M2 Technical Topics > Cosmetic Modifications > Carbon fiber spoiler install
      11-28-2016, 09:58 PM   #1
Dmarcen
Drives: TBD
Anyone who has had this installed. Is it all double side tape or attached with bolts? Looking to have installed just after taking delivery but company doing my xpel coverage and tint says can also install if double side taped.
Any info would be appreciated!
Poochie9104.50
      11-28-2016, 10:19 PM   #2
Ex-MINI
BMW Newb
Ex-MINI's Avatar
Drives: 2016 LBB M2 DCT
Typically installed with 3M tape. Another option is to use Betalink adhesive, but that is typically harder / impossible to remove if you mess up the initial install...fine to just stick with the double sided automotive tape.
      11-28-2016, 10:36 PM   #3
David1
David1's Avatar
Drives: 09 E92 09 X5
Its just taped.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
twin fed1175.50
      11-29-2016, 02:28 PM   #4
zkeeper
zkeeper's Avatar
Drives: 2017 M2 & 08 Z4 si
All the above; only would add to make sure both surfaces are totally clean and grease free, and you are good to go.
      01-20-2017, 01:13 AM   #5
CantComplain
Drives: '17 6MT AW M2
This may be a stupid question, but what's the best method to remove the backing on the tape while keeping everything perfectly placed? I have the BMW CF spoiler and will install it this weekend. There's clearly something going on with the backing, as it's in different colors (blue and red if memory serves) and some of it sticks out. I can only assume there's a document for what to pull when but I can't seem to find it. Can anyone shed any light?
edit: I googled spoiler installation and apparently there's no magic to the adhesive. it's just mark it, remove the backing and stick it on. I was thinking there was some special sanctioned method. For anyone else wondering in the future, I think the best method I saw was to lay it out where it needs to go and then put a few pieces of painters tape on the forward/leading edge. then just pivot up using the tape as a hinge, remove the backing, and lay it back down. Actually looks pretty simple....
      01-20-2017, 05:59 AM   #6
blackholescion
Drives: MG M2
Mark the previous spoiler before you take it off so you can place it in the exact same spot. Position it based on the back and sides of the previous spoiler, since the CF spoiler has a slightly larger footprint.
      01-21-2017, 02:47 AM   #7
aronhuhu
Drives: bmw e46
J.M263.50
AndrewC198910931.00
m2for2227.00
      01-21-2017, 05:11 AM   #8
J.M
J.M's Avatar
Netherlands
264
Drives: '17 M2 DCT BSM
2017 BMW M2  [0.00]
Will be doing the same with an AutoID CF spoiler probably next weekend.
Check out my M2 YouTube channel: The HyperCar Collective
      01-21-2017, 06:18 AM   #9
Wangspeed
Drives: BMW M2
Fishing line and adhesive remover is a safer way of removing the original spoiler. I wouldn't advise doing it the way in the video. Heat it up before running the line if the spoiler is cold.
The way they attach the new one in the video is the best way I know of. Don't make the mistake of pulling off all the backing before you put it down!
FrozenGT1116.50
      01-27-2017, 10:51 AM   #10
bartusM2
Belgium
Drives: BMW M2 (F87) on order
Could someone give me the exact dimensions of this spoiler (how high it is and how far it sticks out from the boot)?
I'm having a car cover made and the manufacturer wants dimensions since it'd a non-stretchy material.
Thanks alot in advance!
      02-08-2017, 12:34 AM   #11
jayg80
jayg80's Avatar
Drives: M3
Is it just me or does the spoiler look like it is seriously pulling up towards each end. The left side doesn't look great in the video after it has been installed.
      02-08-2017, 02:05 AM   #12
Prollig
Prollig's Avatar
Drives: 2017 M2
Haha yeah doesn't look too flush.
I've watched 4 or 5 youtube videos. They're all mostly the same. Haven't heard of any super secret tricks.
      02-08-2017, 02:44 AM   #13
Doji desu
Drives: GR Yaris
Mine lifted (dealer installed), swapped it for another and all good.
      02-08-2017, 10:37 AM   #14
jayg80
jayg80's Avatar
Drives: M3
Does the last inch of each side of your spoiler sit perfectly against the trunk as the rest of the spoiler does? Mine appears to be slightly off the trunk, maybe an 1/8''
      02-08-2017, 04:55 PM   #15
DivideBYZero
Never underestimate the Home-Bowl
DivideBYZero's Avatar
Drives: F87 M2<E92 M3<E46 M3
Mine too. Dealer installed.
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT
2016 F22 M235i Coupe, MW, ZF8
      02-23-2017, 06:12 PM   #16
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
i don't like the way that looks at all. might betalink mine to avoid that.
      02-23-2017, 08:25 PM   #17
jayg80
jayg80's Avatar
Drives: M3
my gap is less than that but still noticeable to someone who considers themselves OCD. I dont think the betalink will make a difference because on my spoiler the edges literally wont touch the trunk even with a decent amount of pressure. It's almost as if during manufacturing the edge slightly curve up.
termigni1081.00
      02-24-2017, 05:30 AM   #18
Doji desu
Drives: GR Yaris
I believe so I will check on the morrow
      07-25-2018, 03:03 PM   #19
subliminalaudio
subliminalaudio's Avatar
316
Drives: BMW M2
Have you see this version before ? If you have it can you share some pics
      07-25-2018, 03:52 PM   #20
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Drives: M2
Someone in the forums has it. I forget their name but they bought it from shuttergang. Personally I don't think it goes with the M2's body lines.
Similar ones that imo look better are AC Schnitzer or PSM. Both of these come in 2 variants, with the "notch" on the center or completely rounded off
      07-26-2018, 01:41 PM   #21
heavyD^2
heavyD^2's Avatar
Drives: X3M Competition
I concur with posters above. The M performance CF spoiler fitment is poor IMO. I did everything possible to ensure a proper fit (polished off old adhesive residue followed by IPA wipe down, followed by 3M adhesive promoter. I spent a good 40 minutes lining things up making marks and measuring to ensure perfect fitment and even taped the corners down for a week and eventually both edges lifted. BMW needs to have the molding very slightly changed to have the ends taper slightly down. That would ensure the ends don't lift and there's no danger of the middle section separating as that part has a very strong bond. I realize CF is more difficult to get perfect but this is one of the worst OEM fitments I've ever seen on any car which is inexcusable for the money they charge for the piece.
      07-26-2018, 04:56 PM   #22
n00bs41bot
Drives: 2016 Long Beach Blue M2
Yup, I got it from Shuttergang.
https://f87.bimmerpost.com/forums/sh....php?t=1510137
nioh_lbbm21716.50
m2
