BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Now Available Agency Power 340/440 B58 Air Intake
proTUNING Freaks
      04-18-2017, 11:46 AM   #1
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Talking Now Available Agency Power 340/440 B58 Air Intake
One of the easiest ways to gain horsepower and improve your throttle response on the BMW 40i B58, turbocharged engine, is with an air intake kit. Agency Power's new short ram air intake kit for the M240i, 340i, and 440i is a great first modification to do. The intake kit is a complete replacement for the OEM air box. The kit includes a new aluminum intake tube with CNC machined MAP sensor mount, precision cut heat shield with mounting tabs, and a new high flow air filter. The MAP sensor mount has been CNC machined out of 6061 aluminum to retain the factory fitment for proper readings. It is than TIG welded to the aluminum intake tube for proper placement. The main part of the intake is the high flow air filter. It features an inlet on the end cap to allow for an even larger volume of air to come through than a standard cone filter. The design improves air filtration while increasing air flow. The air filter is finished off with the Agency Power text and AP logo on the rubber end cap. The heat shield is water jetted from aluminum with rubber trim to provide a secure fit and seal when the hood closes. It is designed to prevent direct hot air from the engine being sucked into the filter. Each heat shield features the AP logo neatly cut out from the shield panel for added style. All parts are finished in a matte black powder coat for an OEM look while the cylindrical air filter features a blue element matching to the BMW Roundel logo. With the new air filter, your turbocharger can breathe better than the factory intake allows. This is noticeable as you step on the accelerator and hear the turbo work (sucking air noise). Release the throttle and the factory blow off valve noise (whoosh) is more audible and keeps you entertained through the gears!
Features:
• Aluminum construction
• CNC machined MAP sensor mount
• Black powder coat for OEM look
• Reusable high flow air filter
Fitment:
• BMW M240i F22
• BMW 340i F30
• BMW 440i F32
Note:
• Heat shield was designed on the BMW M240i chassis and may require alterations or removal to work on the 340i and 440i.
Part Number: AP-M240i-110
https://x-ph.com/sale/
Phone number 702-494-9435
      04-18-2017, 03:46 PM   #2
SingleturboVert
Drives: E93 335i
Nice
      04-18-2017, 05:01 PM   #3
335xiRT1
Drives: 2007 335i
How much
      04-18-2017, 05:08 PM   #4
mike@x-ph.com
Originally Posted by 335xiRT1 View Post
How much
I am not allowed to post prices here, i will send you a pm
      04-18-2017, 05:50 PM   #5
f30m
f30m's Avatar
64
Drives: 2008 E90 M3
Any idea on power gains?
2008 E90 M3 - Sparkling Graphite Metallic / DCT / slicktop / single hump
      04-18-2017, 05:50 PM   #6
mike@x-ph.com
Based of Dyno done by VM on the BMS intake (similar style intake), gains are 5-8 whp
      04-18-2017, 10:11 PM   #7
mannymazz
Drives: 440
Please PM price and how's build
Quality compared to BMS
      04-19-2017, 02:31 AM   #8
BLACK HAWK DOWN
BLACK HAWK DOWN's Avatar
Drives: 16' AW 340i xDrive
Will there be a version for the 340i that is a direct fit? No modifications, alterations or removal of the heat shield for this application.
Their whole life sheep are scared of the wolf but in the end, it's the sheppard who eats them.
jalkster220.00
      04-19-2017, 06:32 AM   #9
jalkster
Drives: X3MC
Originally Posted by mike@x-ph.com View Post
Note:
Would like to know this for the 3er...
Current: 2021 M340i
Previous: 2020 X3M Comp BM3 E30 & 2016 340i 8AT DME Stage 2 | FBO/Catless Meisterschaft Catback | Ohlins R&T
      04-19-2017, 07:45 AM   #10
insanecoder
Drives: 340isDrive
Thats a heat shield as much as I am an NFL player.. on or off prob wont make mucha diff.. same as the BMS intake
jalkster220.00
Roki187126.00
j1980mac262.50
      04-19-2017, 08:36 AM   #11
BLACK HAWK DOWN
If the shield doesn't work then I would just look at the BMS. No sense spending 100+ on something you will toss.
      04-19-2017, 10:38 AM   #12
mike@x-ph.com
Pm sent
At this time i am not aware of a heat shield that fits the 3 series
      04-19-2017, 01:05 PM   #13
mike@x-ph.com
More pictures
      04-23-2017, 04:56 PM   #14
ray340i
Drives: 2016 340i msport
Would love to see a dyno sheet :/
      04-24-2017, 10:32 AM   #15
cptcrunch
Captain Crunch
cptcrunch's Avatar
168
Drives: 2016 340i
Agreed. Before and after dyno to back up the 5-8whp claims, please.
On Order (in transit): BMW iX 50, Oxide Grey
Retired: BMW Welt Delivery 4/14/16: European Delivery - 2016 340i EBII/Saddle - ZMP | ZCW | ZDA | ZLP | ZTP | M Adaptive | Rear Shades | MPPSK Before and After Dyno
Retired: 2011 335D Space Grey/Black - ZSP | ZPP | ZCW | 6FL | Sat Radio | Nav | $600 Base Audio Upgrade
      04-24-2017, 03:12 PM   #16
iMinLuv
iMinLuv's Avatar
Drives: BMW 340i M-Sport track pkg
I have the BMS intake with verified dyno gains for $100 less why buy this one?
340i M Sport Track Package | JB4 | Dinan Exhaust | BMS intake | CG catted 5" DP | HR sport springs | WMI | Zito Zf01 |
      04-24-2017, 03:27 PM   #17
cptcrunch
Captain Crunch
cptcrunch's Avatar
168
Drives: 2016 340i
Not to derail this thread, but do you have a link?
      04-25-2017, 06:54 AM   #18
iMinLuv
iMinLuv's Avatar
Here's the link to get it from mike! He'll get it there as fast as humanly possible..
https://www.x-ph.com/burger-tuning-2...billet-intake/
      04-25-2017, 08:18 AM   #19
insanecoder
Drives: 340isDrive
I mean maybe it can be considered a "radiant" heat shield? ... but convection-wise its not gonna do much to keep heated air from getting sucked in
eluded3046.00
      04-25-2017, 01:25 PM   #20
PeterA90
Drives: 340xi
Agency power, rip off company. Looks like a garage mechanic made that.
      04-25-2017, 02:35 PM   #21
mike@x-ph.com
Thank you
      04-25-2017, 03:46 PM   #22
iMinLuv
iMinLuv's Avatar
Pete getting aggressive
