| 09-20-2016, 01:54 PM | #1 |
Rep 74
2016 340 race pads!!
I have a 2016 340i without M sport Brakes, I'm about to start tracking my car and cannot find a single rear "Track" ready pad for the car. Has anyone else had any luck?
| 09-20-2016, 02:09 PM | #3 | |
Rep 74
| 09-20-2016, 02:33 PM | #4 |
Rep 418
Sure about that because for exemple, front rotors on F80 are 380mm, 370mm on 340i and 340mm on 140i. Pads are not even the same on 140i and 340i because of the rotors size.
BMW M5 ZCP and M4 ZCP. BMW 540i G30 stage 2 with KW street confort, Wagner DP, Remus catback, M sport brakes 395mm front and 385mm rear. MHD tune. |
| 09-20-2016, 05:01 PM | #5 |
Rep 4,773
Yes m140i and f8x pads are same shape - I'm running m4 sport pads on my m135i
Current '22 X3M LCI.. ![]() |
| 09-21-2016, 09:36 AM | #6 |
Rep 418
Thanks a lot for the info
| 09-21-2016, 09:40 AM | #7 |
Rep 766
go to bestbrakes.com - they can probably get you fitted with pagid yellows - or talk to the guys at G-Loc
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK |
| 09-21-2016, 09:43 AM | #8 |
Rep 74
So after further research I picked up Pagid Yellow pads for the front, and the rears are hawk pads that fit on the rear of 328/320i. I will be sure to make a new post when they arrive and I test fitment.
| 09-21-2016, 05:38 PM | #9 | |
![]() 1786
Rep 4,165
Fitment won't be the only issue. Performance/handling/braking will be. Brake systems are designed in such a way that there is an expected proportion of force between the front and rear brakes and this is based on certain assumptions about the interface between the brake pads and rotors. When using non matching sets of fronts and rear brake pads, there's a good chance that you are altering that balance in a negative way. You may very well be totally f'ing up your braking performance/handling - perhaps dangerously as well. Driveway mechanics are endless entertainment. Last edited by Polo08816; 09-21-2016 at 05:46 PM.. |
oceanview218.50 |
| 09-25-2016, 12:28 AM | #10 | |
![]() 1055
Rep 1,561
This shows your lack of understanding on how these braking systems work in the real world on track. You are correct that BMW biases the brakes a certain way, and that each setup has a properly sized master cylinder, piston size, etc. However: 1. Using a less aggressive pad in the rear than in the front is not a safety issue as locking the fronts before the rears will not cause a car to spin 2. This being the case, braking distance will not be effected whatsoever (even vs. OEM pads) as the pads are not the weak point in the braking system during a single stop, the traction of the tires on the pavement are. Even OEM brake pads will lock up both wheels easily in a single stop, so brake bias doesn't matter at all provided the rears do not lock before the front (unsafe). 3. BMW sets up the brake bias of these cars for safety on the street, not for performance on the track. This goes hand in hand with the soft suspension - on these cars, probably 85% of the braking is done with the front axle. I can throw whatever less aggressive pad I want on the rears and it just won't make a difference besides maybe cause a bit of understeer on corner entry trail braking if you take it to a real extreme. I've done it many times. 4. If anything, once you get a stiffer suspension in there to help minimize dive under braking, I would run a more aggressive pad on the rear than on the front to help move brake bias back a bit and help the car rotate better under trail braking. Unfortunately, that's not an option on this car due to lack of pad manufacturers making a pad in the rear caliper shape. So in short: claiming mixing and matching pads on the track is dangerous is ridiculous; it's done all the time and in some cases can enhance performance. Driveway mechanics are endless entertainment indeed. |
| 09-25-2016, 07:32 AM | #11 | |
![]() 1786
Rep 4,165
I never claimed that that using mixed sets will always negatively affect performance. However, there's a good chance that when done by your average driveway mechanic, it will have a less than optimal result. The same applies to suspension as well. I challenge the driveway mechanics to find a better "mixed and matched" spring and strut combination than the M Performance Suspension or well-designed/researched coilovers such as Ohlins R&T or AST. In fact, the most hilarious part of this is that there's plenty of threads of these driveway mechanics having blown tophats with their H&R/Bilstein combos. |
| 09-25-2016, 10:30 AM | #12 | ||
![]() 1055
Rep 1,561
Statistically speaking, it is exactly my strong suit.
