BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Remove Manual Shift Knob
      12-31-2015, 12:29 PM   #1
paul e
Drives: Yes
How?
I've read where you just lift it up with some effort and it will pop off. I lifted so hard I thought the shift lever would come out of the tranny, the knob doesn't budge.
I want to get a wood knob but if I cannot remove the old one it'll just be an expensive paperweight.
Car is 2016 340i if that matters.
      12-31-2015, 01:12 PM   #2
BmwFlooner
Drives: 2013 M-Sport 335i 6MT
Make sure you've unclipped the boot first. Put it in second. Pull towards your chest. NOT YOUR FACE. Close your eyes. Feel the force flow though you. It will pop off.
Cpark1484.50
      12-31-2015, 01:24 PM   #3
paul e
Drives: Yes
Okay, but unclip the boot from what? The knob or the console?
And how to "unclip" as I see no obvious attachment?
I just saw STAR WARS so I am familiar with the Force. But this is my 1st BMW, so nothing is obvious. Thanks.
      12-31-2015, 01:47 PM   #4
Orion4
It takes a lot of force to get it off the first time. A number of folks have smacked themselves in the face. you wont break the shift lever. just be ready for the "pop" when the knob comes free.
      12-31-2015, 02:08 PM   #5
the_phew
Drives: '17 GTI 6MT, was 320i ZSP/ZMT
I found that the best technique is to straddle the tunnel, open the sunroof, stand up and pull with it in neutral (keep your knees bent and back straight, or you could injure yourself). First time took a bit of effort, now it pops off with minimal difficulty.
Remember to unclip the shift boot (using a flathead screwdriver or similar around the edges of the base of the boot) before pulling on the knob, or you could break the clips.
Cpark1484.50
      12-31-2015, 02:42 PM   #6
BmwFlooner
If you have the replacement part with you, you can see where the clips are on the boot.
If not, find a picture of the entire boot + shifter:
http://parts.bmwmonterey.com/a/BMW__...t/25_0537.html
The clips are around the edges of the boot. You'll need to push down and pull in to disconnect them from the frame.
The shifter itself is attached only by friction. It will take a LOT of force to get it off, but once it's off you can attach and remove much easier afterwards.
      12-31-2015, 05:01 PM   #7
Fronzdan
Drives: '24 M240 xDrive
If you just gently pull the boot inward around the base of the shifter you'll see how it clips in.
The way to remove the knob is not with a steady pulling like you're doing arm curls or something. A firm yank/snap upward is what will pop it off. But as everyone says, be sure you know where your hands will be going when it pops off. It's not difficult.
      01-01-2016, 06:16 PM   #8
E30toF30
Drives: 2016 528i Executive Edition
I just swapped my shift knob/boot out the other day. As others have said, you just kind of pinch the base of the boot inward to unclip it. And once the boot is unclipped, put it into second gear and pull hard.
Again just be cognisant of where it is aimed. Don't put your face above it as you might smash your face accidentally when it does pop off. Pull to your chest and it will come off.
I'm only 5'8, 150lbs, and not particularly strong or anything. Took me just a couple minutes to do the swap.
Let us know when you have succeeded!
