09-18-2016, 12:58 PM | #1 |
Rep 59
Drivetrain Malfunction and CEL- Possible leak?
Hey guys,
I wanted to see if any of y'all have experienced this before. So yesterday while I was making a U-turn, the engine suddenly bogged down. CEL and drivetrain malfunction didn't come on until about 30 mins later. In the meantime, the car was still drivable. The only thing is, is that when I stepped on it it wouldn't really accelerate. It sounded like a loud exhaust when I did try. Anyways, once I hit traffic lights the engine would turn off on me. When I turn the car on and leave it idling the engine would shake and turn off. I would have to step on it for it not to turn off. So after driving a bit more, the CEL and a drivetrain malfunction message came on. "Drive Moderately. Maximum drivetrain output not available. Consult Service center." I have a code scanner and the codes are below: 102001/Intermittent: Air Mass, plausibility. Air Mass to High. 120308/Permanent: Charging pressure control, plausibility. Pressure too low. 108F01/Permanent: Intake Plenum: Suspicion of leaks between turbo charger and intake valves. As far as mods go, I have the Dinan Stage 2, and a M sport exhaust. Honestly I believe the 102001 has nothing to do with the other codes. Any help would be appreciated! Thanks in advance!! |
09-20-2016, 05:09 PM | #3 |
Rep 191,109
+1
09-21-2016, 08:15 PM | #5 |
Rep 59
Thanks! Right now it's at the dealership and they should let me know tomorrow what the issue is. Given that my New Car/Maintenance warranty expires in 2 months, I'm glad this happened before then. With this being said, since the warranty is about to expire should I be looking into getting an upgraded Charge Pipe since I have the Dinan Stage 2?
09-21-2016, 08:21 PM | #6 | |
Rep 893
2019 SG M5C
2015 SO M3 6MT 2015 BSM M235xi |
09-21-2016, 08:24 PM | #7 | ||
Rep 59
09-21-2016, 08:53 PM | #8 |
Rep 389
Drives: '13 F30 335i MSport
ER is the way to go. Hit up one of the Mikes.
2013 GSM 335i MSport
09-21-2016, 09:51 PM | #9 |
Rep 115,999
09-28-2016, 08:37 PM | #10 |
Rep 45
I had a similar power issue occur today but none of the codes were triggered and vehicle status was "ok" across the board. Power would be fine to 2500ish rpm when it would just cut out. Turned off car, waited 5 minutes to start again and car then ran fine. Though the issue occurred while in Sport mode so I kept in Comfort after restart. Any idea what this could be?
2013 335i xdrive Msport. |
10-06-2016, 10:09 AM | #11 | |
Rep 59
03-15-2018, 02:38 AM | #12 |
Rep 80
03-15-2018, 12:35 PM | #13 | |
Rep 59
If you're talking about the other issue mentioned, the limp mode, I made a separate thread on that issue which was also resolved. Link is below! http://f30.bimmerpost.com/forums/sho....php?t=1443035 |
05-01-2018, 05:19 PM | #14 |
Bimmer Disciple
Rep 19
I just got a Powertrain Malfunction: Maximum power not available etc.
Limp home mode. Got home, waited 10 minutes. Code cleared but engine light is on. Code thrown is P2279. Intake Air leak. What are the chances the two are connected? The first sounds expensive, the second maybe not so much. Any advice from the folks on here? |
02-25-2020, 10:54 AM | #15 | |
Rep 2
Got the same problem and bumping up the thread. An aftermarket charge pipe is used now, and when I go sports mode and the turbo kick in, this error would appear. It usually deletes and doesn't reappear. Looking to get the ER chargepipe to fix this problem. Online order is the best way to go? I'm at cold Michigan! |
