BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Did BMW not replace my rotors
12-03-2016, 06:16 PM | #1 |
Rep 271
I was changing my winter tires today and I was looking at the rotors and they look hella old. I did a full brake job last spring (2015). Should my rotors look this corroded for being only a year old?
By comparison, here are my rear rotors which were replaced this summer under some warranty work. I have a hard time believing they will look like the ones on the front by this time next year. Did BMW screw me? Lastly here is why my brothers rotors look like, he also had his brakes done around the same time last year. Notice that the center hub is painted grey like my new rear rotors. Where as the hub on my front rotors or dark/rusty. Last edited by ssshake; 12-03-2016 at 06:30 PM.. |
12-03-2016, 08:21 PM | #3 |
Where'd my VTEC go?
481
Rep 6,067
You can't judge "age" of the rotors by how rusty it looks. Rotors are made of iron and will rust very quickly when exposed to the elements. It could be the front rotors never had a rust proof coating sprayed on them to begin with, or it has broken down/rusted through already due to the heavier heat cycling experienced by the front rotors since they work harder. It could also be brake dust from your pads getting baked on the non-friction surfaces of the rotor since it looks more dark instead of rusty.
Judging by how there is minimal "lip" on the outer or inner edge of the friction area, I would say the the rotor looks fairly new.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
12-03-2016, 09:40 PM | #4 |
Rep 342
Drives: 2008 E90 335i; 2016 F80 M3
judging by the lip they have and how it looks on the pictures, those fronts were not changed. Also, I don't know how bad is the weather where you live but mines, new fronts after almost a year, they look pretty pretty good, almost no rust and not a mm of lip on them.
12-04-2016, 03:44 PM | #6 |
Rep 227
They don't look like they have much of a lip on them... I'd say they look fairly new. And like someone said above^ they won't replace the rotors unless they measure below minimum spec. Now if you paid for the rotors specifically to be replaced, that's a different story, but I still think they look like they were replaced.
If you had them done spring of last year, then they already were exposed to the salted roads of winter last year (assuming you live where it snows.) That'll speed the corrosion process up significantly. |
