BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Eibach Sway Bars?....
02-05-2006, 05:28 PM | #1 |
Rep 946
Drives: BMW Fanatic
Garage List 2013 Fiat Abarth [0.00]
1993 Honda Civic EG ... [0.00] 2009 Suzuki LTR 450 [0.00] 2008 Acura MDX [0.00] 2001 Z3 M Coupe S54 [0.00] 1988 E30 M3 [0.00] |
I am seriously considering to get the Eibach Sway bar set..I already have the sport package which is great but want more..What do you guys think?..
1988 E30 M3 Diamantschwartz/Black |
02-05-2006, 06:24 PM | #3 |
Not Stock
160
Rep 2,774
I think springs will make the biggest difference if less body roll is what your after. The sway bars are going to do very little, the car is already extremely stable.
02-05-2006, 07:44 PM | #4 |
Rep 6,158
Diesel is wrong here,
On my E30 (the only car I modded stuff with) I first put lowering springs on, which reduced body roll a bit, then later I added swaybars which reduced body roll A LOT. Lowering springs make your ride rougher, while sways won't. Also swaybars can be adjusted to make your handling more neutral (you can dial out some of the factory set understeer, set the rear bar to full firm) People generally do lowering springs for asthetic reasons, swaybars are a better bang for the buck mod |
02-05-2006, 08:58 PM | #5 |
Rep 6,750
I assume you're thinking about changing both front and rear sway bars. Swapping out the front one alone for a stiffer anti-roll bar will increase understeer. Similarly, increasing the stiffness of the rear anti-roll bar alone will increase oversteer.
In theory, decreasing body roll in the twisties should help cornering, but I've read articles where stiffness decreased slalom and/or lap times. On non-smooth services or bumpy curves, I wonder if the added stiffness would actually impair the suspension's ability to absorb the shock of the bumps while maintaining the car's composure. |
02-05-2006, 09:04 PM | #6 | |
Not Stock
160
Rep 2,774
You are comparing an e30 to an e90 they are two completely different cars. . If you read my post I said that the e90 already comes very solid from the factory, therefore changing the sway bars is really not going to a whole lot. What experience do you have with tuning suspension on an e90 to say I am wrong? |
02-05-2006, 09:24 PM | #7 | |
Rep 6,158
the E90 is decent, but even with sport pack it has a lot of body roll I see that you think the E90 is very solid, more solid than a stock E30 but much less solid than many other cars on the road. Go drive a Z4 or Boxster and then tell me you still think the E90 is "solid" you also (maybe I misunderstood) stated that changing springs would reduce body roll more than changing swaybars. That's just a clear misunderstanding of what suspension components do what.... the swaybars (also known as anti roll bars) are there to reduce body roll, lowering the car with stiffer springs will reduce body roll but not as much as improving the part of the car that's designed to reduce body roll suspension tuning is pretty similar for all cars, knowledge from an E30 is VERY valid when talking about an E90. The frogman is also correct that very stiff sways can unsettle the car in large mid corner bumps, the car will be better on smooth pavement but will give up a little bit if the road gets really bumpy in the corners. There is ZERO drawback to swaybars when you're traveling in a straight line (unlike lowering springs) if you want to corner better, the sways will GREATLY aid in transitions from left to right (slalom type maneuvers) |
02-05-2006, 09:38 PM | #8 |
Not Stock
160
Rep 2,774
You never answered my question. I agree with you that sway bars will decrease body roll, but in my PERSONAL experience with changing out the springs on my e90 it has made a very significant decrease in body roll. You are saying my personal experience is wrong that is why I asked you if you have any suspension mods on the e90.
Yes the ride is stiffer but it's not race car stiff. If I added the sways it would be even better so lets agree on that. Again we are talking about an e90 here no a boxer or z4 or e30. |
02-05-2006, 09:56 PM | #9 | |
Rep 6,158
I have lowered a similar car AND upgraded swaybars. you have zero experience with upgrading swaybars and have no basis of comparison as to what a set of sways will do compared to a set of springs. if you next add a set of swaybars to your car then I'm sure you'll agree with me that they make a larger difference in body roll reduction than the springs (I never said springs don't/won't help body roll, I said they help LESS than sways. If I was modding my car I would personally do the sways first if I only had the budget to do it a bit at a time) I really don't understand how my experience with lowering springs AND swaybars is somehow less valid than your experience with lowering springs only I hope Shady finds our comments usefull |
02-05-2006, 10:05 PM | #10 | |
Rep 946
Drives: BMW Fanatic
02-06-2006, 12:04 AM | #12 | |
Rep 16,628
02-06-2006, 10:43 AM | #13 | |
Not Stock
160
Rep 2,774
Your information is very valid and true, I was just throwing my 2 cents from my experience. I will most likely be upgrading my swaybars in the future. |
02-10-2006, 09:22 AM | #14 | |
Rep 10,176
By the way, that rear sway (even on the sports package) is a joke, if you look at it. It's more the size of a linguine.. I can't believe it is doing much of anything, given it's puny size, and the forces it is supposed to counteract. Another thing you'll notice is that the rear sway appears go over the rear end, and bolt to the top of the diff. that may prove tricky to replace. I haven't actually gotten under there, but it didn't look too fun, when I saw it while swapping out my track wheels/tires. |
02-10-2006, 11:59 AM | #15 | |
Rep 16,628
02-10-2006, 12:57 PM | #16 |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
I thought for our e90(or any rear drive car) that to get more oversteer, leave the back bar alone and upgrade the front bar. The opposite proved right for my FWD car, I upgrade the rear bar and the car turned on a dime! Guess I'm wrong.
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
02-10-2006, 06:21 PM | #18 | |
Rep 10,176
02-12-2006, 03:46 PM | #19 |
Chicketeh china the chinese chicken, you have?
Rep 790
Drives: 335ci hold out
I've heard that larger sway bars are pretty much useless/unnecessary unless your car is lowered with springs or coil overs.
"In Soviet Russia car forks you!"
02-12-2006, 04:31 PM | #20 | |
Rep 6,158
they are completely useless, unless you want to reduce body roll |
02-12-2006, 06:14 PM | #21 | |
Rep 790
you know what i meant, aftermarket.