![]() Quote:
cmplaya211.00 |
| 09-25-2016, 10:58 AM | #13 | |
![]() 1786
Rep 4,165
The point is I doubt that most posters on this forum have done due diligence (through testing, experience, formal technical training/education) in determining that a particular set of mixed pads is better than known matched pairs. In the absence of such due diligence, the large majority are better of sticking to known and "proven" combinations. |
| 09-25-2016, 11:03 AM | #14 | |
![]() 1055
Rep 1,561
I agree that most posters on this forum haven't done due diligence in determining the best performance of their particular braking system. If you haven't done so, why are you offering advice? The only reason I'm being a dick here is because you called out "driveway mechanics" without the requisite knowledge to actually do so. |
| 09-25-2016, 01:16 PM | #15 | |
![]() 1786
Rep 4,165
Clearly you haven't gotten over that either...If the OP tracks his car and is quick ... did you not read the first post? He's about to "start" tracking his car and taking into account his other posts leads me to believe he's pretty new at this. In my experience, stock cars with stock brakes are generally fine for drivers in the novice to novice-intermediate run groups at HPDEs. |
| 09-25-2016, 01:39 PM | #16 | |
![]() 1055
Rep 1,561
![]() Besides the fact that every driver is different, OP is running RE71R. That alone will contribute to increased stress on the stock pads due to their higher grip level. The front straight at NCM is a 140mph+ straight into a bus stop and then a slow right hander. His stock brake pads will be melted after a few laps from this sequence alone; you don't need skill to go fast in a straight line. And being a noob, he will be riding the brakes too softly and be braking too early, contributing to higher pad wear. Last edited by paradoxical3; 09-25-2016 at 01:49 PM.. |
| 09-25-2016, 03:48 PM | #17 | |
![]() 1786
Rep 4,165
Out of curiosity, how often does your SAT score, presumably from your high school years, get used outside of internet forums? When you are offended is that your go to thing? Better yet, how successful is using your SAT score as part of a pick up line? |
| 09-25-2016, 03:55 PM | #18 | |
![]() 1055
Rep 1,561
tmdals0213227.50 |
| 09-25-2016, 05:35 PM | #19 |
![]() ![]() ![]() ![]() 512
Rep 765
| 09-25-2016, 05:43 PM | #20 | |
![]() 1055
Rep 1,561
I taught the stig how to drive Fabio asks me for hair advice Gq had to censor me when I was on the cover because women were fainting I loaned the Lehman Brothers money when they were in trouble Any questions? |
krumpet511.50 tmdals0213227.50 |
| 09-25-2016, 06:07 PM | #21 | |
![]() ![]() ![]() ![]() 211
Rep 774
BOOM. pwned
tmdals0213227.50 |
| 10-05-2016, 08:42 AM | #22 | |
Rep 258
Drives: F30 320i (328i ECU) M-Sport
I had those on the rear stock 300mm on 320i- were sqealing like hell, when hot. Would not use in the city anymore. At the front i've installed the 335i 340mm grey Brembos and use F80 M3/M4 pads, which are fantastic for the price. Stock rear on 340i is 330mm with ~50% bigger pad area compared to 300mm on 320i/328i. So the pads are NOT interchangeable.
'13 F30 320i (328i ECU) RWD M-Sport
Michelin PSS, M-Sport brakes, 320i LCI muffler F32 bottom V-bar F80 bottom reinforcement plate Koni Sport, M-Performance springs, M135i Anti-roll bars |
| Bookmarks |
