03-12-2017, 04:28 PM | #1 |
Rep 240
MP4S on 8.5" and 9.5" wide rims
Hey guys,
Really hoping the wheel/tire gurus can give me a definitive answer once and for all. Am I correct in assuming that the new MPS4S will be similar dimensions to the MPSS, and that a 235/40-19 and 265/35-19 set-up is ideal for my 2013 335i xDrive going on some new 19"x8.5" +35 and 19"x9.5" +35 rims (currently lowered on coils to 0.75" wheel gap in front and 0.25" wheel gap in rear with the 400M and 441M wheels I've been running in summer/winter; I'm using 10mm spacers in front and 15mm in rear right now but hope not to have to use them for the new wheels unless necessary)? I shouldn't get any rubbing on fender or suspension parts, right? Or should I go with a lower-profile 235/35-19 265/3-19? This is what the 40 profile tires on the 8.5" +35 rim would be in front: http://www.willtheyfit.com/index.php...8-5&offset2=35 And the 35 profile on the 9.5" +35 rear: http://www.willtheyfit.com/index.php...9-5&offset2=35 Thanks for your feedback! Fred Last edited by TSiSPY007; 03-12-2017 at 04:55 PM.. |
03-12-2017, 05:12 PM | #2 |
Rep 366
265/35 might rub in the rear depending on your alignment, height, dips in the road and passenger weight. 265/30 would be safe but its a bit of a thin sidewall. 255/35 would work as well and is the OEM size for 19" wheels.
03-13-2017, 12:13 AM | #3 | |
Rep 1,986
You need to research the specs. For example the MPSS Tread Width is 234mm while the MPS4S is 216mm, while the rear MPS4S is wider than the MPSS in the rear. See: http://f30.bimmerpost.com/forums/sho...20&postcount=1 Last edited by Kabrich; 03-13-2017 at 12:24 AM.. |
03-13-2017, 11:25 AM | #4 | |
Rep 105
Section Width: https://www.tirerack.com/tires/tiret...jsp?techid=200 Tread Width:https://www.tirerack.com/tires/tiret...jsp?techid=201 The listed width of a tire 235 (front) or 265 (rear) is the section width. That's the measurement of the tire's width from its inner sidewall to its outer sidewall, which is consistent of all tires listed in that size for all brands and models. This is what the OP is concerned about, since he's asking about fitment and potential rubbing. The tread width is the contact patch, ie. the width of the tread that comes into contact with the road. It makes me wonder about the huge 1-inch difference in the MPSS (9.2 inches) vs. the Conti ECS (8.2 inches) for the 235 fronts! |
03-13-2017, 06:35 PM | #5 | |
Rep 1,986
03-15-2017, 07:55 PM | #6 |
Rep 240
Thanks for the input, guys!
I'm still not clear whether I should go with a 235/40-19 and 265/35-19 combo (minimal discrepency between front/rear and more sidewall/overall-diameter) or a 235/35-19 and 265/30-19 (less chance of rubbing) on my xDrive and the wheels/lowering I stated in the original post... a local tire dealer said to stick with OEM 225/40-19 255/35-19. Thoughts? Thanks. Fred |
03-15-2017, 10:36 PM | #7 |
Rep 4,512
not sure about the rubbing but 235/35F, 265/30R diameters are smaller than 26" oem spec so your speedo/odometer will read higher than actual. in the grand scheme it prolly doesn't make that much of a difference but rather stay close to 26" or a lil more if anything. so i prefer the 235/40F, 265/35R combo...
03-16-2017, 08:22 AM | #8 | |
Rep 115
See the images: |
03-16-2017, 09:20 AM | #9 |
Rep 105
03-16-2017, 09:21 AM | #10 | |
Rep 115
03-17-2017, 12:00 AM | #11 |
Rep 240
Wow, that's great to hear, Marasool! Thanks so much for the feedback. Car looks *beautiful*, btw!
I'm sitting a bit lower than you, and my local tire guy;s been very helpful and is recommending I go with the OEM 225/40-19 and 255/35-19. That might be more sensible without too much diff in the width...should I still be going with the 8.5" +35 wheel in front and 9.5" +35 wheel in rear? What have you decided on, mineral_f30? And what's your deciding factor going with the ECS vs. MPS4S (or were you considering the MPSS)? Fred |
03-17-2017, 05:42 AM | #12 | |
Rep 366
(-_-)BmwF30xdrive(-_-)258.00 |
03-17-2017, 01:41 PM | #13 | ||
Rep 240
Thx! Really appreciate it. Fred |
03-17-2017, 02:32 PM | #14 | |||
Rep 366
