BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > F30/F32/F33 Classifieds (For Sale / Trade / Wanted) > Members Classifieds > Electronics: Audio / Video / Phone / Alarm / Navigation / Radar > ~F36 GranCoupe Custom Sub Enclosure~
European Auto Source (EAS)
      04-15-2016, 06:50 PM   #1
Titan 3
Titan 3's Avatar
93
Drives: E46 325ci ~ F36 428ix
BIMMERPOST / Classifieds
Asking Price:
USD 400.00
Shipping Costs Included
✓ Will Ship
Item Interest
I made one of these for my GC, and thought I'd see if anyone else would be interested in one? I can make them to fit either a 10" or 12" sub and as you can see in the photos, the dyed carpet is a VERY close match to stock. It takes me about a week to put one together, so if your interested, it'll require a small amount of patience to receive.
This sits right over your battery and friction fits into place. I'll test fit it in my own car before shipping to ensure a precise fitment.
Thanks!
Mike
      04-15-2016, 07:43 PM   #2
Maximus_GC
Drives: 2016 428i GC
What are they made out of? Is there enough room to fit a 10" JL Audio woofer? Where are you located? Thanks.
      04-15-2016, 09:23 PM   #3
Titan 3
Titan 3's Avatar
93
The one in my car currently was made to fit a JL 10w6, so that's no problem at all. If it's a w7, it'll need more volume/deeper, but I'm sure I could make it work.
The enclosure is three layers of fiberglass with a lathe cut 3/4" mdf ring. They are also countersunk so the speaker face sits flush with the carpeted surface.
I'm located in Nashville, TN, so I assume there will be shipping involved. These aren't terribly heavy so costs shouldn't be very high.
Here's another pic from a more extreme angle. You can see that the sub is flush with the enclosure better from here.
Thanks,
Mike
      04-15-2016, 09:35 PM   #4
Maximus_GC
That looks great! I would like to add the JL W6 but im unsure what else I would need to make it work. I assume I would need an amp as well. Any recommendations? I would like to run my stock speakers for now with the sub but later on down the road, I would replace them. What would be the easiest solution to run a W6 with your sub enclosure? Thanks.
      04-15-2016, 09:57 PM   #5
Titan 3
Titan 3's Avatar
93
Youll need an amp, an LOC (line out converter) and ideally a harness. There is a forum member who sells custom harnesses for our cars that plug directly into the HK amp and add a set of pigtails. Very clean install with no cutting. There are some junk LOC's out there that will get the job done, but people have complained about them burning up. I personally like the Audio Control devices. I use an LC6i, but that's because I already had one laying around. I believe AC now makes an LC2 (2 channel instead of 6) which is all you'll need.
As far as amps go, Something with a small footprint is ideal. I've used an Alpine PDX 1.600, which is a digital amp that doesn't produce much heat. Pretty solid piece too. I'm currently using a old school Nakamichi piece, but that's just because I'm a sucker for OG Nak equipment.
That was a long answer... Amp, Harness, LOC.
      04-15-2016, 10:32 PM   #6
Maximus_GC
Awesome! Let me do a little more research. I think I'm going to go for it. I can give you a definite answer by Sun. Can you let me know where I should buy the JL W6 and the amp? What do you think about JL amps? I haven't had a "system" for over 2 decades. I used to run Alpine decks (7909), Orion amps and subs. I'm jonesing for some more bass in this car!
      04-15-2016, 10:43 PM   #7
Maximus_GC
Does the BMW type harness from the forum member work on the regular hi fi system? I don't have the HK upgrade.
      04-15-2016, 10:58 PM   #8
Titan 3
Titan 3's Avatar
93
He does... It looks like he's in the middle of creating a webpage too. I'd try contacting him her to place an order:
http://technicpnp.com/
      04-15-2016, 11:23 PM   #9
Maximus_GC
Ok perfect! Could you tell me which 10" JLw6 would be an ideal match for your enclosure?
      04-16-2016, 02:05 AM   #10
Maximus_GC
Would this sub work? http://www.amazon.com/10W6v3-D4-Audi.../dp/B00BWCTYN4
I read that its optimal enclosure size is 0.55 cu ft. Is your enclosure that size? If so, sign me up!
