03-04-2017, 02:36 AM | #1 |
Rep 469
N55 oil consumption - bad sign?
Hi
I was wondering. I have a F30 335i that was build in 2011. I bought it used at 23k miles and from the beginning it consumed oil. Nothing worrying but still more than I have tried in other engines. We also discussed it here: http://f30.bimmerpost.com/forums/sho....php?t=1074877. The car used more oil the faster I drove it or the heavier the load was. However, unfortunately my engine decided to eat its crankshaft bearings and I had to get a new engine/turbo and transmission 10 months ago. Of course I am a bit nervous that my new engine also will fail some time in the future but the new engine is almost not using any oil at all and it looks like I am able to complete a service cycle without refilling it. Do you think there is any relation from a oil consuming engine and its failure or have I just been unlucky with my first engine? Anyone else also had complete engine failure on the first versions of the N55?
DD: F48 X1 xDrive25i '20 - https://f48.bimmerpost.com/forums/sh....php?t=1703083
For fun: F22 M240i '19 - https://www.2addicts.com/forums/show....php?t=1644646 Previous BMW: Fully loaded F30, 335i https://f30.bimmerpost.com/forums/sh....php?t=1681247 |
03-04-2017, 07:35 AM | #3 | |
Rep 10,351
"Drive more, worry less. "
03-04-2017, 09:07 AM | #5 |
Rep 367
03-04-2017, 09:59 AM | #6 | |
Rep 10,351
03-04-2017, 10:17 AM | #7 | |
Rep 2,083
Per your post you add a quarter every 10k right, meaning you do your oil change pass that miles. How can you follow the stupid BMW oil change every 10k or 15k miles. You are killing your engine. Op, just do you oil change at 5k and you wouldn't need to add anything.
stxf3094.00 |
03-04-2017, 10:42 AM | #8 | |
Rep 367
03-04-2017, 11:07 AM | #9 |
Rep 1,782
I usually run though a quart every 3-5k miles.
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
03-04-2017, 02:31 PM | #10 |
Rep 469
Hi all - thanks for the comments. I see I need to add some information.
I bought the car before any tunes were available and it was fully serviced by BMW. I added MPPK at 40k miles. It had done 24k miles when I bought the car and the engine failed at 70k. Normally I added a quart every 3-5k miles and it was serviced every 8-12k miles even though it told me not to service it for the next 6k miles. My mechanic (a BMW service world champion) told me the car was very well serviced but also said that even thought the oil refills were within the tolerance it was a bit on the high side.
03-05-2017, 12:55 PM | #11 |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
I use a quart every 1,000 but I found a cracked pcv inlet tube so replaced that and pure inlet all in one shot so I'll monitor and report. I wrote down mileage every time it prompts me to add oil.
FBO-PS1 and stuff
Chicken_Joe606.00 |
03-06-2017, 01:15 AM | #12 |
Rep 114
I had this same issue as well. I took mine to the dealership since I'm CPO. they replaced it no prob. no issues since.
2013 F30 335i - Totaled 2016 F80 M3 - PS2+ | MHD | Wedge Performance | |
03-06-2017, 07:08 AM | #13 | |
Rep 709
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL | 85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger |
03-06-2017, 01:12 PM | #14 |
not good, but bad
333
Rep 361
FWIW I've been keeping track of my engine oil analysis.
http://*************/oil-analysis-results/ It seems like the average oil change interval that Blackstone receives for a '13 (or N55) is 6,200 miles. The link above includes an oil change at 10,000 miles and at 2,700 miles. I haven't had to add any "top off" oil but I did notice a bit of the blow by oil when I changed out my intake. From the responses I got in this thread, this was a "normal" amount. http://f30.bimmerpost.com/forums/sho....php?t=1307828
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube |
03-06-2017, 11:21 PM | #16 |
Rep 469
The oil is the one recommended by BMW. I have no idea what it is. I never ever drive aggressively before the engine is warm.
03-07-2017, 10:08 AM | #17 | |
Rep 2,825
-motul -amsoil -shell rotella t6 -redline oil liqui moly you should have in denmark. very good quality and stick to a 5w40. it will slow oil burning and protect your engine better. you probably had an engine failure due to poor quality oil not protecting the bearings. |
03-07-2017, 12:03 PM | #19 |
Rep 709
Anyone have any experience with BG oil? Heard it was better than most for these cars
03-08-2017, 02:31 PM | #20 |
Rep 469
I actually did consider bringing my own oil and I will certainly reconsider that option. Last time it got Castrol but I don't know the rating. Next time it will be serviced my usual place and if it starts burning oil I might have found the reason for the oil consumption. Then I will also change to the oil to something thicker.
03-08-2017, 02:51 PM | #21 | |
Rep 3,211
break in your engine properly and change the oil every 6-7.5k miles youll be fine |
03-08-2017, 11:27 PM | #22 |
Rep 469
I know the first owner was BMW and yes, it could have taken some beating during test drives. The second owner I don't know but according to the music that was loaded on the harddrive he must have been 50+ ;-)
