BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coolant Drain DIY - F30 335i
      06-29-2016, 12:40 AM   #1
humbertob
humbertob's Avatar
Drives: '14 F10 535i MSport
Exclamation Coolant Drain DIY - F30 335i
Well today I just replaced the brownish coolant on my F30, here are the steps, could help someone, I hope:
1. Place your car securely on ramps
2. Remove the engine under cover, you need to remove all the 8mm bolts holding it in place
3. Remove the 8mm bolt holding the overflow tank, then unlock the 2 tabs holding the overflow tank in place
4. disconnect the upper coolant line from the overflow tank
5. disconnect the coolant level sensor below the overflow tank
6. disconnect the lower coolant line from the overflow tank
7. After you remove the upper and lower coolant lines the coolant will start to drain so be prepared with a bin to catch the old coolant
8. Remove the overflow tank completely and at this time rinse the overflow tank using the garden hose to clean the overflow tank from old coolant and sediments
9. Go back under the engine and unbolt the water pump clamp, be prepared with a bin or recipient under the engine, masive coolant amount will drain at this time
10. release the coolant hose from the water pump (coolant will drain)
11. after all the coolant is gone, replace the clamp using the attached bolt
12. Replace the under engine cover and all the 8mm bolts that hold it in place
13. Re-attach the lower coolant line to the overflow tank
14. Re-connect the coolant level sensor to the overflow tank
15. Re-attach the upper coolant line to the overflow tank
16. Replace the bolt that holds the overflow tank in place (8mm bolt)
17. Remove the bleeding screw (black screw) from the overflow tank
18. Using 50/50 BMW Blue Coolant/Distilled Water fill the overflow tank slowly until the coolant starts to escape from the bleeding hole at the overflow tank
19. Re-attach the bleeding screw
20. Replace the overflow tank cap
21. start the ignition on the car, without starting the engine
22. select the hottest temp on the a/c unit
23. select the lowest fan speed on the a/c unit
24. push the accelerator down to the floor for 10 seconds
25. you'll start hearing that the water pump starts working, it's bleeding the coolant system for you
26. Wait for 12-13 minutes until the water pump completes the bleeding cycle
27. You have changed your Coolant on your F30 at this point !
Thanks for all your support !
(OO)-(////)(\\\\)-(OO)
'14 F10 535i M-Sport
'14 F15 X5 | Wife's
'15 F30 335i M-Sport | Son's
'10 Porsche Boxster
      06-29-2016, 08:31 AM   #2
mr_kay
mr_kay's Avatar
123
Drives: F30 335i
Perfect. Thank you. I was looking how to do this for when I do my oil housing gaskets this weekend. Up until this morning I was trying to test to see if the bleeding procedure worked on my car and I couldn't hear anything to confirm if it was running...Good to know I was doing the correct procedure.
      06-29-2016, 08:35 AM   #3
mr_kay
mr_kay's Avatar
123
Drives: F30 335i
Any reason to drain the reservoir tank first and not the water pump connection? Seems like it might be less messy that way.
      06-29-2016, 11:51 AM   #4
humbertob
humbertob's Avatar
Exclamation
"The order of the factors does not alter the product !" The only reason that I first removed the overflow tank was to clean and rinse the tank from sediments and old coolant, but if yours is clean, you can even keep it attached, on my case there were sediments and I did prefer to clean the overflow tank before new coolant was poured.
'14 F15 X5 | Wife's
'10 Porsche Boxster
      06-29-2016, 11:52 AM   #5
mr_kay
mr_kay's Avatar
123
Drives: F30 335i
Gotcha. Thanks!
      07-31-2017, 11:05 PM   #6
rugbyfool89
Drives: F30 335i Sport
Just wanted to say thank you. Pretty cool how the car bleeds itself.
      08-01-2017, 10:09 PM   #7
jdr78569
jdr78569's Avatar
137
Drives: F31 328d sport wag
Do you have picture on how to unclip the lower hose? I stopped at that point since it was getting late and i didn't see how i could unclip it. I know BMW coolant is "lifetime" and mines clean i just wanted to do a drain and fill
      08-04-2017, 11:04 AM   #8
reyoasian
Drives: 340xi MPPSK
What's the spec of the coolant required?
