06-08-2016, 05:50 PM | #1 |
Rep 55
340i JB4 warranty/dealership experiences?
I understand that many of you swap out your JB4 when taking your 340i to the dealer.
Have you heard any stories about the dealerships knowing about JB4 installs, even when they are removed, and causing warranty issues? |
06-08-2016, 06:06 PM | #2 |
Rep 115,980
06-08-2016, 06:18 PM | #3 |
Rep 3,211
If I were BMW I'd track any anomalous outputs to the engine outside of norms ..
from their pov this is like overclocking a chip.. do at your own risk warranty no more I dont see why they havent done that.. saves them money in the longrun y saving on warranty for guys who stress the engines .. OR HAVE THEY ... da-dun.. (eyes back and forth) |
06-08-2016, 06:22 PM | #4 | |
Rep 115,980
Mike |
06-09-2016, 02:35 AM | #5 |
2JZ-GTE
3046
Rep 3,997
i think it lies to the ECU and the ECU doesn't know what it doesn't see.
06-14-2016, 09:43 AM | #9 |
Pace Car Driver
1548
Rep 3,164
I heard the JB4 actually calls the dealership.
Lionel_24k7.00 Bigsean71452.50 Polo088161610.00 Tlongo277.00 BimmerNugget542.50 B58togo808.50 srvrdhn0.00 TyStacksz0.00 JerMe40414.00 |
06-14-2016, 10:23 AM | #10 |
Rep 3,622
Don't know man, the only way to guarantee there will be no issues is to not do JB4. I have to say it's a compelling package but not worth it IMO.
BMW CCA Member #516012
Polo088161610.00 |
06-14-2016, 01:53 PM | #13 |
Rep 5,776
My car was at the dealer last week for brakes and oil change and they also did a full inspection for any codes, leaks or other warranty items. Left my jb4 in the car as well as DP. Put it on map 0 and hid the obd cable. They said everything looked great.
06-14-2016, 03:16 PM | #14 |
Rep 149
Thanks for the info. Does map 0 take out the cel light from DP?
06-14-2016, 03:43 PM | #15 | |
Rep 584
I'm not one of those rabidly anti-JB4 guys that exist on this board, but I strongly believe that you should go into this eyes wide open. You have to pay to play, so only go this route if you are financially prepared for the risk of having your warranty voided. This is coming from someone who has chipped multiple cars in the past, but is probably going to go the MPPSK route for my 340i because the engine is new. |
06-14-2016, 04:39 PM | #16 | ||
Rep 5,776
Last car: 2011 335i Msport. JB4. Vrsf CP |
06-15-2016, 08:58 AM | #17 |
Rep 548
Drives: 2011 E90 M3 ZCP
I know the catless DP will cause a CEL but the JB4 clears it automatically. The only outlying problem from that is the readiness monitors will never clear (meaning you will have issues getting an inspection, at least in my state of NY).
06-15-2016, 09:59 AM | #18 |
Rep 1,649
Funny you should ask. My car was at my dealership for a few days. I told them it was running funny (idling). Plus since my warranty was almost expired, had them do some maintenance items. My initial thinking was a coil or injector type issue like everyone else has had. I kept JB4 installed on Map 0,plus my Intake, CP and IC are clearly evident. Tech of course found it, ran some tests, uninstalled JB4, drove it and attributed the JB4 as the culprit. They cleared the faults, etc...long story short.... no big deal. Some SA and Techs are very cool about the JB4 as they all pretty much know about and can figure it out quickly. I guess the thing to know is if they can prove JB4 blew up your engine, turbo's etc. they will have to void the warranty. It has to be a major issue and they have to prove it without a shadow of a doubt. But there is Magnusson act, etc. people have mentioned. Most say uninstall before you go in which I would recommend if you don't have a cool SA and TECH.
06-15-2016, 10:22 AM | #19 | |
Rep 548
06-15-2016, 10:24 AM | #20 |
Rep 1,649
06-15-2016, 12:12 PM | #21 | |
Rep 115,980
Mike |
06-15-2016, 12:31 PM | #22 |
Rep 149
