BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
E93 Subwoofer options
12-21-2015, 09:08 AM | #1 |
Rep 485
Just picked up a new to me E93. It has option 676 HiFi and iDrive. I want to add a 12 to the trunk but obviously there isn't a lot of room in there.
I was a car audio installer back in the 90's. I haven't done much car audio work since then so I'm a little behind on current tech. Back in the day we would add High to Low level adapters to add a subwoofer amp to factory systems. That was never an ideal setup. Is it possible to tap the factory pre-amp outputs to create a low level pre-amp to a sub amp? |
12-21-2015, 11:21 AM | #3 |
Rep 485
12-21-2015, 12:46 PM | #4 |
Rep 145
If you have a ski pass, the best space-saving option is to run the sub IB through the ski pass. Many members here do that with very good sound quality results.
Because you have hi-fi, you have balanced output directly from the head unit. There is a harness sold by Technic that allows you to add a sub. I don't believe you need a LOC line driver, but you will need to purchase an amp that allows for balanced inputs. |
12-22-2015, 01:24 PM | #5 |
Rep 45
Nowadays, many amps accept high level inputs so all you would have to do is tap into the rear speakers (or whatever is the most accessible) to get the input for your subwoofer amp. No LOC needed.
That said, if what you're looking for is more bass, upgrading the underseat woofers and amplifying them can make an amazing difference without compromising trunk space. I have upgraded 8" underseats and I hardly ever crank up the 12" Hertz Hi-Energy sub I have in the trunk (I have a remote gain control for it). The bass from the underseats is nice and tight and the staging of having the woofer in the front is really pleasant. Food for thought. If you want a dedicated sub in the back you can get some pretty big sound out of some pretty small woofers. JL makes good stuff for sure but imo it's pretty overpriced. You can get some Pioneer woofers preloaded in a *tiny* box for a very reasonable price. I used to have the older version of the 10" and it surprised me. |
12-22-2015, 04:36 PM | #6 | |
Rep 79
12-22-2015, 05:06 PM | #7 |
Rep 313
Where are you based mate? I went for a custom e93 12" enclosure that fits in the boot and allows for the hatch to come down. The guys who make this are based in the UK so not sure what countries they deliver to. Here is the link if you are interested. I managed to fit a 12" 1000rms sub in and I have to say even with base stereo (im planning to upgrade the speakers at some point) and a dynavin N6 headunit it sounds fantastic (I cant say what it would sound like with a stock head unit through using a LOC)
Here is the link to the enclosure if you are interested http://www.ebay.co.uk/itm/BMW-E93-Co...-/251460766541 |
12-23-2015, 07:29 AM | #8 |
Rep 485
I haven't seen any speakers under the seat. I'll have to look and see if something is down there.
12-23-2015, 07:30 AM | #9 | |
Rep 485
12-23-2015, 12:21 PM | #10 | |
Rep 45
All E9X have woofers in the floor under the front seats. If you have HiFi you've got 8" underseat woofers. A custom-fit box for a 12" box will definitely get you the more bass but it still takes up a room. It's all a matter of how much bass you want and how important trunk space is.
http://www.audiotec-fischer.de/lng/en/ms-8b-bmw2.html They're not strictly plug and play but still very easy to install. They have higher power handling than the Bavsound woofers (150W vs 100W) and are significantly cheaper. Another very similar option (since I can't seem to find mine on eBay right now) would be the Earthquake SWS-8Xi. These woofers are extremely popular for upgrading the underseats and also boast 150W RMS power handling. http://www.ebay.com/itm/2-x-Earthqua...oAAOSwfcVUBjuS Half the price of Bavsound's while offering for better performance. Worth the extra manual labour in my opinion. |
12-23-2015, 01:45 PM | #11 |
Rep 485
I'll have to look under the seats tonight to see what's under there.
I ended up buying this for now. Amazon had a screaming deal on a used 12 and I should have it tomorrow. If it doesn't fit I'll use it in my E90. Looks like the thickest point is 11.5 inches so it should be close. |
12-23-2015, 02:02 PM | #12 | |
Rep 3,969
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
12-23-2015, 02:09 PM | #13 |
Rep 485
I used to build custom enclosures when I did car audio for a living. Dual ported bandpass boxes were my specialty. There's not enough room for that and I'm not looking to relive my youth.
12-23-2015, 02:19 PM | #14 | |
Rep 3,969
12-23-2015, 02:26 PM | #15 |
Rep 485
I did a lot of IB setups back in the day and didn't really like the sound...too boomy. Maybe there are better drivers now because this was 20 years ago. I'm not trying to win any SPL contests right now.
12-23-2015, 03:11 PM | #16 |
Rep 994
Yes, times have changed. IB sounds great with the right sub.
iPhone 6 Plus (iTunes library/iTunes radio/Waze, etc) to Airport Express via AirPlay. Toslink out of Airport Express to Helix P-Six DSP. PHD AF 1.C tweeters, PHD FB 4.1 midranges. Jehnert Door Cards and mid-bass'.
12-23-2015, 08:07 PM | #17 |
Rep 145
I don't think the concern is "IB or nothing else." I think the concern is that particular sub composition. A sealed 12 with an internal 300w rms amp that weighs 16 pounds? Something isn't right there. Btw, I don't run my subs IB either, but I am doubtful you will be satisfied with that product; particularly since you have some aftermarket car audio background.
12-24-2015, 05:53 AM | #18 | |
Rep 313
Anyway let me know how you get on with it. |
01-10-2016, 06:29 PM | #19 | |
Rep 5
E93 Ski Hatch Subwoofer
Swing by www.e93subwoofer.com, where you can get big bass in a small space. Thanks!
01-10-2016, 06:30 PM | #20 |
Rep 994
Installing a Brax Matrix in mine in a few weeks. Stay tuned
01-11-2016, 08:07 AM | #21 |
Rep 485
I installed the Fosgate box and it's not bad for what it is. The sound quality is not great but not bad either. I think I can hear the box flexing as much as I do the 12 at high volume lol. It moves some air and that's all I wanted until I can do something much better. My E93 does not have a ski pass but I have a plan to create an opening and do something in a little smaller box with more power behind it. I would have built an enclosure out of MDF to begin with but I sold my table saw a few months ago and don't have any means to build a box right now.
As for upgrading the factory wiring....with the amp on the driver side and the battery on the passenger it couldn't be easier. Way back when I worked for a Fosgate dealer we would have sold a boatload of these sub boxes if they had existed back then. I wouldn't say it's adequate for anything beyond adding some bass to an otherwise factory setup. |
01-11-2016, 08:54 AM | #22 |
Rep 15
I have a e92 and just bought 2 10w6v3 JL
Focal krs 100 for the front. helix dsp pro JL 900/500. Leave the subs that are under the seats. Also got a great deal from a dealer on eBay for Focal krs 100. Paid 415 Canadian with shipping and no VAT. You have to pm him for no VAT and better price. |
