04-15-2016, 03:37 PM | #1 |
Rep 210
F30 BMW 340i B58 Engine Oil Change DIY
Just hit 4k miles on my 340i so i did a oil change, straight forward process:
1. Jack up car on jack stands and make sure it is secure(Not responsible for any deaths) 2. Open oil cap so oil drains nicely. 3. Pop off cover for oil drain with a flat head 4. Get 17mm socket to drain oil, there was no crush washer on my car but the oil filter came with one so i used it. 5. Take out oil filter. You will need a 32mm socket to take it out. 6. Replace oil filter with new filter 7. At this point your oil be drained are almost all the way drained out. Once its drained of course tighten the drain plug with new crush washer. 8. Refill with a 7 quarts of oil of your choice, I personally used Castrol 0w-30 European formula. 9. Enjoy the extra 20hp you gained from a oil change |
04-15-2016, 04:08 PM | #2 |
Rep 497
You should make a slight edit. It's better to remove the fill cap after you remove the drain bolt, this will allow you a little bit more time (better still move quick) to get the bolt out of the way before it starts flowing out. Just remember the drain flow will extend further out once you remove the fill cap so line it up your catch receptacle appropriately.
04-15-2016, 05:35 PM | #3 |
2JZ-GTE
3032
Rep 3,992
Nice write up.
Does the car take exactly 7 quarts? |
04-15-2016, 05:38 PM | #4 |
64-bit
598
Rep 814
Drives: 2018 BMW 340i xDrive
Thanks for the DIY.
Thinking about doing mine as well. Just hit 4K Miles. |
04-16-2016, 07:50 AM | #6 |
Rep 6,990
This would go great in the DIY/Coding section of this forum...
04-16-2016, 09:12 AM | #7 | |
Member
458
Rep 1,517
Also link to where you got he filter?
Previous: 2013 135i Space Grey w/Coral Red | 6 Speed MT | M Pkg | JB4 | AA Downpipes | AA Exhaust |
Previous: 2015 M3, BSM[/SO/CF | DCT | Adaptive M | 19" Black | CF Roof | Previous: 2018 M2, AW | DCT | Exec Pkg Current 2020 X7 50i |
04-16-2016, 09:56 AM | #8 |
Member
28
Rep 344
Thanks for the information, I'm planning on a post break-in oil change as well. Is the filter housing left-hand threaded? I see a clockwise rotating arrow on the hex head.
04-16-2016, 10:53 AM | #9 | ||
Rep 210
No castrol logo got the filter from dealer $21.xx, i couldve used a shop discoun but i forgo the number to my buddys shop. and no benefit that i know of except i had 0w-30 laying around |
04-16-2016, 05:53 PM | #10 |
Rep 1,240
Drives: 2016 BMW 340i
I thought the B58 engines required 0W-20?
Although I don't have the sticker under the hood, see this: http://f30.bimmerpost.com/forums/sho...91&postcount=4
2016 BMW 340i 688 | LCL5 | 4FT | ZMT | ZTP | ZDA | ZLP | 494 Formula One Pinnacle 30 Tint | Brushed Aluminum Pedals |
04-17-2016, 01:13 PM | #11 | ||
Rep 210
04-18-2016, 09:36 PM | #12 |
Rep 3,064
how in the hell did you get the oil filter out? Did you remove a bunch of stuff?
Way more complicated than the N55 which was integrated into the oil cooler. |
04-19-2016, 10:25 AM | #13 |
Rep 210
i just used a 32mm socket and a fine tooth ratcheting wrench, and also it helps to move the wire above it out of the way, i did that so i dont get oil everywhere, i try to keep a clean engine bay. And i guess i got used to working with tight spaces coming from a e46 whose ccv went bad more than once, ive done my fair share of tight spaces and taking my arm out with a bunch of dirty oily cuts
04-19-2016, 11:26 AM | #14 | |
Rep 40
Drives: 2022 BMW 230i M Sport
Engine Cover Does the engine cover simply pop off by detaching it from those attachment points that look like pawns on a chess board? Or are there screws near the firewall / cabin air filter area that I'm not seeing (like some of the older ones have)? Do you recommend any particular technique in removing the cover? Are there any hoses or wires attached to the underside of the engine cover that I need to worry about when removing it? Filter Housing Access Is removal of the engine cover the only "disassembly" necessary to gain access to the filter housing? Did you need to use a ratchet with a rotating head or socket extension with a wobble function, etc...? In looking at my engine bay, I'm having a hard time believing I'll be able to get my hand in and out of the area between the engine and that fuse box -- with or without the filter. I'm sorry to bombard you with so many questions, but it appears you are the first individual in the world to post a "how to" DIY oil change thread for the 340i, and I don't want to wreck anything on my wife's new car when doing the first mid-interval oil change. Thank you! Last edited by MateoTorgy; 04-19-2016 at 02:46 PM.. |
04-19-2016, 05:55 PM | #15 | |
Rep 3,064
I ordered a shorty 32mm oil filter socket from ecs and plan to use a swivel and extension to remove. The rest of the oil change process is standard BMW :-) |
04-19-2016, 08:16 PM | #16 | |
Rep 5,088
04-20-2016, 01:31 AM | #17 | |
Rep 3,870
Step 2 should be after step 4
Leaving satisfied!
04-20-2016, 04:12 AM | #18 |
Rep 441
On what logical premise did BMW put the oil fill orifice towards the back of the engine and the oil filter housing buried to the side at the back as well? I thought the N55 locations are just clever, but not so the B58.
EBII 335i Touring M-Sport (Munich built July 2013)
| 6 Speed Manual | 2VF Adaptive M Suspension | 2VL Variable Sports Steering | 403M wheels | M-Sport brakes | 688 Harman Kardon | 494 Heated Seats | 610 HUD | 322 Comfort Access | 5AC High-Beam Assist | 609 Navigation Professional | |
04-20-2016, 06:47 AM | #19 |
Rep 3,870
To make our life more difficult and discourage any of our attempts at self reliance...
They want to remove any ounce of satisfaction that we may get from working and twinkling on our/their cars |
04-20-2016, 08:17 AM | #20 |
Rep 40
The camera was positioned between the fuse box and engine, with a close-up shot. It doesn't afford the perspective to understand that limited space. In looking at my wife's 340i, I can imagine accessing the filter housing cover with a rotating ratchet with a wobble socket extension, but I don't see how it's possible to fit a hand and arm through that space to remove an eight-inch-long filter. I'm thinking the service techs will remove the cabin air filter partition and access it from against the firewall and not between those hoses, fuse box, and engine.
m3roman2.00 |
04-20-2016, 08:33 AM | #21 |
Rep 40
Shortly after buying the car, I made the mistake of registering at Bimmerfest and having the audacity of posting a question about DIY mid-interval oil changes. The posers had a meltdown over the mere suggestion of DIY maintenance. "Why would you change your oil within 10,000 miles?" "Why would you do something like that yourself?" It was crazy. Many posts about after-market window tint (installed at a shop of course), favorite BMW color, after-market lights (installed at a shop of course), etc etc etc... I don't care if modern oil is created by the hand of God Himself. I'm performing mid-interval changes within the 50,000-mile service period and every 5,000 miles thereafter. That's why I'm a little disappointed and frustrated with BMW's engineers for locating the filter housing in the ass crack and under air hoses and a fuse box.
DrGadget46.00 |
04-20-2016, 07:57 PM | #22 | |
Rep 3,064
