BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Only one exhaust steam?
      01-21-2016, 01:06 PM   #1
venom4065
Drives: 2016 F36
My 2016 F36 is equipped with MPE and MPPK, I noticed when my car was sitting idling on cold day and only one steam coming out of one exhaust? MPE came with two exhaust system. Is one exhaust fake or close while another one is open?
      01-21-2016, 01:08 PM   #2
crono06
crono06's Avatar
Drives: 2013 335i and 2018 X3
The left pipe has a valve. During warm up, it's closed so you'll only see exhaust coming out of the right side.
      01-21-2016, 01:09 PM   #3
Ali Shiralian
Ali Shiralian's Avatar
Drives: 2014 335i xdrive, 2014 X5 3.5d
I believe it's the same with all BMWs. First steam comes out of the right pipe and after a minute or so the one on the left opens up and smoke comes out of both. I know it's kinda strange looking at it but once the car is warmed up, both pipes emit equal amounts...
      01-21-2016, 01:13 PM   #4
yoandry
yoandry's Avatar
Drives: 13 F30 335i & JGC
Send a message via AIM to yoandry Send a message via MSN to yoandry
Yeap, totally normal
PS2+ WMI + MHD Bef+JB4, VRSF DP, CP, FMIC Race 6, AFE Intake, MP-LSD, MPPK, MPE, MP-Susp, MP-Brakes, 437M, MP-interior trim, MP-Alcantara Steering Wheels W/race display, MP-Lip, MP-Diffuser, MP-Spoiler, MP-Rocker Panel, MP-Sills, MP-Pedals, MP-Grille, MP-Mats.
      01-21-2016, 02:36 PM   #5
venom4065
Drives: 2016 F36
Thanks, I was reading other forum that I can make it open by unplugging connector on exhaust and it is 10 minutes job. I wonder if coding is also other way?
      01-21-2016, 03:51 PM   #6
crono06
crono06's Avatar
I don't believe the valve can be coded to always be open. If you drive around in sport mode, it will be open.
      01-21-2016, 04:20 PM   #7
Vegetable
Vegetable's Avatar
Drives: M4 MT
Is the valve disconnect different on the MPE than the stock exhaust? Because it certainly is no 10 minute job on the stock exhaust, maybe 10 seconds. Simply unplug connector and tuck away. It should be noted that this "Mod" (if you want to call it that) should only be done in the morning (before start-up) when the valve is open. You can shine a flashlight into the left exhaust to make sure it's open. I hated seeing steam come out of only one pipe in the morning (even in sport +) so much so that I did this mod solely for that purpose.
M4 in MG | 6 MT
      01-21-2016, 05:22 PM   #8
northern_435GC
northern_435GC's Avatar
Drives: 435 GC x-drive
Can you post pics of where this "connector" is please. only having one exhaust open annoys the shit out of me.
      01-21-2016, 05:38 PM   #9
venom4065
Drives: 2016 F36
This is from other post:
http://f30.bimmerpost.com/forums/sho...d.php?t=812946
      01-21-2016, 05:50 PM   #10
venom4065
Drives: 2016 F36
Thanks for tip, I am not sure what is different between stock and MPE. I will give it a try when I have time.
      01-21-2016, 06:28 PM   #11
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
As mentioned above, completely normal
      01-21-2016, 07:54 PM   #12
Trcb777
Trcb777's Avatar
Drives: 2013 335i M Sport
Stock and MPE are the same. Three ways to open the valve all the time.
1. Golf tee mod. Remove spring and Wrap a wire around the flap valve. 2. Just disconnect the connector on the left at the flap valve. Just verify its in the open position when you disconnect it. 3. Jb4 tune will allow you to open or close it whenever you want via the BC button on the steering column.
The weekly "exhaust only out of passenger side" service announcement. 😄
      01-24-2016, 03:25 PM   #13
northern_435GC
THX
      01-24-2016, 05:04 PM   #14
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
+1, and there's reasons why it's that way. If there weren't BMW wouldn't do it, if only for the cost savings and reduction in complexity.
      01-24-2016, 06:15 PM   #15
Anton_RU
From Siberia to Switzerland
Anton_RU's Avatar
Switzerland
Drives: F32 435i
Hey, I was thinking about doing the same, as it bothers me a lot to see that smoke comes out only from the right pipe. But even before start up the valve is closed, so if I unplug it - it will remain always closed, is that right?
Did you notice any change after unplugging? No errors on the dash screen?
Thanks in advance
2015 F32 435i M Sport | RWD | 19" 442M | 8AT | Black Sapphire | LCI Rear lights | Llumar ATR 15% | Mike's Customs downpipe | MPE | MPPK | MP Brakes | H&R 10/12mm spacers
Previously: 2008 E92 335i / M-pack / RWD / 6AT / Frozen Grey
      01-24-2016, 06:28 PM   #16
Vegetable
Vegetable's Avatar
Drives: M4 MT
Thanks in advance
The valve should be open in the morning before start-up. If you unplug the the connector when the valve is closed, it will remain closed, so make sure it's open. There will be no errors on the dash. The only thing that I have noticed is a bit more sound if I put it it eco pro or Comfort, but I never drive in those modes anyway.
M4 in MG | 6 MT
      01-24-2016, 06:30 PM   #17
Anton_RU
Anton_RU's Avatar
Switzerland
Drives: F32 435i
The valve should be open in the morning before start-up. If you unplug the the connector when the valve is closed, it will remain closed, so make sure it's open. There will be no errors on the dash. The only thing that I have noticed is a bit more sound if I put it it eco pro or Comfort, but I never drive in that modes anyway.
Thanks! I had a feeling that it's closed in the morning, but will try to check if that's so.
      01-24-2016, 10:47 PM   #18
zman1237
zman1237's Avatar
36
Drives: F12 M6, F32 428i M-Sport
Is the valve supposed to be opened or closed at startup? I have seen it stated a couple different ways. I believe my valve is open and then closes once it warms up a bit. This makes sense to me, but it does not explain the steam only coming out of one side of the exhaust in the morning. Wouldn't it be the other way around?
F32 M-Sport
F12 M6 Competition
      01-24-2016, 10:59 PM   #19
Trcb777
Trcb777's Avatar
The valve is closed on startup. The loud startup noise is because of the wastegate at the wide open position.
      01-25-2016, 10:25 AM   #20
RoundelM3
RoundelM3's Avatar
Drives: 15 M3 Sedan, 16 228i Cabrio
2015 BMW M3  [0.00]
2016 BMW 228i  [3.00]
It's not "smoke", it's water vapor - but regardless, it's normal, and with the flap disconnected, you get an annoying drone at moderate throttle that will drive backseat passengers nuts. I did this to mine (also with MPE and MPPK) and re-plugged it after a couple of cruises down the highway.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2016 228i M-Sport Cabrio 8AT Melbourne
      01-25-2016, 11:37 AM   #21
Anton_RU
Anton_RU's Avatar
Switzerland
Drives: F32 435i
You are right, the valve is always closed unless you put the car in Sport or Sport + and floor the pedal.
      01-25-2016, 12:25 PM   #22
venom4065
Drives: 2016 F36
It seems that it is impossible to unplug actuator while flap is open. I tried many different method to make it open and no luck. If there is no choice and I will have to unclip and wire it.
