BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > F30/F32/F33 Classifieds (For Sale / Trade / Wanted) > Members Classifieds > Electronics: Audio / Video / Phone / Alarm / Navigation / Radar > Match/Helix Jehnert Amp Speakers
European Auto Source (EAS)
      02-15-2017, 08:30 AM   #1
Jedclampet
Drives: 2011 X3 Black
BIMMERPOST / Classifieds
Asking Price:
None
✓ Will Ship
Item Interest
I have a clean Helix/ Match PP82DSP which is a 8 channel amp and dsp for advanced tuning and easy intergration to a sotck system. $ 400 OBO see this link
http://www.audiotec-fischer.de/lng/e.../pp-82dsp.html
I also have a Jehnert Flatline three way system made for Bimmers easy bolt in although I used the underseats for another project it includes the tweeters, mids mounting rings and crossovers everything but the underseats
Fits many models $ 300 OBO
http://www.jehnert.de/en/shop/doorbo...-3-5-7-series/
And I also have a harness built by Music car NW for the base audio adding a 3 way fronts $ 75 OBO
Take it all for $ 700 OBO
Will post pics soon or send a email I will send them to you
See this link for Pic's and this important note regarding one of the tweeters
**** Very important note that one of the tweeters has been repaired.
One lead had come loose and been soldered back on some plastic had
to be cut away to reach the connection the speaker works perfectly****
http://www.caraudioclassifieds.org/f...-speakers.html
I'm in NJ 07834 and will charge actual shipping costs
2010 135i Champagne Silver
      02-23-2017, 10:59 AM   #2
listed5
Drives: 2011 e93 M3 DCT black/bamboo
Is the harness used to connect the amplifier or front speaker assembly? also, what model did this equipment come out of and why?
thanks,
Chris
      02-27-2017, 07:52 AM   #3
Jedclampet
Harness
This came out of a 2011 x3 with a basic stock system. For the harness you disconnect the factory amp and plug the harness and Match pp82dsp in its place. Its pretty adaptable with many inputs and outputs. I ran it for an active system using all stock locations tweeters, mids and mid bases under the seats. I replaced it for more that three times the money to go bigger. The tuning aspect when done well is what makes this system imo and the speakers aren't bad either. The one unused harness is configured to take the stock inputs, power, ground and remote turn on. And run one channel for the front mid and front under seats using factory speaker wires for that part there is nothing else you need to do. There is another set of speaker wires for the front tweeters which you will have to run yourself. The reason for that is the factory harness runs one set of wires into the doors for both the tweeters and mids and they split off within the door, not allowing you to run active ( which gives you far more control when tuning and well worth the effort). So in that set up running only one set of speaker wires is all that is needed for wiring.
      03-13-2017, 02:47 PM   #4
listed5
I'm sorry, I'm a bit of a novice here. Would I be able to retain my center channel using the harness you are selling or would I have to run a wire in order to do so? Also, would this interfere with bluetooth calling? If there is a different harness on the market that would allow me to utilize my stock HiFi center channel and bluetooth config, please let me know! I'd like to buy this amp at least and maybe the harness also.
Thanks,
Chris
      03-13-2017, 04:12 PM   #5
Jedclampet
Chris best to call me I'll give you the low down
Peter cell 973-919-3500
      03-18-2017, 03:17 AM   #6
listed5
Thanks Peter! I'm sorry that I'm just now seeing your reply! I'm sorry to have kept you waiting. I'll give you a call on Monday.
thanks,
Chris
      06-21-2017, 10:47 AM   #7
chrisnguyen01
Drives: 2017 540xi
Is the amp still available?
      06-21-2017, 10:48 AM   #8
Jedclampet
Helix
Sorry no finally sold
