BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 JB4 Customer Dyno Compilation Thread - Show us your Dynos!
      02-11-2016, 09:41 AM   #1
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
As more and more of these cars are getting into customer hands I wanted to start a modding thread for the B58, specifically to get some end user data with the JB4 and any other mods you may have.
I'll start the thread with the BMS JB4 dyno, but can't wait to see some user data..
      02-12-2016, 07:38 AM   #2
Cory S
Cory S's Avatar
Drives: 2011 335i-X
STD correction, Smoothing at 5, and running far too lean on that dyno chart......
Let's see what BMS's test car makes with a more widely used SAE correction, less smoothing (to really see the curve spikes/dips), and a much safer 11.8-12.2:1 AFR???
      02-12-2016, 08:22 AM   #3
platty
platty's Avatar
237
Drives: M4 VERT
All of these engines run lean. N55 is the same way. That's about par for the course.
      02-12-2016, 08:33 AM   #4
Bee Pee
Bee Pee's Avatar
Drives: AW M2 DCT
The chart in post # 1 is BMS' test car and AFR's look normal given its beta map 1 stage just now and based on JB4's running for years on N54/N55
Current '22 X3M LCI..
      02-12-2016, 08:37 AM   #5
Cory S
Cory S's Avatar
Drives: 2011 335i-X
Lean is one thing (12.4-12.7), but 13.5-14:1?? I don't care what engine it is, that begging for meltdown eventually. Hell, that's leaner than NA tuned at max power....
      02-12-2016, 08:48 AM   #6
platty
platty's Avatar
237
Drives: M4 VERT
From N54tech:
AFR: The AFR (Air Fuel Ratio in Lbs air/ Lbs gasoline fuel) trend displays for each bank under AFR1 for bank1 (1,2,3) and AFR2 for bank2 (4,5,6). Typical values are 15:1 at light engine loads decreasing to around 12.5:1 under heavy engine loads and high rpm.
Note: The N54 is a direct injection motor and as such will run much leaner air/fuel ratios than many who have worked with older platforms are used to seeing. It's common to target 14:1 at peak torque and 13:1 at peak HP for example. It is also normal to have the AFR display 20:1 when car is coasting in gear or under a misfiring condition where the DME will cut off fuel to the misfiring cylinder(s).
      02-12-2016, 08:53 AM   #7
Cory S
Cory S's Avatar
Drives: 2011 335i-X
That's nuts..... I just don't see why it would be able to get away with it that lean. Lean is lean. We run our 550hp 10:1 NA engines at 12.7-13.0:1, and our 700-800hp Boosted ones at 11.7-12.0:1...
      02-12-2016, 09:27 AM   #8
Mike@N54Tuning.com
+1
Mike
      02-12-2016, 10:31 AM   #9
Remonster
Drives: E90 M3
Notice that the stock run shows the same lean AFR. They're right, all these new motors run much more lean that what we're used to seeing.
      02-12-2016, 10:34 AM   #10
Cory S
Cory S's Avatar
Drives: 2011 335i-X
No wonder the canned tunes in my COBB V3 weren't great... I was seeing 11.6-11.9:1 AFR on most of the maps....
So if 13.0-13.8 is ok for N54/55, what would be approaching danger zone? Anything over 14.5:1?
      02-16-2016, 10:10 AM   #11
Mike@N54Tuning.com
+1
Mike
      02-16-2016, 01:18 PM   #12
Baldmonkey22
Drives: 2016 340i
Wondering what the stock target boost level is? I haven't seen it published anywhere.
      02-16-2016, 05:18 PM   #13
Mike@N54Tuning.com
This is a log from a stock run.. and corresponding dyno
Mike
      02-16-2016, 09:02 PM   #14
Spikey
Australia
64
Drives: erratically
Mike
peaks just under 15?
      02-16-2016, 09:51 PM   #15
Baldmonkey22
Drives: 2016 340i
Thanks mike looks like maybe 14.8 PSI at 5250 rpm for that pull...
      02-16-2016, 10:30 PM   #16
Sleeper
Sleeper's Avatar
Drives: '23 BSM X5///MC
Wow. So the B58 is running close to 15 PSI stock while the N55 is running 9 PSI. Do the power output differences between the two make sense with a boost delta of 6 PSI? Must be very different tuning strategies for the two different engines.
      02-17-2016, 12:41 PM   #17
Mike@N54Tuning.com
Ya its in the 14-15 range..
Mike
      02-17-2016, 01:07 PM   #18
Mike@N54Tuning.com
Turbo size, tuning, design all come into play.. Remember as the years go by manufactures are more interested in emissions. So this change may be emissions related. Car may produce much less emissions when cruising as it looks like without the turbos power may be down versus the N55. (just speculation)
Mike
      02-17-2016, 01:13 PM   #19
Cory S
Cory S's Avatar
Drives: 2011 335i-X
It's not the manufacturers interested in emissions. It's the EPA driving their ridiculous standard, forcing manufacturers to meet strict requirements.
      02-18-2016, 01:49 PM   #20
//M
Drives: M2 Comp
Mike
You might be offbase here. The B58 has a higher compression ratio then the N55, I highly doubt it makes less power off boost.
Also that graph has to be the tuned run... look at the throttle closures and the timing drops... thats not stock
Im guessing you basing the power comment off of the graph.
      02-22-2016, 03:14 PM   #21
F80Boost
Drives: Beater
On a tuned vs tuned basis, isnt the N55 a better platform to start with vs the B58, due to the B58 being limited as far as added power ?
Whats the compression on either motor ?
      02-23-2016, 11:49 AM   #22
//M
Drives: M2 Comp
In the long term, B58 is probably the better bet.
Ecu tuning will come, they're getting closer and closer.
N55=10.2:1
B58=11:1
B58 is leaving power on the table with the super lean mixture.
