BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Is it possible to code out the trunk opening from the remote ?
Studio RSR
      12-26-2016, 02:20 PM   #1
CIWS
Moon Parasite
CIWS's Avatar
Drives: F98 X4M Competition
Looking to see if we can code out/off the opening of the trunk from the remote to prevent the FOB opening the trunk while in your pocket. Has anyone done this yet ? I searched but didn't find an answer.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged
      12-28-2016, 05:01 AM   #2
CIWS
Moon Parasite
CIWS's Avatar
BUMP - No one out there have any idea ? Bueller Bueller ?
      12-28-2016, 06:21 PM   #3
anom3
Drives: F30 335ix
There is a setting somewhere to set the amount of time one has to hold the button on the remote down before the trunk opens.
Guessing you can max this out and at least make it very unlikely someone will attempt to hold the button down that long.
CIWS655.00
      12-28-2016, 08:13 PM   #4
CIWS
Moon Parasite
CIWS's Avatar
That's an interesting idea, thanks.
      12-30-2016, 10:20 PM   #5
regular_joe
regular_joe's Avatar
Drives: 2014 320XI Modern Line
Why not flip the trunk lock switch to locked that is in the glove compartment?
      12-31-2016, 05:09 AM   #6
anom3
Drives: F30 335ix
All depends on what OP is after.
I'm EU so we dont get the switch in the glove box...
But I am assuming this locks ALL access to the trunk. Including the outside handle button and (if you have one) the interior drivers knee area button.
      12-31-2016, 05:29 AM   #7
CIWS
Moon Parasite
CIWS's Avatar
Best case would be to prevent unintended trunk openings occurring because the button on the remote gets pressed while the remote is in the pocket when bending / kneeling, etc But still allowing it to be opened from the release inside and outside the car. I never really use the button on the remote to open it. I purchased and tried the BMW MSport leather remote cover and it still happens.
      12-31-2016, 07:57 AM   #8
anom3
Drives: F30 335ix
Yep looks like this is as close to a solution as you will get:
FEM_BODY 3040 CLM_TIMEOUT_HK_SMO Change the Comfort Access trunk opening delay. (HEX value by 0.1 secs)
Unless you are brave enough to open up your remote and unsolder or block the button.
EDIT : Should note, I am not 100% sure if this is the correct setting. This may not be it. I am sure this exist though. I have it coded in my E92 M3. I found the opposite... Annoying that I had to hold the button down for so long to get the trunk to pop open.
CIWS655.00
      12-31-2016, 12:23 PM   #9
BMW3291
BMW3291's Avatar
Thailand
Drives: F30 Active Hybrid 3
Try this setting
FEM_BODY
RC_TIME_DELAY_BOOTLID
CIWS655.00
      01-01-2017, 06:37 AM   #10
CIWS
Moon Parasite
CIWS's Avatar
Thanks folks, will see what I can come up with.
      01-02-2017, 04:30 PM   #11
Olly232
Drives: F31 320d Xdrive
I don't have an answer for you but I can sympathise having had the same problem with finding all the windowss open one morning. I was able to code out that option so there maybe a similar option for the trunk
      01-02-2017, 07:58 PM   #12
CIWS
Moon Parasite
CIWS's Avatar
Originally Posted by BMW3291 View Post
Try this setting
FEM_BODY
Tried this afternoon, setting the value to 00 vs 01 hoping it might disable, but it didn't. Just took the opening delay out so it popped right open.
      01-02-2017, 11:39 PM   #13
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Look in HKFM. There are settings there as well.
CIWS655.00
      01-03-2017, 10:43 AM   #14
TheRealEssad
TheRealEssad's Avatar
56
Drives: 2015 328i xDrive
Did you try going in the opposite direction and making it much higher number, like 09? Not sure what the top value of the range is, but definitely lowering it reduces the delay, not what you're after.
      01-03-2017, 02:35 PM   #15
anom3
Drives: F30 335ix
Exactly.
Also worth mentioning, even if a value is not there, you can try entering a custom value for 60 seconds or something.
First try the highest value, let the car sleep a few minutes and see if it helps.
If it does, keep going up with custom values until you reach a point you feel comfortable with.
      01-03-2017, 05:44 PM   #16
CIWS
Moon Parasite
CIWS's Avatar
Exactly.
I changed the wert value from 01 to 00. The only two options available. I think y'all are referring to the Werte value which is default to 05 in my case.
When wert was changed to 00, Werte also changed to 00. My assumption here is wert is a delay on or off (01 or 00) As it turns out there was no delay with that setting, the trunk popped right open.