      04-16-2016, 03:21 AM   #11
Maximus_GC
So here is my final list. Can you please let me know if this is all I need? Thanks!
1. JL Audio 10W6v2-D4 http://www.amazon.com/10W6v3-D4-Audi...A1OQ0HQZ5A5YEQ
2. AudioControl LC2I http://www.amazon.com/AudioControl-2.../dp/B004CTBYGE
3. Alpine PDX-M6 http://www.amazon.com/Alpine-PDX-M6-...lpine+mono+amp
4. Technic's harness
5. Subwoofer enclosure
2016 428i MG MSport GC w/Premium, Tech, and PDC.
      04-16-2016, 03:53 AM   #12
Maximus_GC
Just thought of something. If I decide to upgrade my speakers in the future but add the sub now, would it be more cost effective if I went for a 6 or 8 channel amp instead of the 2 channel Alpine amp? I'd probably go with the JL Audio XD600/6v2 or the JL XD800/8v2. Would this amp be sufficient to drive my stock speakers and a JL 10w6? Thanks!
      04-16-2016, 12:18 PM   #13
Titan 3
Titan 3's Avatar
93
I'm guessing you don't have private message privileges yet. As soon as you do, let's take this to PM.
I'd say it depends on your realistic timeline. Check with Technic and find out what his harnesses can accomplish. If he has one that covers a full speaker replacement, I'd invest in that now, but you might be surprised how much better the stock setup sounds just by adding a bit of low end to it.
If it'll be awhile, or you're unsure about speaker replacement, maybe just consider a dedicated sub amp for now. You can always add to it or sell it for a 5 or 6 channel replacement. One of the things I like about the PDX amps is that they are stackable, and fit really nicely in the cubby under the trunk floor.
Lastly, you'll likely find that if Technic makes a harness to replace the front speakers, it may not replace the rears. Rear speakers can often be left for fill (rear passenger experience) and just run off of the factory amp. If you do an amplified replacement, it'll likely be under-seat subs ideally band-passed as mid-bass drivers, and front door mids/tweets. That'll consume 4 channels.
      04-16-2016, 12:25 PM   #14
Titan 3
Titan 3's Avatar
93
10w6v3 would be a pretty great option for you. I have to build these by hand, so I can adjust internal volume accordingly. a bit over 1/4 a cubic foot seems pretty ideal to keep the enclosure from protruding into the cargo space tho.
If you are committed to one, please send me your zip and I'll get a final price with shipping for you, and a paypal address to make payment to.
Thanks again,
Mike
      04-16-2016, 04:57 PM   #15
Maximus_GC
Can't wait to get it! Thanks for all your help!
      04-24-2016, 11:39 AM   #16
EBM4
Drives: 2015 BMW M4
Titan would you have access to an M4 so you could build a box for me like this? I would be willing to pay the $300 and am planning on running a 10W6 also.
Thx
      05-12-2016, 07:27 PM   #17
Maximus_GC
I would just like to add that Mike is one of the most helpful members I've ever done business with. I plan on posting a full write up on his fantastic sub enclosure and even more amazing customer service. Until then, here are a couple pics that I just took. Let's just say it sounds unreal and looks like it could have came from BMW as a factory option!
      07-05-2016, 01:10 PM   #18
naiza3k
Drives: 2013 M5 & 2015 X5
Do the F36 GC have the same trunk layout as the F32 4series? I have a 435i coupe and would be interested.
      07-06-2016, 01:11 PM   #19
Titan 3
Titan 3's Avatar
93
PM sent! ??
      09-30-2016, 11:05 PM   #20
sam01
Drives: X5 50i
Ditto on the interest but for 435i X Drive.
Thanks!
      07-14-2017, 06:58 PM   #21
devil84
Drives: F36 430D X Drive
is this still available?
      06-18-2018, 02:04 PM   #22
Jorge101
Drives: BMW 428I M series
Interested
Mike I am interested in the enclosure for my 428I Gran Coupe. 10", are you still doing these?
