| 05-06-2016, 05:09 PM | #1 |
Rep 501
Fault Code-Help!!!
I am having problems with fault codes that I believe have to do with the 02 sensor. Car has no power and drivetrain malfunctions regularly.
Codes are: 1B5202 terminal-electrical short circuit to ground or open ci 12B302-Lamba probe heating after catalyst activation short circuit to ground 12B102- same thing but before catalyst Any experience with this? I have installed the following: -Wagner downpipe and FMIC -BMS JB4 and intake -ER charge pipe Thanks!!!
Sunset Orange G20 M340i
PAST F80 LCI/M3/AW FBO BM3 Cary Tuned Meth/Pure Stage 2 F36 CB 435i FBO F15 GS X5 50i Tune F10 AW 550i Loaded/Tune/M5 Exhaust |
| 05-09-2016, 03:26 PM | #2 |
![]() ![]() 2027
Rep 7,144
Drives: 23 G42 M240, 22 G01 X3 30i
Correct - your downpipe probably has no catalytic converter. JB4 should take care of faking the 02 sensor readings, but I'm not sure how to activate that. Could be one of the connectors to the 02 sensors is shorted out as well, or one of the sensors itself is damaged somehow.
2023 G42 ///M240i Coupe 8AT Portimao Blue, 2022 X3 sDrive30i 8AT Brooklyn Grey
| 05-10-2016, 12:14 AM | #3 | |
Rep 501
Still trying to figure it out.
| 05-23-2016, 11:00 PM | #4 |
Rep 501
Any other feedback. These codes are still coming up and not having much luck.
| 05-23-2016, 11:44 PM | #5 |
2JZ-GTE
3565
Rep 4,490
Sounds like it's related to the downpipe.
And some people say you can buy high-end downpipe and not get engine fault codes. |
| 05-24-2016, 08:45 AM | #6 |
Rep 493
That's an actual sensor issue, not a efficiency code which you will get from carless downpipes. The first one is to ambiguous but the second ones mean either bad connections or damaged sensors. Every O2 sensor has a heating element built in which is needed to give you accurate reading when you first start the vehicle. That is part having an issue.
Did you disconnect the sensors from the harness during install? |
| 05-24-2016, 09:41 AM | #7 | |
Rep 501
| 05-25-2016, 03:06 PM | #8 | |
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
These errors are not related to the downpipe, it's either the sensor and it's wiring or improper installation which could damage the sensor. There's nothing wrong with the downpipe.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
| 05-25-2016, 03:09 PM | #9 | ||
Rep 902
| 05-25-2016, 08:19 PM | #10 | |||
Rep 501
I posted this after replacing the sensor actually.
| 05-25-2016, 11:46 PM | #11 | ||||
Rep 902
| 05-26-2016, 01:20 AM | #12 | |||||
Rep 501
I appreciate any diagnosis and remedial work recomendations sir!!! ?
| 05-26-2016, 01:22 AM | #13 | |||||
Rep 501
| 05-26-2016, 03:29 PM | #14 | |
Rep 902
The 2 O2 sensor faults are most likely related to the first fault based on the info I found. Hopefully it's just a fuse, that'd be the easiest solution, but I'm giving you all the info for a full diagnosis. Code:
Code 1B5202 Fault Description Diagnosis monitors the voltage supply line of terminals 15 N_1 and KL87_1 for open circuit and short to ground. Malfunction monitoring conditions The fault is detected when no voltage is applied at the DME input (KL87_1 or 15 N_1) despite the main relay being enabled. Action in Service - Check voltage supply and integrated supply module. - Wiring harness between DME and main relay - Replace Digital Motor Electronics main relay or power distribution box or integrated supply module. -Check lines and plug connections between the following components: - Engine control unit and Digital Motor Electronics main relay Code 12B302 Fault Description Diagnosis monitors the messages of the internal output stage diagnosis. The fault is detected by self-diagnosis. Possible cause of fault: - Wiring harness of oxygen sensor after catalytic converter defective - Oxygen sensor after catalytic converter defective - DME defective Action in Service --Consequential fault if additional faults from the relay for sensor/actuator supply or from terminal 15N_1 are present. Correct these faults first. Check lines and plug connections between the following components: - Integrated supply module. - DME. Check fuse, replace if necessary. - Eliminate secondary faults, faults for the following components/functions: -Check terminal 15 N_1 lines and plug connections between following components: DME Oxygen Sensor before catalytic converter - Check wiring harness of oxygen sensor after catalytic converter - Replace oxygen sensor after catalytic converter ( Do not allow plug connection to come into contact with cleaning agents or solvents, oxygen sensor can be destroyed) (The internal resistance of the oxygen sensor heater can be measured when disconnected/removed. A resistance greater than 1000 ohms can be measured between pin 1 (+12 V) and pin 2 (GND) in the event of a fault and when the sensor is cold (less than 50 °C). ) - Replace DME Code 12B102 Fault Description The diagnosis monitors activation of heating at the oxygen sensor before catalytic converter. Malfunction monitoring conditions The fault is detected when there is a short circuit to ground. Action in Service Consequential fault, rectify faults relating to the following components or functions: -- Terminal 15N_1 Consequential fault if additional faults from the relay for sensor/actuator supply are present. Correct these faults first. Check lines and plug connections between the following components: -- Integrated supply module. -- DME. Check fuse, replace if necessary. - Eliminate secondary faults, faults for the following components/functions: Check terminal 15 N_1 lines and plug connections between following components: DME Oxygen sensor before catalytic converter - Check oxygen sensor before catalytic converter (The internal resistance of the oxygen sensor heater can be measured when disconnected/removed. A resistance greater than 1000 ohm can be measured between pin 4 (+12 V) and pin 3 (ground) in the event of a fault and when the sensor is cold (less than 50°C). Do not allow plug connection to come into contact with cleaning agents or solvents, oxygen sensor can be destroyed) - Renew oxygen sensor before catalytic converter Also what does your JB4 read as AFR at idle?
| 05-27-2016, 01:54 AM | #15 | ||
Rep 501
AFR's are 16.9 at idle.
| 05-27-2016, 05:20 PM | #16 | |||
Rep 902
| 05-27-2016, 10:27 PM | #17 | ||||
Rep 501
I have run several logs and it is undetectable under load. It idles like crap right now.
| 05-29-2016, 12:52 AM | #18 | |||
Rep 501
| 05-29-2016, 03:02 AM | #19 | ||||
Rep 902
| 05-29-2016, 03:22 PM | #20 |
Rep 501
Thanks man!! I really appreciate.
I pulled every fuse and inspected already.
| 05-29-2016, 03:40 PM | #21 | |
Rep 116,288
Posts ![]() |
Sounds like he blew a fuse or damage the o2 sensor wiring doing the downpipe install. Mike |
| 05-29-2016, 04:17 PM | #22 | |
![]() ![]() 2027
Rep 7,144
| Bookmarks |
