07-08-2016, 11:45 AM | #1 |
Rep 3,135
NEW RELEASE: DINANTRONICS Sport (N20/N26)
DINANTRONICS Sport For the BMW 'F' Series N20/N26 Engines Part Number: D440-0010 Applications: 2014-16 F22 228i Coupe, 2015-16 F23 228i Cabrio, 2012-16 F30 328i Sedan, 2014-16 F31 328i Wagon, 2014-16 F34 328i GT, 2014-16 F32 428i Coupe, 2014-16 F33 428i Cabrio, 2015-16 F36 428i GC, 2012-16 F10 528i Sedan, 2012-15 E84 X1 28i SAV, 2013-16 F25 X3 28i SAV, 2015-16 F26 X4 28i SAV, 2012-16 E89 Z4 28i RD Product Page / Pricing: http://www.dinancars.com/product/d44...ries&mid=1182/ Release Date: Today, July 8th, 2016. Description: DINANTRONICS Sport is the boost controller for the masses. Its simple design/execution allows for easy installation/removal that can be performed in a blink of an eye and yields results you will be sure to feel, and enjoy, from the get go. Coupled with Bluetooth capabilities right out of the box that allows for user controlled adjustability and a live boost monitor to keep track of the action its a value proposition that is unequaled in the marketplace. DINANTRONICS Sport plugs into a single sensor which lends itself to a very quick and and discrete installation, or removal, should the need arise. Not only does this connection method offer a simplified install but also effectively utilizes the factory DME, in tandem with itself, in order to re-map boost, fueling, and timing for optimal performance. Once installed DINANTRONICS Sport enjoys connectivity to various smartphone devices courtesy of its built-in Bluetooth Smart system. From the free app one has the freedom to reduce stock boost for valet duties or crank up the boost all the way up to the "race" setting for maximum enjoyment... or anywhere in between. Regardless of what setting is chosen there is a power level for everyone. Also within the app the end user has access to a live boost monitor which streams boost data in real time to the phone very similar in appearance to the sport gauges on the iDrive. Not only will you be able to feel the difference but now you can see it as well! Perhaps best of all, the unit automatically detects which engine it is installed upon and loads the appropriate mapping. Effectively making a single unit compatible with an extremely wide range of applications making switching to a new vehicle, sharing with another, or selling the unit a breeze. Benefits of the DINANTRONICS Sport Performance Tuner for BMW N20/26 Engines:
For a full breakdown of the various tuning options within the tiered DINANTRONICS Performance Tuner lineup please visit our comparison page, HERE, to understand which step in the 'evolution of power' is right for you. RACING ONLY: Not legal for sale or use in California. CARB EO submitted and pending. WARRANTY: DINANTRONICS Sport does not carry the factory matching warranty that Dinan is known for. DINANTRONICS Sport's warranty is a 1 year product only warranty that does not cover consequential damages or labor reimbursement. DINANTRONICS Sport Performance Tuner for the BMW N20/N26 Engine POWER CHART Part Number: D440-0010 Retail Price: Consult Website Install Time: 0.25 hrs Max Gains (Sport+ Setting): +30 HP / +50 lb-ft TRQ Please Note: N55 and B46/48 applications were also released today so please consult the appropriate forum for those details or our website. Many more applications coming in the months ahead ranging across the entire gamut of European car brands (Mercedes, VW/Audi, Porsche, Fiat, Alfa Romeo, etc) |
07-08-2016, 12:42 PM | #3 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Impressive...a bit skeptical on the baseline HP numbers of 262rwhp/286wtq however on a 228....but the plug/play aspect and being Dinan is pretty cool. I pulled 228/267 in triple digit heat on 91 octane bone stock but -34 and -19 is a big difference. So was this an N20 or an N26?
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
07-08-2016, 12:48 PM | #5 | |
Rep 3,135
darrenterrence4.00 |
07-08-2016, 12:56 PM | #6 | |
Rep 3,135
Simply put we kept getting requests for a basic, cost effective, no frills version of a tune so this is what was born from those requests. Its a departure from normal Dinan since it will not hold the same warranty but in order to meet the reduced price point its just part of the game. I should note about the sensor aspect that some of the other brands/engines (like Audi) requires the 2 sensors to make any meaningful power however so those kits as we expand to the other Euro brands will be a 2 sensor device so will be slightly more expensive. |
07-08-2016, 01:57 PM | #8 |
Rep 3,135
It works on the N26. Already been tested. The limitation of the N26 is at the top end of the RPM due to its more restrictive CAT's. As you can see from the chart above the gains at the top end are already very minimal so the N26 power loss has very little difference, if any, from the N20 for this particular product.
