07-14-2017, 06:43 AM | #1 |
Rep 1,782
!! Flex Fuel Please Read !!
Alright now that I have hooked you with my click bait title I have a question.
My buddy wants me to help him install his FF wires tonight, easy Enough. However he wants to race someone at the track and is asking me if it's alright to just mix e30 and throw it in map 7 for the first run and I told him while theoretically, yes, he could it was strongly advised to mix from a 2.5g start and go upwards and log accordingly. My question is why can you not just dump like 4 or 5 gallons into the car and then go. Obviously you can hurt the engine, I'm not a total n00b. How can the engine get hurt or messed up. I have Ff wires on my car and took it from 2.0g to start and worked up to 7 gallons and logged all the way up to 5 gallons and had no issues
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
07-14-2017, 07:34 AM | #2 |
Rep 6,993
First of all, ethanol does not give your engine any additional power - it is strictly an octane boost, as its thermal energy is only approximately 70% of that of gasoline. Now, with increased octane, your engine can stand a little higher combustion temperature and advanced ignition without the knock sensor retarding the ignition or cutting fuel to avoid detonation (which will destroy the pistons). So, "dumping" ethanol into your fuel tank may raise your octane level, but BMW fuel systems really aren't designed to run any more than an E15 mix. The owner's manual states that. Ethanol is hygroscopic and will mix with water (not good for fuel injectors), and the seals within the fuel system can be degraded by ethanol to the point of failure over long-term use. So while engine issues might not appear immediately, they could manifest themselves after a year or two, depending on how often and how much you use.
If you really want to add a little power without messing with the engine internals, a meth/water injection system directly into the charge pipe would be more effective, but somewhat dangerous due to the volatility of methanol.
07-14-2017, 07:40 AM | #3 |
Rep 367
The reason for gradually increasing the amount of E85 is because each car responds a bit differently to it. So in order to find the "limit" for your specific car, it's advised to gradually work your way up in E85 content while data logging. If my gas light is on and I'm trying a new supplier, I usually start with 4-5g of E85 and the rest 93. Then I log and alter from there.
FSociety3816.50 |
07-14-2017, 09:52 AM | #4 | |
Rep 1,782
FSociety3816.50 |
07-14-2017, 10:03 AM | #5 |
Rep 499
Drives: 2021 X3 M40i
If it is just for the track why not put some race gas in? Would have the high octane and not the worries about to much E85 since he hasn't done any logging with it yet. Just an idea.
2021 G01 X3 M40i Carbon Black Cognac Vernasca
Retired: 2013 F30 335i Glacier Silver Metallic Coral Red Dakota Retired: 2011 E90 328i Space Gray Black Dakota |
07-14-2017, 10:28 AM | #6 |
Rep 1,782
We thought about that but race gas is not very close to us and the track pumps are down for whatever reason
07-14-2017, 11:30 AM | #7 |
IG @bmwF9xG80
3817
Rep 7,595
E30 not enough to run map7 without a log IMO
but like mr_kay said you have to start low and log and see how car responds as you know already
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
Chicken_Joe608.00 |
07-14-2017, 11:42 AM | #8 |
Rep 1,782
That's what I figured the real reasoning was just making sure
07-14-2017, 12:06 PM | #9 | |
Rep 2,087
07-14-2017, 01:36 PM | #10 | ||
Rep 1,782
07-14-2017, 02:22 PM | #11 |
Rep 693
Before the recall i could not run over e30. With the new recall pump i can run e40 no problem. The thing i have to watch now is the trims because the hpfp and lpfp values are very stable in the logs.
I personally think everyone should buy a ethanol tester and calculator app before running e85. You will never know what mix you have dont test. Chicken joe you seen me test it before you put it in your car. It took 7 gal because it was only e70 and you were starting from scratch. Now that i run e40 every tank i only add 6 gal when ever i fill up from a 1/4 tank. |
Chicken_Joe608.00 |
07-14-2017, 10:20 PM | #12 | |
Rep 1,782
07-16-2017, 08:35 AM | #13 |
Rep 1,130
It's more about your gas stations supply of gas than each car being different, since they are mass produced it implies they are all the same in fact.
The flex fuel pump can be from E51 to E85 and of course environment factors are different. Those two things have the greatest effect because you are running the fuel system to the absolute limit so you need to find that limit and back down. |
07-16-2017, 01:14 PM | #14 |
Rep 1,782
We actually found some great 110 leaded fuel. Mixed 3 gallons of the 110 leaded with 3 gallons of 93 octane and the car ran 13.2 at the strip. About .5 seconds faster then it did previously in 93 octane with same mods.
07-16-2017, 02:26 PM | #15 |
Rep 693
Leaded?! You trying to kill the o2 sensors?
07-16-2017, 02:48 PM | #16 | |
Rep 1,782
07-16-2017, 02:49 PM | #17 |
Rep 1,782
And it's not like I ran a full tank. We cut the fuel with 93 and then after we left the track we filled the at all the way up with 93. Car on ran at the track with a little over 1/4 tank of fuel in it
07-17-2017, 11:10 AM | #18 |
Modder of everything I own
147
Rep 491
I started out at about E25/93 on map 2/5 now I'm running about E50/93 daily on map 7. I have had my LPFP changed under recall, now it starts hard sometimes, go figure. I've been running E50 map 7 for over a month now with no issues and excellent performance!
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
07-17-2017, 11:28 AM | #19 |
Dream crusher
984
Rep 2,421
Just a note here: Put the e85 in and mix the pump gas on top of that. Twice I've mistakenly put in e85 in and then only mixed a couple of gallons of pump gas on top and threw error codes "lean conditions". PITA really.
ICarly for the reset, but still. The DV error is GFB DV+ spring.
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
07-17-2017, 01:00 PM | #20 | |
Rep 1,782
07-17-2017, 10:13 PM | #21 |
147
Rep 491
I can't get 93 octane and e85 at the same station so I put the 93 first and then the e85 at the other station, a couple miles away. I figured err on the gas side of things.
07-18-2017, 06:29 AM | #22 | |
Rep 1,782
