10-30-2016, 02:09 AM | #2 | |
In The Rain
8174
Rep 6,259
Drives: '24 GT4RS, '24 Macan GTS
It's called money shifting because doing that will tend to harm/destroy the engine, and that is money out of your pocket because warranty doesn't cover it. Cars now a days especially a F80/F82 will record things like this.
'24 Porsche Cayman GT4RS Arctic Grey "Alice"
'24 Porsche Macan GTS Dolomite Silver "Gina" |
Super Spartan1553.50 QLAbot87.00 |
10-30-2016, 02:18 AM | #3 |
Rep 1,165
Drives: f83 / E93 335 / E70 X5 40d
Other than a mis-shift, is it actually possible to over-rev an S55?
I would have thought that once you hit the redline, the injectors would shut down - just like they did on the N54. I don't know, as I haven't tried to go beyond the redline. |
10-30-2016, 02:18 AM | #4 |
Rep 3,661
I have the same question. Anyone who says they have never hit the rev limiter is lying. It happens once in a while. I don't think that can cause an engine failure. Money shift is more likely the culprit.
2016 F80 M3 AW/SO (Manual) - Picked up at the Welt 08/28/15 My Amazing European Delivery Story |
10-30-2016, 02:18 AM | #5 |
Rep 3,659
Drives: 981 Cayman GTS
This is what I'm wondering as well. I thought over-revving was only possible with money shifting and in other cases rev-limiter would prevent this.
10-30-2016, 02:21 AM | #6 | |
Rep 2,419
10-30-2016, 02:23 AM | #7 | |
Rep 2,419
since that's something the car is programmed to do, do you think that is harmful to the engine/transmission? |
10-30-2016, 02:26 AM | #8 | ||
Rep 3,659
Super Spartan1553.50 |
10-30-2016, 05:57 AM | #9 |
In The Rain
8174
Rep 6,259
on the M-DCT, no it won't allow you to self harm the engine in such a fashion but you can still do so with a MT.
10-30-2016, 06:57 AM | #11 |
Rep 6,673
Basically downshifting while having too much cash in your pocket. That big wad of money can restrict the movement in your left leg (clutch leg) causing you to mis-shift. If you don't have cash on you then it's called a heel toe or something like that.
mrfox148.00 |
10-30-2016, 07:02 AM | #13 | |
Rep 6,673
10-30-2016, 07:05 AM | #14 |
Rep 6,673
BTW, do you guys consider redlining an MT to be over revving? Can BMW reasonably build a case to decline warranty repairs or even engine replacement due to a history of redlining (not including erroneous money shifts). Just good ole fashion hooning or track days with multiple redline events?
What do you guys think? |
10-30-2016, 07:45 AM | #15 | |
Rep 20,741
Drives: 2021 911 turbo
However, I seriously doubt an over rev of a few 100RPM would cause such a catastrophic failure. To the OP, it is also important to understand that a severe over rev caused by a money shift might not result in an immediate engine failure. The over rev can cause damages to components that will only fail later down the road after more cycles are put on them. So it is very possible for the engine to suffer a catastrophic failure while leisurely cruising down the highway caused by an over rev that occured quite earlier in time (could be months later).
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 10-30-2016 at 12:22 PM.. |
10-30-2016, 07:46 AM | #16 | |
Rep 10,185
The limiter is in place to prevent any damage. A moneyshift is another thing.
BMW if you are reading, I need a job, Please. |
Falafel Combo3773.00 |
10-30-2016, 08:26 AM | #17 | |
Rep 6,673
10-30-2016, 09:51 AM | #18 |
Rep 218
I'm in the dark here on a lot in life...hahaha, but also on why you cannot over rev an engine when it has the DCT. I've seen a lot of posters reiterate this, but I would like to know why myself if someone is willing to explain. Means the DCT has a manual shift option, I had always assumed it would only shift when you tell it too other than when it automatically shifts when slowing down. What happens if you are in third and you get to the redline, will it not let you go pass that? Does it just shut down the engine in the same way as when is sees wheel spin when the traction control is on or does it just sit there at the redline until you shift?
I'm assuming it's somewhere in the manual, but I haven't made it through the whole thing yet. |
10-30-2016, 10:30 AM | #19 | |
Rep 20,741
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
NOLATom104.00 |
10-30-2016, 10:44 AM | #20 |
Rep 2,799
Does this money shifting also happens for Honda engines,.I have driven my brothers S2k several times very hard and never thought of this and my brother used to drive the S2k extremely hard including tracking it and never had any engine issues.
These cars are meant to be driven hard and I think engine should be tuned to absorb some mis- shifts...this money shifting makes me nervous to drive my car hard |
10-30-2016, 10:59 AM | #21 | |
Rep 218
10-30-2016, 12:15 PM | #22 | |
Rep 2,799
