BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > OEM F30 LCI Headlamp Conversion Harness
      03-12-2016, 10:14 PM   #1
ZeeSpeed
Drives: E46 M3
In realoem, under the 'Accessories and Retrofits' section,for the pre-LCI F30 there appears to be a conversion harness for converting to LCI headlamps. The part number is 61122410223. Has anybody carried out this conversion yet using this harness?
In the same section on for LCI F30s there is a harness for retrofitting LED headlamps 61122410239. Can this harness also be used for retrofitting Adaptive LED headlamps into a pre-LCI F30?
      03-13-2016, 06:33 PM   #2
ji99lypuff
Drives: 2014 bmw 328xi
I know there was one guy who had done the lci retrofit but he doesnt frequent the forums often or at all that i can recall. He has a youtube video or two up showing the finished thing with leds swiveling when he turns the wheel. He was either from thailand or malaysia somehwere in that vicinity. Contacting him would be your best bet as he has had pre lci car that got the lci led adaptive retrofitted.
      03-23-2016, 10:07 PM   #3
A'PEXi
A'PEXi's Avatar
Australia
64
Drives: M3
sounds like max from elebest - the lci headlights are not cheap though...
      03-24-2016, 07:51 AM   #4
Adamr916
Adamr916's Avatar
Drives: 2014 328d
You'd be surprised, I saw a non-adaptive set on ebay (coming out of the UK) the other day that was $1500 for a full complete set. They didn't last very long, but if you look hard enough, they are starting to show up more regularly now.
      03-24-2016, 02:05 PM   #5
rollinstone157
Brotographer
rollinstone157's Avatar
Drives: F30 335xi
The adaptive lights are going to be the real challenge, but given enough time they'll start popping up in the used market.
      04-03-2016, 01:37 PM   #6
marius76
Drives: F30 335i & E90 335d
LED headlights require few new wires and there is a difference between number of wires in F30 harness and F80 harness.
It looks that this OEM harness 61122410239 is correct, however when I did my LED retrofit, I created my own harness using OEM plugs, sockets, connectors... and can do more if anyone need it.
      05-05-2016, 05:54 AM   #7
I.A.W
I.A.W
Thailand
Drives: F10
Smile
I'd be interested in getting a set of your harness for this conversion. Does your harness work with RHD non-adaptive Xenons?
      05-05-2016, 09:18 PM   #8
Who?
Who?'s Avatar
Australia
449
Drives: F87 LCI
so what kind of coding id needed?
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
      08-15-2016, 10:21 AM   #9
Alex_straume
Drives: bmw f30 2012
LED retrofit
Hi. could you make an harness for me? how much would you charge for this?
i got an f30 2012 and want the LED retrofitted. but haven't bought any headlights yet. do you have an preference about getting the adaptive or non adaptive?
thnx.
      02-13-2018, 07:00 PM   #10
Jhnblckwood
Drives: F30 2014 320i xdrive
I can't find a clear cut guide for pre lci halogens to lci full led non adaptive retrofit. Anyone have a link? The one PDF I found that was great said was only good for cars build 7-14 n on while mine was build 5-14. I made a new post with the PDF if anyone can help I'd really appreciate it. Been researching for months but still can't figure it 100%
      04-07-2018, 09:02 PM   #11
YusufLUK
Drives: 2014 M Sport F30
Link?
      04-10-2018, 03:12 PM   #12
Jhnblckwood
http://f80.bimmerpost.com/forums/att...7&d=1490600365
      07-11-2018, 02:58 PM   #13
ottawa_f30
Drives: 2013 328x
Do you have anymore that you can make? I would love to buy one
      07-30-2018, 01:44 PM   #14
dashti640
Drives: F06
Hi,
im looking for some help with LED Headlight Retrofit for a F06 currently is Bi-Xenon and want to upgrade them to LED. i have got the Headlights and apparently needs rewiring and i appreciate and help. thanks in advance
      08-01-2018, 01:34 AM   #15
Nomana
Nomana's Avatar
1266
I thought it's like conversion harness that plug on ones ends and done. Didnt know that we need to wire to rear fusebox
      10-24-2018, 05:11 PM   #16
Markom051
Drives: F31
Anyone knows what is the pinout of the fem on 12/2012? Before 07/13 it was using K-Can, not the K-Can 2. Where to take out the K-Can 2 as I know the car have it but don’t know if anybody retrofited to full LED LCI.
Thanx
      11-05-2018, 07:32 PM   #17
Littlebear
Major Major
Littlebear's Avatar
Drives: 2017 330i
Hello BMW Experts!
I have a 2017 330i lci, standard halogens.
So like, I got some LED headlights, and the harness, but can someone tell me, or better yet show me, how & where I connect the harness, pls? I can rip off he front bumper just, fine but where to connect & hang the wires has eluded me so far... Do I have to go to the rear fusebox?
TIA! Murf