      08-04-2017, 12:03 PM   #9
Sanelko
Sanelko's Avatar
57
Drives: 2012 Jet Black 328i
I think it's BMW N60069.0 (blue in color). Other than the BMW coolant, the only other ones I know of are Pentosin and Rowe.
      08-04-2017, 01:15 PM   #10
_bdiddyb_
Drives: 2013 335i
It was a bitch to unclip the hose from the water pump to drain the coolant. What ever happened to the drain plug at the bottom of the radiator??? C'mon BMW !!! Bleeding procedure was very smart.
On another car maker, the Lexus IS350 was completely opposite. Draining was a cinch, but bleeding procedure was asinine.
      08-15-2017, 08:56 PM   #11
vifferfun
Drives: 2012 BMW 335i Sedan 6MT
Thanks so much for posting these instructions! I just had to bleed my system (after replacing a blown coolant hose) so I just had to complete steps 17+. It was really easy!
      12-17-2017, 10:46 PM   #12
GTBrandon
GTBrandon's Avatar
Drives: 13' M3 Competition
Any idea on how much coolant the system took total? I'm wondering whether to use one or two (or more) Gallons of the BMW coolant after mixing with water
Current:
13' E92 M3 Comp | 04' Yahama Warrior
Past:
14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i |06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL | 85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger
      06-10-2018, 09:16 PM   #13
Busa1
Busa1's Avatar
Drives: 435i xDrive M-Sport
I would like to know this also because I plan on flushing the coolant soon.
      11-11-2018, 08:22 PM   #14
flyt100
Drives: F30 335xi
I just did this today by removing the two hoses on the water pump on my F30 335xi. I used less than 2 gallons of mixed coolant (so one gallon of the BMW full strength coolant was enough)
      04-02-2019, 12:04 PM   #15
M Smurf
M Smurf's Avatar
77
Drives: 2013 328i M Sport
Looking to start doing this myself as well.
So no need for any special tools such as an air-powered refill tool?
      04-02-2019, 12:46 PM   #16
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [0.00]
2014 BMW 328i  [5.00]
Can someone confirm this is the exact same process for N20 engine?
      06-11-2019, 12:12 AM   #17
stroker15
Drives: 2013 328I Sportline
Here's a good video on how to do it. Looks like the same procedure.
ER Catted Downpipe| K&N Drop in Air Filter| FTP Charge Pipes| CSF Intercooler| Bootmod3 Stage 2| Michelin Pilot Sport 4S| Carbon Fiber Trim| 30% Ceramic Tint| Audio Control DM-810 DSP| Audison Bit DMI Digital Interface| Pioneer Amps| Rockford Fosgate T3-BMW1| Earthquake Subs.
sspade1902.50
      06-11-2019, 09:05 AM   #18
pongkin
Drives: f30
bleeding the system where would the air escape since you screw back the bleed screw and cap?
      06-12-2019, 12:02 AM   #19
stroker15
I'm assuming it just pressures up the empty space in the overflow tank. I also bet the cap on the overflow tank isn't air tight.
      07-04-2019, 01:43 AM   #20
stroker15
There is a shop here that you can rent a lift and all their tools for $30 an hour. They have a coolant exchange machine. I'm going to try and do it with the machine, and skip pulling hoses. From what I can tell, the machine sucks out and adds new coolant at the same time, and you just keep going till the coolant coming out into the machine is new coolant. Using the machine is supposed to take 10 minutes. I'll report back next week how that went. If anyone else has tried doing a coolant exchange with the machine, let me know how that went.
Thanks.
      07-04-2019, 01:57 AM   #21
stroker15
Thanks.
Hmm, I just watched a video on how to use the coolant machine, it looks like using the machine may not be possible or may be more of a pain than pulling the hoses. I'll find out when I get to the shop and see how their machine works. If anyone has used a machine to do it, let me know.
      07-12-2019, 11:39 PM   #22
BigJack75
BigJack75's Avatar
Drives: M5 Dream Car
So what about all the old coolant in the motor. Is there a way to flush this out?
diy coolant drain
