03-13-2016, 01:14 PM | #1 |
Rep 1,988
Headliner Rattle when Flexing
My 2016 340 xDrive (build 8/15) has really loud and annoying rattles when the car is flexing (such as when coming out of a drive way or even some uneven bumps). It sounds like it's coming from the rear drivers side headliner. Does anyone else have this and if so have you found a solution? Normally I have the radio on so i don't hear it, but recently drove without the radio on and it's quite bothering especially for a new car with less than 2k miles on it.
03-13-2016, 02:10 PM | #2 | |
Rep 377
We've gone to the dealer multiple times for this issue. They've sprayed some sort of thing on it, changed out the seals, and it always just comes back. I've given up and just close the moonroof visor to block out the sound. :/ I read another forum that there is some type of anti-creak tape especially for these seals, though.
2014 BMW 328i, 6-speed Prem / Nav / Drivers Assist / Heated Seats / Lighting |
03-13-2016, 07:18 PM | #3 | |
Rep 1,988
Good luck with your fix! |
03-13-2016, 08:18 PM | #5 |
Rep 199
03-13-2016, 08:26 PM | #6 |
Rep 72
I have rattle coming from the rear brake light cover on the top of rear wind sheild.. It is loose and vibrating against the rear windshield... You should check that too.
03-13-2016, 08:40 PM | #7 |
Rep 3,622
+1 on door seals
BMW CCA Member #516012
03-14-2016, 08:06 AM | #8 |
Rep 6,993
First, try taking it to the dealership - it's a brand-new car with a full warranty. If they can't or won't fix it, then the teflon tape mentioned above is the best resolution.
