| 01-31-2016, 12:14 PM | #1 |
![]() ![]() 29
Rep 318
Lights on shifter not illuminating
So I noticed a few days ago that the lights on the gear selector are not illuminating. They turn off after a minute or so. If u put the car in park, the P does not light up. If I put it in drive or reverse, the light does not change or illuminate. Has this ever happened before? I'm at 50,100 miles... This sucks.
| 01-31-2016, 01:02 PM | #2 |
Rep 4,311
Had this issue on one of my new F11's. Required replacement of gear shift lever, under warranty.
Owned: 440i GC LCI with MPPSK, F31 330D M Sport with MPPK, F11 530D SE, F11 520D SE, E61 530D M Sport, E36 325i plus many MB's, Audi's & Volvo's
| 02-01-2016, 07:58 AM | #4 |
![]() ![]() 29
Rep 318
Bump. So I started my car this morning and it was lighting up perfectly. As soon as I put the car in gear the light turns off approximately 5-15 seconds later. This every happen to anyone else?
| 02-01-2016, 10:17 AM | #5 |
Rep 333
I don't think I've ever paid that much attention to the shifter haha...now I'm going to have to check
2018 F80 M3 6MT (current)
2014 F31 328i Touring (sold) 2008 E92 M3 6MT (sold) 2011 E90 335xi (lease up) |
| 02-01-2016, 10:54 AM | #6 |
Rep 5,739
Drives: G80 M3 6MT
Not supposed to happen, take it to the dealership.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
| 02-01-2016, 11:02 AM | #7 | |
Rep 5,005
Drives: '23 X1 28i xDrive
| 02-01-2016, 11:03 AM | #8 |
Rep 5,005
| 02-01-2016, 01:11 PM | #9 |
![]() ![]() 99
Rep 378
Drives: '16 340, ex e92 335, ex e46 M3
| 02-01-2016, 01:19 PM | #10 |
Rep 4,311
Please see my response above, I had the same problem and its a dealer fix
| 02-01-2016, 03:09 PM | #12 |
Rep 5,005
| 02-01-2016, 06:09 PM | #13 |
![]() ![]() 29
Rep 318
Well I'm actually 1,000 over lol. More than I thought. I 100% will not take it or pay to have it fixed. Just curious if anyone trouble shooted the issue. Might be a fuse for all I know. Really sucks to be honest with you, I look down and have no idea what gear I'm in.
| 02-02-2016, 03:19 AM | #14 | |
Rep 4,311
As you can see from the picture, its a self-contained unit, and the light module cant be replaced separately. Clearly, the lighting isn't supposed to fail but it does - as it did for me, and has done for you. http://www.realoem.com/bmw/enUS/show...diagId=25_0519
| 02-02-2016, 09:54 AM | #15 |
Rep 5,005
Well--don't look down. Look at your IP, either in the center, or below the tach if you have extended display.
| 06-30-2020, 06:00 AM | #17 |
Rep 1
Hi all. I just bought the 320i F30 year 2012 with only 33,000km. I just noticed it has the same problem with no lights on the indicator. Can someone help me find a replacement? my car is a RHD. Thanks a lot.
| 07-01-2020, 02:05 AM | #18 |
Rep 2,501
I don't think I've ever had to look at the shifter to know what gear I'm in driving an automatic BMW. That's why the design is actually pretty good. You only have to be careful when you put it in neutral, but you don't have to do that often in an automatic.
tex26702751.50 |
| 03-18-2021, 11:25 AM | #19 |
Rep 16
i know this is an older thread but just came across this occurrence 0n my 2014 F30
from my understanding it is the LED module inside he knob housing that is faulty Has anyone had any luck just replacing the module without having to change out the whole assembly and then getting it reprogrammed to mate to the vehicle? i see some used gear selectors on ebay for under $100 and wonder if its possible to just swap out the LED module. Thanks |
| 03-19-2021, 04:27 PM | #20 |
Rep 16
Just took the trim off and see it a LED module that pops out.
Anybody know where to get a replacement ? Not handy enough with the soldering gun to replace the LEDs themselves. |
| 02-01-2022, 09:23 PM | #21 |
Rep 12
Picture of what worked for a very expensive knob
I have a bmw 435x modified I had the same situation, a person that sells on eBay has the circuit board for around 180.00. It worked perfectly all you need is a torx t9 and a knife. They supplied a new circuit board and a new panel to the board. I will post a picture of what I got.
| 02-01-2022, 09:27 PM | #22 |
Rep 12
| Bookmarks |
