06-12-2017, 07:32 AM | #1 |
Rep 150
Drivetrain Malfunction, Multiple Misfires, getting worse...
Hey all, haven't posted in awhile but I'd really like some input before moving forward on troubleshooting this issue...
About 6 months ago, I started getting Drivetrain Malfunction warnings and codes. Unfortunately I don't have the codes from those occurrences but I can assume they are the same as they are now. I did some general troubleshooting, ended up pulling off my JB and the problem went away. I'm pretty busy so I tossed the JB on the shelf and didn't think about it much until recently. I've again (without the JB installed) had the Drivetrain Malfunctions come up. This time I went ahead and got Rheingold set up and pulled the codes which tell me the following... - Combustion misfires, several cylinders: Fuel Injection is switched off - Combustion misfires, several cylinders: detected - Combustion misfire, cylinder 3: Fuel injection is switched off - Combustion misfire, cylinder 3: detected I've done quite a bit of reading and understand that the problem is likely one of the following... - Spark plugs - Coil packs - Injectors - Ionic control module (does the 2013 F10 M5 have this? I didn't see anything that looked like the part online looked like) To start the troubleshooting process, I swapped the coil from cyl 1 with the coil from cyl 3. I also went ahead and cleaned the air filters (K&N) and the MAF's... Since the problem is not being caused (just exacerbated) by the JB, I went ahead and reinstalled it... Took the car out again this morning and got the exact same codes and report for the same cyl 3 misfire. What confuses me is that it says misfire on several cylinders. Does that mean that only one was bad enough to pull fuel? Assuming that I got my cyl # correct, this would rule out the coil. When looking at the engine from the front of the car, I swapped the front right coil with the one just behind it on the same side. I understand the numbering starts from the front right at 1 then goes front left, back to the next one on the right and zig zags the rest of the way. Can someone confirm that? One thing that I haven't seen mentioned too much is battery. My battery is likely near its end of life and I saw one undervoltage code the last time I pulled codes (not today tho). May be completely unrelated however but thought it was worth mentioning... Does this point to anything specific for anyone? I would have checked my plugs but couldn't locate my plug socket... I'm outside of dealer warranty but have an aftermarket warranty. I love working on the car but only have so much time so will take it to the shop if need be... Thanks in advance for any help or advice! |
06-12-2017, 06:48 PM | #2 |
Rep 150
I went back and did some more searching and am fairly certain I swapped the wrong two coils. Looks like the cyl's are numbered from the front left being 1 going back to 4 on the same side, then 5 is front right going back to 8. I'll try swapping the real #3 and report back with findings...
sdrawkcaB26.00 |
06-14-2017, 12:26 PM | #4 |
Rep 28
That should do it. I had something very similar with out the mod. Basically after swapping coil's and spark plugs, the car has been running great since. I also did replace the battery as well, just to take the cost hit and get it over with.
06-14-2017, 12:36 PM | #5 | |
Rep 1,300
06-26-2017, 10:43 AM | #6 |
Rep 978
Damned. I would like to know this also. Thanks.
2021 M340i
2020 X3 M40i - her car 2019 M5, AW, DP's, MSR CAI, BM3, SOLD 2020 Chev. ZR2 Bison truck, Daily Driver |
09-12-2017, 07:21 PM | #8 |
Rep 553
any of you guys experience vibration at cold start ? today i noticed upon cold start weather has been getting colder the seat belt rattles against the frame thats how bad it shakes for a good 30 seconds before becoming smooth
im thinking to replace all injectors and coil packs/plugs |
05-10-2018, 10:30 PM | #9 | |
Rep 9
05-24-2018, 01:15 AM | #10 |
Rep 3
So I was having similar problems, luckly my vehicle was still under CPO, because it turned out that I had scoring marks on three of the cylinder walls, so they swapped the engine with a refurbished one..... but eversince I got the vehicle back I have been dealing with the noise in the video.... have you guys experienced this ?
08-20-2018, 06:57 PM | #11 | |
Rep 9
Had to Replace Fuel Injectors
12-22-2018, 01:16 PM | #12 |
Rep 22
Hey guys i just purchased a used 2013 m5 days ago and out of the blues i recieved drive train error alot of smoke from exhaust went into limp mode code read misfired cylinder 8 i got all new spark plugs and coil pack . 2days later at the traffic light medium throttle it happened again . Any help guys ?
12-22-2018, 08:41 PM | #13 |
Rep 22
Drivetrain malfunction m5 f10 PLEASE HELP
I recently purchased a used M5 f10 2013 41k miles no warranty . Light acceleration triggered this and alot of smoke from tail pipes . After 5 mins parked engine off it went away . Checked code and it said cylinder 8 misfired . Changed all spark plugs and coil pack changed oil too . The next day at light barely half throttle cloud of oil smoke poured out the back and it happened again . Can anyone here help ? If its not the coil pack and spark plugs what could it be?
12-23-2018, 09:25 AM | #14 | |
Rep 1,073
12-23-2018, 10:57 AM | #15 | |
Perennial PFC
336
Rep 1,274
Perhaps chance a visit to a dealership to have them see if your problem might be one of those? I don't believe you have to be the original owner, it's for the vehicle. |
12-23-2018, 02:55 PM | #16 |
Rep 22
Thanks guys i really appreciate all the help ill go to the dealership after the holidays . I love the car aside from this issue its the perfect daily in my opinion .
12-23-2018, 04:42 PM | #17 | |
Rep 1,107
GL! Happy holidays
'13 Black Sapphire Metallic - BPM Stage 1 Tune - RPI Exhaust - KW HAS Kit - 12mm spacers all around- Carbon Fiber front lip - High Kick Trunk Spoiler - Rear Roof Spoiler - IND Kidney and Fender Grills - 20% Tint all around 50% Front Windshield - PPF
12-23-2018, 07:26 PM | #18 |
Rep 22
Gosh im so relieved that it could be injectors and fuel pump and also covered by factory warranty . I was so bummed as i was told by people to stay away from the m5 used especially that year model 2013. When that cloud of smoke came out i thought oh no there goes the engine ...
12-26-2018, 03:07 PM | #19 |
Rep 22
Well its official . Im doomed . Bmw says there is damage to the cylinder 4. No possible repair only complete 40k engine replacement . Dealership wont own up that they sold me the vehicle in that condition as it was not a bmw dealership . Im devastated and i have owned the vehicle for 2 weeks ....
12-28-2018, 01:57 PM | #20 | |
Rep 1,107
12-28-2018, 02:59 PM | #21 | |
Rep 1,073
12-28-2018, 03:01 PM | #22 | |
Rep 1,073