07-08-2016, 02:57 PM | #10 |
Rep 3,135
It will connect and work but we have not had the opportunity to do any testing specifically for the 320i so we don't know what kind of gains you would ultimately get. We are so backlogged in projects right now I don't foresee us specifically getting to it any time soon I am afraid. As I said though it will physically connect and function though so you are more then welcome to give it a shot.
If you want to do some fit checking, which is what it essentially comes down to, I am sure we can offer a discounted unit for the effort. |
07-08-2016, 03:48 PM | #11 |
Rep 3,258
Makes a difference..thank you for the clarification
25% 3M Tint| |
07-09-2016, 08:49 AM | #12 |
Rep 186
From the looks of it, it seem to be tapping / hijacking the TMAP or MAP sensor?
So without the other connections, does this run a straight +x PSI across all RPM ranges? Dun think there is any way to obtain RPM values thru these 2 ports. The way it behaves is almost similar to the JB Stage 1, but that also took 4 connections - boost solenoid, TMAP, MAP and MAF.
328i
Custom Tune @ 1.5bar | GruppeM Air Intake | Dinan Springs | CF Front Strut Bar | ER Charge Pipes | ER Intercooler | GFB DV+ | AEM Meth Kit Removed: BMS JB4 N20 | ER Downpipe | BMS OCC |
07-09-2016, 10:25 AM | #13 |
Rep 33
hmmm so if it is only one sensor does that mean your only lying to the ecu about the boost? and nothing else. and if that is the case is that not very bad for the engine since its not getting the right air fuel mixture? and have you had a chance to check this out on a catless n26? and can this be detected when i take it to a dealership if i unplug it and take it out.
07-09-2016, 02:21 PM | #14 | ||
Rep 3,135
Like pretty much every other piggyback on the market, fuel, timing, and other variables are being adjusted by the factory DME. To my knowledge the full warrantied DINANTRONICS is the only unit that manages those variables in any other way. We do not do any testing on CATless as it is not emissions legal. It will work fine though. Just have CEL is all. N26/N20 will yields the same gains (with CATs) as the N26 has a more restrictive Cat that hinders performance at the top end. As you can see in the graph above the top end additions are pretty minimal to begin with so the higher squid count on the N26 CAT and its hindrance on power has very little effect on this tune. Any tune can be detected. If anyone tells you otherwise they are lying. While the dealership techs may not have the tools to find evidence of a tune per se it can be determined should a large warranty claim come up by BMW/PUMA. This device dos not hold the typical Dinan warranty and is simply a workmanship and defect 1 year warranty for all intents and puroposes (like everyone else) so it should be treated as such. |
07-09-2016, 10:28 PM | #15 |
Rep 208
Well I was just about to order the BMS, but then I saw this so I went ahead and ordered the Dinantronics. Are the module and wires waterproof? Also, after I install the tune would be necessary that I drive the car for a few miles to let the tune get used to the car before I go hard on the car? Lastly, when do you think the iOS app will be released?
07-10-2016, 12:51 AM | #16 | |
Rep 168
Pm sent
07-10-2016, 03:35 PM | #17 | |
Rep 3,135
There is minimal, if any, adaptation period. I would still start in the lower settings (sport/sport+) and hammer on those before you up it to the race setting but thats more so you can appreciate the differences between the stages and get use to the increased power more then anything. I will refrain from giving an estimate on the iOS app as that bit me the last time around. The first iOS app we did for the full DINANTRONICS took about 3 months to make it to the store with all the random hoops apple seemingly made us go through. Replied. Will get back to you by EOD tomorrow if I don't hear from the other guy. |
07-10-2016, 05:17 PM | #19 | |
Rep 19
07-10-2016, 06:07 PM | #20 | ||
Rep 208
07-10-2016, 06:37 PM | #21 | |
Rep 3,135
http://files.dinancars.com/webresources/datasheets/fe87c3c87395f27075d01be824ea0dc5.pdf Nope. Works on 91 and up just fine but will just have slightly lower gains is all. |
07-10-2016, 06:59 PM | #22 | ||
Rep 208
