01-06-2016, 10:51 AM | #1 |
Rep 171
Drives: X3 M Comp
Auto Headlight Quirks
I'm experiencing a few quirks with my auto headlights (headlight switch set to automatic).
The biggest is during daytime hours when it's clearly sunny outside the headlights don't switch off and remain on. Or for instance, leaving work, I'm in a parking garage, the lights will turn on but when exiting the garage into the daylight they will not turn off. It's very sporadic too. For instance this morning leaving home from my parking garage the lights were on. I got out on the street and in the sun and they turned off. Went on the highway and into the 3rd St tunnel and they switched on as they usually do however, when exiting the tunnel and back into direct sunlight the headlights remained on the rest of the way to work. It's rather annoying. Is the computer aware of what time of day it is; like when leaving work after say 4PM and it's close to dusk or the sun going down, but still clearly bright outside, the headlights will remain on. Anyone else having anything like this? -NVE |
01-06-2016, 10:54 AM | #2 |
Rep 938
I've found this on my headlights too however I worked out if it's very bright or the sun shining directly at me, the lights remain on. Presumably to increase your visibility to oncoming drivers.
01-06-2016, 11:07 AM | #3 | |
Rep 171
Drives: X3 M Comp
-NVE |
01-06-2016, 11:30 AM | #4 |
Too much is never enough
655
Rep 3,079
The lights will turn on if the sun is at a low angle - i.e. glare is likely - to improve your visibility to other drivers. The times you've described would certainly support that given the time of year and inclination of the sun.
01-06-2016, 12:29 PM | #5 | |
Rep 171
Drives: X3 M Comp
-NVE |
01-06-2016, 12:33 PM | #6 |
Rep 155
You can code the lights to be less sensitive and stay off under less external light. I too have found them to turn on under conditions i would consider daylight.
01-06-2016, 03:20 PM | #7 |
Rep 4,478
Drives: '23 X1 28i xDrive
Yet another feature that is curiously only controlled through "coding". Why not an iDrive setting??
01-06-2016, 03:25 PM | #8 |
655
Rep 3,079
Because they're configured differently for different markets around the globe. North America is the frivolous lawsuit capital of the world, so we don't get to control our own destiny. I can't say that I blame them...
01-06-2016, 03:43 PM | #9 |
Rep 4,478
I can't control the sensitivity of my headlights because I might sue BMW because ... what, the lights don't come on at 4:00pm? But I can turn off my DRLs, which are supposed to be a safety feature...? Okaaaayyy then....
01-06-2016, 04:01 PM | #10 | |
655
Rep 3,079
You CAN control the sensitivity of your lights - the old fashioned way. Don't use the auto setting. If you do, you let them decide what's best for you. I guarantee you that somewhere, someday, someone would get in a wreck and their attorney would claim that the automatic headlights malfunctioned causing the wreck. This is the world that we live in, and it sucks for those of us that aren't idiots. |
01-06-2016, 04:04 PM | #11 |
Rep 4,323
don't they turn on dusk and dawn....?
01-06-2016, 07:14 PM | #12 |
Rep 31
FYI, when the auto headlight is triggered and you go back into daylight, there is a delay before the lights turn off. I believe it's a delay of several minutes in case you might go back through a tunnel or into a parking garage. Totally normal.
01-07-2016, 05:40 AM | #14 |
Rep 125
Drives: 2013 328I Sportline
01-07-2016, 09:31 AM | #15 |
Rep 171
Drives: X3 M Comp
01-07-2016, 09:19 PM | #16 |
Rep 687
Do you have anything covering your rear view mirror? Like a parking pass hanging there, or a navigation unit/radar detector/dashcam?
I moved mine to fix the issue. Also, it is possible to adjust the headlight sensor sensitivity in-dash on the E90. They removed it on the F... |
01-09-2016, 11:24 AM | #17 |
Rep 4,478
02-08-2016, 11:43 AM | #18 |
Rep 1,342
Just the thread I was looking for. Where exactly is the auto headlight sensor for ambient light?
My auto headlights also seem to be on more often than off. Had another F30 opposite from me at a stop light this morning, his halos where on...headlights off. But my headlights were on. I put my toll tag just to the right of the inside rear view mirror, but it's not that near the rain sensor...wouldn't think it would affect anything else? |
03-01-2016, 06:22 PM | #19 |
Rep 1,342
I was able to code it to be less sensitive, I think it's mo' betta now. (my first coding session...yay!)
Still don't know where the daylight sensor is...anyone? Is it in the same place as the rain sensor? |
03-01-2016, 08:33 PM | #20 | |
Rep 4,725
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
03-02-2016, 07:34 AM | #21 | |
655
Rep 3,079
03-03-2016, 03:38 PM | #22 |
Rep 1,114
Hmmmm........Just like our "Auto" Wipers?
My Ride! : 2015 428i GC (F36) - MSport, Alpine, Black Leather, MBrakes, Adaptive, Sport Seats, Hex. Alum w/Piano, HK Sound, 400m's, Comfort Acc. When I’m not Driving: https://youtube.com/shorts/ViKD_Hj5htE?feature=share