I could be off base here, but if Werte is a delay setting then increasing the number is only going to delay how long it takes before the trunk pops open after the button is pressed, not stop it from opening, which is the goal I'm after. Would you agree, or am I looking at it wrong ?
      01-03-2017, 07:44 PM   #17
anom3
Drives: F30 335ix
Yes. Its going to increase the time needed to hold the button.
That being said, if you are able to increase it to lets say 30 seconds, you'll be pretty close to what you are after.
Try changing the value to 10 by right clicking Werte and editing it to 10.
See if that increases the time you have to hold the button.
Those values are usually in hex ( http://www.binaryhexconverter.com/de...-hex-converter ).
So for example, 30 would be:
1E
Also, they are usually fractions of a second. So with 1E (30) as an example, it could be 30 x 0.5, or something along those lines.
Note : Just to be clear, those Werte values can be modified even if its not one of the "choices". You can set manual values in there by editing them manually by doing the right click -> edit I mentioned. As always, proceed at your own risk. I have NEVER EVER had any issues setting custom values (even with things like how soon the alternator should switch on when car starts, etc)...
CIWS655.00
      01-03-2017, 08:06 PM   #18
Almaretto
Almaretto's Avatar
2374
RC_TIME_DELAY_BOOTLID (RC TIME DELAY BOAT EYELID)
wert_01 (value 01) = 05
Comment = timeout for delayed open control of the bootlid (HKL) 1 unit = 0, 1s value range: 0... 2s note: overall delay value is the sum of CLM TIMEOUT RC BTL (CL-master) and RC TIME DELAY boat EYELID (component in remote control) delay time to the electrically opening of HK - should be added for F020 when available in container: (building level > = 0703) + 316 tailgate LIFT
OPTIONS
wert_00 (value 00) = 00 - Comment = Verzögerung in Einheiten von [0,1s], wert_00 entspricht 0,0s. (Delay in units of [0, 1s], value 00 is equal to 0, 0 s.)
wert_01 (value 01) = 05 - Comment = Verzögerung in Einheiten von [0,1s], wert_01 entspricht 0,5s. (Delay in units of [0, 1s], value 01 corresponds to 0, 5 sec.)
CLM_TIMEOUT_RC_BTL
initwert = 00 00
Comment = timeout for delayed open control of the bootlid (HKL) 1 unit = 1ms value range: 0... 5 sec Note: overall delay value is the sum of CLM TIMEOUT RC BTL (in CL-master) and RC TIME DELAY boat EYELID (component in remote control) – should be added for F020 when available in container: delay time to the electric opening of HK
OPTIONS
initwert = 00 00 - Comment = Timeout to active RC in Ms. Default is 0 ms for L7, 500 ms for L6 (Timeout to active RC in Ms. default is 0 ms for L7, 500 ms for L6)
OPTIONS
CIWS655.00
      01-04-2017, 05:04 AM   #19
CIWS
Moon Parasite
CIWS's Avatar
Thanks guys, will give it a try and see what the result is. Even if it gets funky it can be flashed back to default.
      01-05-2017, 04:49 AM   #20
CIWS
Moon Parasite
CIWS's Avatar
Minor update, I had one chance at lunch yesterday to try it and edited Werte value to 10. (vs 05) and that pushed the trunk opening delay to something to between 3 and 4 seconds. I could stand there holding the button down for a good count to 3 and it would not open, repeated it several times. But about the time I counted to 4 it would pop open.
So some forward progress, and that by itself would solve any momentary presses occurring. But I would like to see if it will go longer. It's possible for some reason there's a "max" value / time and any larger setting won't make any difference. But I'd feel more comfortable with at least double that time.
      01-05-2017, 02:03 PM   #21
anom3
Drives: F30 335ix
Yes.
It is possible there is a max value programmed in.
Eg:
If werte > X, set to X regardless.
At least this was the case with my E series.
Give "64" a shot.
64 = 100 in decimal. So that SHOULD give you 100 x 0.1 seconds.
If it only gives you the 3-4 seconds you mentioned, then there is a max value programmed into the module.
      01-05-2017, 06:17 PM   #22
CIWS
Moon Parasite
CIWS's Avatar
Yes.
Eg:
Give "64" a shot.
Looks like I may have already hit it. Tried Werte 1E and also 30 this afternoon and in both cases it's stayed between 3 and 4 seconds to open, so I may simply have to live with that and see how it goes. But I do appreciate the assistance with getting it to this point. One more little note in the coding of the car.
