      01-08-2016, 08:34 AM   #20
david51
david51's Avatar
France
538
Drives: bmw M3 F80
I do not understand your question
      05-04-2016, 01:50 PM   #21
cailas
cailas's Avatar
Lithuania
31
Drives: BMW M5 F90 2018
What for these things are needed?
      05-04-2016, 01:52 PM   #22
kemiksiz
kemiksiz's Avatar
Turkey
380
Perfect post, thanks a lot in the name of the lci modders
