11-07-2016, 11:25 AM | #1 |
Rep 716
Drives: F90 M5
springs
hey guys, has anyone tried using the Dinan Supplemental Ride Quality & Handling Kit with any springs other than the dinan ones?
01-02-2017, 02:05 PM | #3 |
Rep 716
Drives: F90 M5
Yea pretty much
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
01-05-2017, 11:01 AM | #5 |
Rep 580
How are the pro Kits springs working with the Adaptive suspension on your M235? Eibach doesn't seem to make a separate spring for that suspension like H&R does.
01-07-2017, 02:19 PM | #6 | |
Rep 566
There may be issues on cr*ppy roads with lots of potholes and waves on them, especially if the car is loaded - more chance of bottoming out, damaging wheels, etc., or even hitting the underside if you go too fast for the conditions because the springs are still not stiff enough (I'm not sure they are stiffer than stock springs), and the shocks are not stiff enough, to prevent too much vertical movement. I cannot imagine how I would drive with the kind of lowering you get with H&R. That would be for the looks only. I really think that is wrong for the stock shocks. The reason I chose Eibach over H&Rs is precisely because they do not produce too much lowering. Adaptive shocks longevity? That I don't know. Sometimes I drive on really bad roads so that could be a factor. Right now I am at 12k miles on them and want to go to the dealer and check everything in the suspension including shocks. It's really cold (- 20 C) out here and once it got cold I started hearing a knocking/rattling sound in the suspension in the morning, can't quite place it, that would pretty much go away after about 5-10 min of driving, could be the shocks dying or, hopefully, just too cold outside and something plasticky/rubbery getting too stiff and rattling about. Will find out soon. Last edited by x233; 01-07-2017 at 02:32 PM.. |
Tpeterson156.50 |
01-07-2017, 03:28 PM | #7 | |
Rep 580
BTW Our temps here are about the same as you are experiencing and I was just thinking that all squeaks ,rattles,and groans have to be ignored because cars really don't like to be driven in this type of weather! |
01-07-2017, 06:37 PM | #8 |
Rep 301
01-07-2017, 06:59 PM | #9 |
Rep 580
01-07-2017, 07:47 PM | #10 |
Rep 301
Then just don't have them installed by a Dinan dealer. I had mine installed at a speed shop including the new bump stops and spacers for $225.
If you go with another brand like H&R will you have them installed by an "H&R dealer?" Happy with my Dinans but there is no way that I was going to pay $1000 for a simple spring install. Last edited by ChrisFulton; 01-07-2017 at 07:55 PM.. |
01-07-2017, 11:24 PM | #11 | |
Rep 356
Drives: 2014 m235i
Very satisfied with mind too, I just DIYed |
Tpeterson156.50 ChrisFulton228.50 |
01-08-2017, 09:07 AM | #12 |
Rep 580
Thanks for the feedback and advice. I had thought of non Dinan dealer installation also -DIY is more than I want to attempt- but wondered about warranty coverage. You're both right.They have to honor their warranty if the springs are installed correctly. It's been mentioned already in this forum,but I'm glad to hear someone has done this way.Something for me to think about this Spring!
ChrisFulton228.50 |
01-08-2017, 10:08 AM | #13 | |
Rep 301
Rears are part #: 33536762722 https://www.fcpeuro.com/products/bmw...in-33536762722 Fronts are part #: 31331138814 https://www.fcpeuro.com/products/bmw...-31331138814oe Last edited by ChrisFulton; 01-08-2017 at 10:14 AM.. |
01-08-2017, 01:13 PM | #14 | |
Rep 580
01-08-2017, 01:55 PM | #15 | |
Rep 301
I believe they are sourced from two different models of the 5 series. |
Tpeterson156.50 |
01-24-2017, 01:52 AM | #16 | |
Rep 716
Drives: F90 M5
01-28-2017, 04:41 PM | #17 |
Rep 301
02-01-2017, 04:32 PM | #18 |
Rep 647
I have Dinans + supp ride kit and the car rides great. IMO drop is perfect. H&R's seem too low and less opportunity for aggressive tires to boot. I run a M perf front lip and rarely bottom out although i am careful. $1000 is ludicrous. I installed mine in 4 hrs. Any reputable shop should be more than fine if your uncomfortable with the install. Heres a few pics of the stance.
02-01-2017, 04:59 PM | #19 | |
Rep 716
Drives: F90 M5
02-01-2017, 06:21 PM | #20 | ||
Rep 647
He is awesome to work with and great prices.. |
02-01-2017, 06:21 PM | #21 | |||
Rep 716
Drives: F90 M5
