BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > TPMS programming tool?
      04-21-2017, 12:06 PM   #1
XKxRome0ox
e90noob
XKxRome0ox's Avatar
Drives: '08 E90 M3
has anyone replaced the TPMS sensors for a 2014+ f30 f3x car?
i bought a second set of wheels and purchased a set of HUF TPMS
looking through the instructions and it says i need a TPMS programming tool to make these work
-_-
i hope the tire shop has one
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22
      04-21-2017, 12:35 PM   #2
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i
you should only need to go into the idrive and reset the TPMS. start driving and they will sync up.
IF this is not working for you then you bought the wrong TPMS sensors for your MY F30. They changed for '14+ from what the 12-13 F30s have
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
Polo088161787.00
      04-21-2017, 12:51 PM   #3
XKxRome0ox
e90noob
XKxRome0ox's Avatar
Drives: '08 E90 M3
i read through a lot of forum posts and articles about the TPMS and part numbers
these sensors are the right part number
36106856209
i hope they just sync up with the TMPS reset then
      04-21-2017, 01:11 PM   #4
inspired626
Drives: A slow one
Who did you buy the sensors from? Can you ask them to program them for you?
      04-21-2017, 01:17 PM   #5
wdeerfield
A family of bimmers
there is no programming needed. BMW idrive has the reset for TPM
      04-30-2017, 03:24 PM   #6
XKxRome0ox
e90noob
XKxRome0ox's Avatar
Drives: '08 E90 M3
It worked
HUF TPMS works after just resetting through I drive
Polo088161787.00
      05-08-2019, 01:14 AM   #7
bobbyggx
Drives: '18 BMW G30 540i xDrive
Guys, can somebody give a short technical explanation how does this reset happens and how does the car knows the location of each sensor?
I saw a video in Youtube where a Chrysler vehicle got its sensors changed and the guys was walking around with a magnet. I would assume that the system is somehow check the tires itself, but how exactly?
      06-15-2019, 08:15 PM   #8
Beachparty
Drives: 2018 F30 330Xi
I believe each wheel well has it's own tpms receiver so it only reads whatever the sensor sends.
That's why you can swap / rotate wheels without changing / coding anything
      11-15-2020, 05:00 PM   #9
tpo209
Drives: 2013 335Xi M-Sport
Sorry for bringing this back from the dead. How did you get pressure and temp to show for each wheel?
      11-16-2020, 11:57 AM   #10
wdeerfield
A family of bimmers
This is done through coding using esys or bimmercode.
Setting RDC_SAFETY to activ is what i did.
      05-20-2021, 08:38 AM   #11
bimmerace
Drives: F30 335i xDrive M-Sport
I bought m4 wheels for my 13' F30 and a reset won't work, is there a way to code these new typ of sensors or do I have to buy new ones?
