BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Help regarding MAF - Continental/Siemens VDO branding
06-11-2016, 07:44 AM | #1 |
Rep 210
Drives: F30 320iA M Sport
Hello bmw enthusiasts,
I am currently suspecting my maf for rough starts, surges and a bit of a rough idle. I have cleaned it and it has shown improvement but the symptoms re-appeared, i wanted to know from what year did Continental started branding the Siemens VDO mafs and if you can tell from this picture if this is the car's factory MAF, i see -06 after the code(which is my car's production date) but i know that the original factory MAFS had Siemens VDO written on them and later came with Continental branding. CLIFFS: Can someone tell if this is the car's factory maf or do you think it was changed over the course of those 10 years.
Bmw e46 320d '04 - Sold
Bmw e46 330ci '01 - Sold Bmw 3-er e90 325i '06 - Sold Bmw 3-er e92 325xi '08 - Sold |
06-12-2016, 06:27 AM | #2 |
Rep 452
Seems to be the stock one as new ones after 2009 are 13627551638 and 13627585680. I got one spare from 2010 car with 38x km if you need send me a pm we can deal something
06-13-2016, 08:48 AM | #3 |
Rep 210
Thanks, pm'd.
06-13-2016, 03:29 PM | #4 |
Rep 1,834
Drives: '05 E90 330i Manual
Check on RealOEM with your car's VIN number.
06-20-2016, 05:31 AM | #5 |
Rep 210
On realoem it appears with the code shown on the above pic, it means it's the stock factory one, correct?
06-20-2016, 12:51 PM | #6 |
Rep 1,834
It should be fine then. I also replaced my MAF about a year or so ago (was a gamble to solve what I am experiencing) and it was also a Continental branded - it's the same company and it seems that the branding changed from VDO, to VDO-Siemens, to Continental as far I remember reading back then. An ECU specialist that I took my car to was very quick to turn his nose up when I told him that I fitted this part, saying that it's not a "genuine" BMW part, but then later on admitted that it was working properly and giving the ECU the correct values.
06-21-2016, 03:19 PM | #7 |
just another bmw douche bag
195
Rep 3,640
That looks like the stock one that came on my '06 325i. I recently replaced it with the VDO/Siemens part and everything works fine.
06-21-2016, 06:22 PM | #8 |
Rep 210
I also just replaced it and the car shakes on start-up. Does it need time to settle in with the new values or do i need to write it in the car's ECU/program it?
06-21-2016, 07:45 PM | #9 |
Rep 1,834
Mine didn't shake or do anything unusual, but it is best to reset adaptations when fitting a new MAF. Disconnect the car's battery for half an hour, that should clear the adaptations.
06-22-2016, 07:33 AM | #10 |
Rep 210
Gotcha, now it drives like a true 6 cylinder. I'm happy the problem went away but going through coils, plugs, injectors, solenoids.... no regrets
06-22-2016, 07:35 PM | #11 |
Rep 1,834
It's a lot of costly parts to replace! But I hope she continues to behave now!!!
