10-27-2016, 08:39 PM | #1 |
Rep 925
340i B58 MidPipe Options?
I know of AWE Tuning and Dinan. Any others? Are they bolt on or do they require cutting? Both are about $500, seems a little pricey for just some exhaust tubing.
2016 M235i | BSM | 6SPD | BMS JB4 | Dinan Intake | Wagner Evo 2 Comp IC | VRSF DP | ER CP | Dinan Exhaust | M Performance LSD | M Performance Springs
Gone: 2016 F30 340i, 2015 Corvette Z06, 2011 E92 335i, 2007 E92 335i, 2008 Corvette Z51, 1999 E46 323i, 2001 Boxster, 1999 Carrera 2, 1997 Corvette, 2001 Camaro SS |
10-28-2016, 11:46 PM | #3 |
Rep 3,622
I have the axle back MPE. SoundS FANTASTIC. not super racy but a great GT sound
BMW CCA Member #516012
10-31-2016, 01:16 PM | #5 |
Rep 190,807
REMUS
10-31-2016, 04:18 PM | #6 | |
Rep 498
It was like $125 to do. That was including buying the guy lunch. |
11-01-2016, 03:26 AM | #7 |
Rep 881
11-01-2016, 09:39 AM | #8 |
Rep 190,807
Yes it is compatible with stock muffler... Dual pipe will give a more aggressive sound
11-01-2016, 05:53 PM | #11 |
Rep 1,771
Thank you!
Instagram: @dg_g20
11-01-2016, 07:28 PM | #12 |
Rep 190,807
$763 is the retail price from REMUS ... Im sure you can find a better deal in the vendors section
kern4174449.50 |
11-05-2016, 05:25 PM | #14 |
Rep 190,807
Midpipes for M3/M4 are over $1000
11-06-2016, 07:43 PM | #15 |
Rep 401
I'm not sure I'm buying this whole dual pipe design on a car with a single turbo. Having two pipes not only makes the system heavier but in increases the amount of turbulence from unnecessarily flow splitting and then flow merging down the path...and if you want to get even more technical it also has higher flow drag coefficient from having greater internal wall surface area.
I would venture to guess keeping exhaust pulses merged from a single turbo all the way back to be the winning combo for performance numbers. |
Wires1645.50 |
11-07-2016, 04:51 PM | #17 |
Rep 190,807
Congrats
11-07-2016, 07:36 PM | #18 |
The Wolf
247
Rep 987
Drives: stuff
Megan will make one it's not a complicated design screw 500+
11-02-2020, 08:11 PM | #19 |
Rep 454
11-02-2020, 10:51 PM | #20 |
Rep 281
Drives: 2016 EB 340i
an exhaust shop did mine for $150
11-07-2020, 02:16 PM | #21 |
Rep 2,964
+1
I originally had the Dinan but then sold it when I decided I wanted to quite things down a bit - year later I missed it and just went to my local muffler shop and had the resonators deleted for $100. Not as pretty but end result was the same (as you would expect) |
11-07-2020, 02:55 PM | #22 |
Rep 327
Does anyone know if the Dinan or AWE midpipes will fit with the Active Autowerke axle back exhaust? I have the Active Autowerke axle back exhaust on my 340i and like it but would like a more aggressive sound and know that a performance midpipe should do the trick. I do also have the Active Autowerke high flow catted downpipe which I love. Hopefully adding a performance midpipe won't make it too loud for me (and my neighbors).
2019 X3 M40i Alpine White/Black Vernasca stock
2015 435i Alpine White/Black Dakota FTP chargepipe, Dinan intercooler, M Performance exhaust, Carbahn Stage 2 tune |
