BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
328i n52 anything besides 3IM & headers?
05-30-2016, 04:34 PM | #1 |
Rep 657
It seems like the two best upgrades to this engine without dropping 5K are these two mods.
My question is.....is there anything else to do to this engine to see HP gains for reasonable money? The tune will come once both items are installed. I am planning on AA unless BPC can come up with a way to tune a car in AZ while they are in SC. Since ESS is local to me I might consider them for a tune but I really haven't heard much about what they have to offer. |
05-30-2016, 04:55 PM | #2 |
Mike: Everyone's Pal
2045
Rep 2,972
Drives: F80 M3
sounds like you hit the nail on the head
[CENTER]
2021 6.2L Trail Boss, 6" BDS lift, Chevy Performance intake, 35" Nitto Grapplers, 20" Fuel wheels |
05-30-2016, 05:00 PM | #3 |
Rep 657
Has there been any better tune offered than AA's? I am leaning towards them 80% because I know they have had it for a while and I haven't heard of anyones car blowing up. I want the best of both worlds performance/reliability.
Any word on ESS and their tune? I have been reading all the dyno and shop specific threads and really can't tell if they are worth the extra few hundred. |
05-30-2016, 05:10 PM | #4 | |
2045
Rep 2,972
Drives: F80 M3
[CENTER]
05-30-2016, 05:16 PM | #5 | |
Rep 657
So now the golden question.... That I assume the answer is no but I have heard conflicting answers. Will the disa valves be active before the tune? I know our cars are run by computers but I just can't understand how the ECU would know to start using disa's without being told to. Especially on a car that shouldn't be programmed for them in the first place. |
05-30-2016, 05:17 PM | #6 | |
2045
Rep 2,972
Drives: F80 M3
[CENTER]
05-30-2016, 05:57 PM | #9 |
Rep 2,293
There isn't much besides headers, tune , 3 stage intake
Maybe charcoal delete, air intaker ( k and n , or any other) , pe exhaust , they may add some power but you probably won't even notice If you go ESS forget about headers as they believe headers make you loose power , even though it has been dyno proven to gain powers. Very few people have their tune and they seem to be happy . Most here are running AA tune and I believe most of us are happy with it Next route would be supercharger , but to be honest with you , I m not sold on the supercharger. For starters is not making more power than a stock 335 and the tuning is questionable . It seems to much of a headache |
05-30-2016, 06:01 PM | #10 |
Rep 1,286
If you are considering headers at all, I would go with the AA tune and the 3im first, then if you do get the catless headers the updated tune to support the headers is fairly inexpensive from what I recall. The ESS tune will not support catless headers so if you go that direction, catless headers will be out of the question, unless you pay for a complete new tune from AA. AFE catted headers are an option but buyer beware, after one year and two track days, I fried one of the cats and had to have the stock exhaust manifolds reinstalled.
2012 Jet Black 328i Coupe / ESS Tuning Gen. 2 Supercharger / Evolution Racewerks Oil Cooler / BMS Oil Catch Can / BMW Performance Exhaust with Dinan Y Pipe / Eibach Pro Kit Springs / Koni FSD Shocks / MFactory LSD & Differential Bushings / Performance Rear Trailing Arms / BMW Performance Strut Brace / Stop Tech Slotted Rotors / Hawk HPS 5.0 / SS Brake Lines / Brass Guide Pins / M3 Front Control Arms, 28 MM FSB, Engine Cowl, and DCT Paddle Shifters / Michelin PSS / APEX ARC-8
05-30-2016, 06:05 PM | #11 | |
Rep 657
I like a noisy car as much as the next guy but it needs to be car appropriate and a 328i should not be loud. M2/3/4 should be crackin' and poppin' not a 328. |
05-30-2016, 06:07 PM | #12 | |
Rep 657
05-30-2016, 06:17 PM | #13 |
Rep 1,286
Yes, Parts Score can do the AA tune, in fact, they are the ones who will be installing the ESS supercharger on my car. And with respect to the ESS supercharger, the latest dialogue you've read, the owner of that car had AA headers installed and ESS tried to tune for the the headers without success. The tunes ESS had been sending him to fix the bog did not work because his MAF has been covered in oil. The Gen2 supercharger comes with larger fuel injectors and ESS has sold many of these kits around the world, which is why they are currently on back order. Also, I will be reinstalling the stock tune prior to the supercharger install so ESS does not have to overwrite the AA tune.
05-30-2016, 06:24 PM | #14 | |
Rep 657
Are you getting your headers removed when you get the SC since you are getting a ESS tune or just going to clean your MAF? |
05-30-2016, 06:39 PM | #15 | |
Rep 1,286
As for cooling Parts Score installed an Evolution Racewerks oil cooler. To keep the MAF clean, I'm also having a BMS oil catch can installed.
05-30-2016, 06:44 PM | #16 |
Rep 657
Are you going with an aftermarket header setup or staying stock?
What causes the MAF to get oil on it in the first place? What is the labor/hour charge at parts score? |
05-30-2016, 07:06 PM | #17 | |
Rep 1,286
Either too much oil on the K&N air filter or crankcase blow by, but more than likely crankcase blow by. $95 per hour.
05-30-2016, 07:15 PM | #18 | |
Rep 2,293
Furthermore , it is not the first time a car is not running well with the ess supercharger, I recall reading a few members with that kit also having issues related to the tuning . Im not saying the kit is bad , but its hard to justify paying over 5k for a kit that does not ran well and it gives so many headaches, reliability is still suspect and it does not produce more power than a stock 335 ... To each its own , personally I would not get the kit unless I was driving a wagon or something I put a lot of money into it ( m3 conversion or something like that) |
05-30-2016, 07:23 PM | #19 | |
Rep 2,293
the pe exhaust is not too loud , neither is the k and n filter. Again the n52 is not a platform to go crazy. Once you realized that then you are going to be more open to small mods, sure they don't make much power but it all adds up at the end of the day. Unfortunately with the n52 you need every little mod to make some type of power From experience I can tell you that headers work well with k and n filter, the power delivery and response is a lot better. I m suspecting with PE exhaust it would even be better. It may not show in the dyno as much but on the street you definitely feel a more responsive car. At the end of the day I want my car to feel quick because I m not winning any races again the bigger boys ( STI's , 335 , IS350, G37, mustangs, camaro's , Golf R, etc ,etc ,etc)... At least I can beat a civic SI now |
05-30-2016, 10:28 PM | #20 | |
Rep 657
05-30-2016, 10:36 PM | #21 |
Rep 9,004
Don't do any of the BMW Performance mods for power, you're better off with the Super Sprint section 2, headers (brand of choice) and a good muffler (Stock and PE is very restrictive.
I know the AFE Si makes power, as does the Dinan+ silicone elbow/carbon delete. As for tunes...AA AND BPC are solid choices, I chose BPC because of the ALFA N option, as well as potential for 'upgrades' in the future. Regardless BPC is a AA dealer, and they do stock AA tunes, so you talk to them regardless. |
05-30-2016, 10:45 PM | #22 | |
Rep 657
BPC is a little out of the way for me so I think I'm sticking with AA for now unless they figure out a cross country tune. When you say Dinan+ elbow are you talking about the Rev Motoring elbow equillevent? I already did carbon delete and am thinking about this. What about scoops in the kidneys.....are they really only good for a slight boost at higher speeds on our cars? Not worth it. |
