03-31-2017, 12:25 PM | #1 |
![]() ![]() 51
Rep 169
Drives: '18 540i '15 X5 '03 530i
Windshield washer pump replacing
Looking for help where to start pulling front wheel covers, i need to replace windshield washer pump thats probably clogged. I can hear twice the noise from pump but would only spray water in bottom part of windshield.
i have replaced many of this pump in the past in my old e39 and e53 and they are a lot easier to reach, now f30's have it hidden behind right front wheel well, i think. I would really appreciate if anyone could post procedure; my car is 2014 328i (F30). I did lots of search but has not found any posting to this subject. Thanks in advance for any reply. |
03-31-2017, 12:59 PM | #2 | |
![]() ![]() ![]() ![]() 185
Rep 753
http://www.realoem.com/bmw/enUS/show...diagId=61_2896
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
03-31-2017, 05:49 PM | #3 |
![]() ![]() 51
Rep 169
I'm really hope its just the strainer; i still need to know where to start to get to the pump/ccontainer thing. Can't see the actual unit, looking at the filler it appears it might be mounted behind right front fender after the wheel.
03-31-2017, 06:33 PM | #4 |
Rep 753
I think you're right. From the design of the reservoir, it looks similar to the e90's; behind the passenger side fender.
http://www.e90post.com/forums/showthread.php?t=331829 Good luck!
03-31-2017, 10:17 PM | #6 | |||
![]() 1658
Rep 4,016
ISTAD Windshield Windscreen Washer System Procedure
04-01-2017, 02:31 PM | #7 |
Rep 753
slightly offtopic, but where did you find this in ista/d? I dug around and ended up giving up lol.
04-01-2017, 02:51 PM | #8 | |
![]() 1658
Rep 4,016
I actually got to the individual components through the clickable links in the Overview. I didn't see the actual procedures listed in this category so I can understand why it may have been difficult to find. |
04-01-2017, 03:43 PM | #9 | |
Rep 753
Polo088161658.00 |
04-04-2017, 07:25 AM | #10 |
![]() ![]() 51
Rep 169
04-05-2017, 01:59 PM | #11 |
![]() ![]() 580
Rep 1,644
It looks to be essentially the same as the E-90. I changed 2 on my 09 E-30. It's a bit of a tight fit with little room in the fender space, but just take your time and don't let if frustrate you.
04-16-2017, 03:15 PM | #12 |
![]() ![]() 51
Rep 169
Found the problem, so please avoid or do not use Rain-X washer fluid as it is causing blockage in strainer.
and a big Thank you again to Polo08816 for sending the procedure. Pic below is the glob of slime found from using Rain-X during winter. |
05-12-2020, 08:21 AM | #13 |
Ü
![]() 82
Rep 474
sorry to drag this up but I have the same issue and wondering did you have to replace rivets.
If you have to is there info on the replacement rivets thank you. Installation note: Replaced expanding rivets (2). |
05-16-2020, 05:44 PM | #14 |
Rep 753
I have this issue and found out that the sensor is integrated with the tank. what i did try was alcohol and vinegar with distilled water trying to get the slim off the sensor and it worked...until i filled it back up with windshield fluid. still get the low fluid warning every single time i get in the car. cant try the mix again since alcohol are flying off the shelf.
