BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Messy Vanos Solenoids?
08-06-2016, 11:26 AM | #1 |
Rep 210
Drives: F30 320iA M Sport
Hello Guys,
I've installed two new vanos solenoids a few months ago and i noticed the top bolt doesn't torque well(you can turn it by hand) so i'm guessing that oil vapors are escaping, what can be done about the nut? I tried interchanging them and only the top one is loose, will i need to modify the engine block somehow?
Bmw e46 320d '04 - Sold
Bmw e46 330ci '01 - Sold Bmw 3-er e90 325i '06 - Sold Bmw 3-er e92 325xi '08 - Sold |
08-06-2016, 07:26 PM | #2 |
Rep 1,834
Drives: '05 E90 330i Manual
And you fitted it with a new O-ring seal?
That looks dirty like an old engine that had never been cleaned for such a short period of time. So there must be a fairly significant leak. I would start by cleaning this with a brush and some petrol, or any decent light solvent cleaner. Maybe also clean the electrical connectors for the solenoids to play safe. Do you think the thread is stripped for either bolt or most likely the head where it screws into? These bolts don't really need to be all that tight, just enough to keep the solenoids in place. |
alx.41.00 |
08-07-2016, 04:42 AM | #3 | |
Rep 210
I think this might be causing my rough running as well.
08-07-2016, 08:19 AM | #4 |
Rep 210
Cleaned the connectors with a special circuit cleaner. The solenoid seems to be air tight and you can't remove it by hand easily, the nut though you can turn by hand and remove freely.
Would a helicoil insert fix this?
08-07-2016, 09:09 AM | #5 |
Rep 1,017
HI,I wouldn't go that route yet,don't go drillin just yet,clean the threads with brake cleaner,blow with air,new bolt with pipe dope. The dope will harden enough for the bolt not to back out. You can use a mild loctite if you don't use dope. It's worked for me with aluminum. Hope this helps
alx.41.00 |
08-07-2016, 09:26 AM | #6 |
Rep 18,814
You need to fix this properly. The thread in the cylinderhead is stripped and needs to be repaired correctly. The proper repair is a heilcoil insert. I recommend that you leave it to a professional and take the car to an automotive machine shop to have the helicoil repair made.
The leaks are coming from the oil pressure that is present in the head and the VANOS solenoid needs to be firmly affixed to the cylinderhead.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
08-07-2016, 09:28 AM | #7 | |
Rep 210
08-07-2016, 09:29 AM | #8 | |
Rep 210
08-07-2016, 09:52 AM | #9 |
Rep 18,814
I would think so. The VANOS solenoids control the flow of oil to the VANOS adjusters that control the camshafts. If the solenoid is not sitting firmly in head, the oil is not going to flow correctly. Plus, the situation is only going to get worse to the point where the hole may not be able to be repaired. If you need to go the next bolt size up (M8) there my not be enough material to support a 8MM hole in the head.
alx.41.00 |
08-07-2016, 01:54 PM | #10 | |
Rep 210
08-07-2016, 07:58 PM | #11 |
Rep 1,834
I would also rather have this properly fixed. I have removed and cleaned the solenoids a few times on my car, and only replaced the one O-ring and spacer some years back when the spacer fell off the end of the solenoids when I was removing it - found it months later "hiding" in the cooling fan shroud. Point is, the O-rings are still original for the one, and years old for the other, and the solenoids have been removed a few times for cleaning. But the engine is still spotless with not a trace of oil leaking out. It's not so much about the bolt having to be tight, but it has to keep the solenoids firmly in position. Good luck with the repair!!!
08-08-2016, 05:03 AM | #12 | |
Rep 18,814
Good luck with it.
08-08-2016, 07:38 PM | #13 | |
Rep 1,834
08-10-2016, 05:54 AM | #14 |
Rep 210
Got it fixed, thank you people!
08-10-2016, 10:29 AM | #16 |
Rep 210
Yes sir, also while looking around i noticed that one of the solenoid wires is chewed up? I'm not sure if it was from the heat or if i'm having a rodent problem but i do have some rough idle/stalling/check engine with mass air flow error(i changed the maf with a brand new one weeks ago). Any input?
08-10-2016, 11:56 AM | #17 | |
Rep 3
I've been researching and it seems the m6x1 heli-coil would be compatible with the BMW m6x12-8.8 hex bolt, can you confirm? Also, did you have enough space to do the drilling and tapping without removing any components? Not sure about your rough idle, perhaps scanning for fault codes would narrow down the problem. My rough idle had different causes on two separate occasions. The first was cracked engine valve cover, the second was bad ignition coils. |
08-10-2016, 06:18 PM | #18 |
Rep 1,834
Glad you got this sorted out. Regarding the chewed cable, is it badly chewed such that it may not carry power to the solenoid, or just the insulation is damaged exposing the wires?
08-11-2016, 05:35 AM | #19 | |
Rep 210
Apparently only the cable was chewed, the wires were fine... back to the drawing board.
08-11-2016, 09:19 PM | #20 |
Rep 1,834
That's at least good news - not keen on damaged wires, at least you can cover them with some insulation.
08-14-2016, 11:58 AM | #21 |
Rep 3
Was able to repair after two attempts. The m6-1 threaded insert was a perfect fit. I only removed the engine cover and front air intake so I had to spend a few days to find a compact right angle attachment and a stubby hex base 1/4 inch drill bit to drill out the hole which was the hardest part.
08-14-2016, 02:48 PM | #22 | |
Rep 210
