08-06-2017, 12:29 AM | #1 |
Rep 6
How to program the new REM module?
Hi there. Just plan to replace the REM for some malfunctions with the old one. Does anyone know where I can find the guide or Tutorial about the programming procedure ?
08-06-2017, 08:01 AM | #2 |
Rep 2,302
08-06-2017, 03:56 PM | #3 | |
Rep 8,364
08-06-2017, 04:19 PM | #4 |
Rep 2,302
I think it is not necessary to flash the new REM.
The software is already on the ecu, it just needs to be coded on the vehicle. So it was on my retrofit of PDC. |
08-06-2017, 05:17 PM | #5 |
Rep 8,364
It is always best to save yourself the time by trying to inject CAFD first. If that does not work or dependent ECU's are on separate I-Step, then you must program.
08-06-2017, 10:06 PM | #6 | ||
Rep 6
08-06-2017, 10:07 PM | #7 | |||
Rep 6
08-07-2017, 02:17 PM | #9 |
Rep 16,082
In a related topic, I did a change today in the REM, and noticed there are dozens of parameters that can be coded, but only the four V_Schwelle options are listed on the cheat sheet. One can only wonder what else is possible.
08-07-2017, 02:22 PM | #10 |
Rep 8,364
Rear lamps and rear windows to name a few.
08-07-2017, 02:37 PM | #12 |
Rep 8,364
08-07-2017, 03:30 PM | #13 |
Rep 16,082
I looked at the descriptions, but they weren't exactly explicit. You could tell they had to do with different camera and PDC adjustments, but I wasn't going to fiddle with them to see what happened.
11-03-2019, 12:06 PM | #14 |
Rep 5
REM
hello, how did you know your REM was bad? My rear passenger door lock doesn't work, the ambient doesn't work, window doesn't wind down, and door handle led light don't work. everything is on that one door, passenger rear.
Barr
12-29-2021, 11:52 PM | #19 |
Rep 4
If the CAFD is missing for example module LMV_01 (transfer case actuator) the CAFD will have to be injected and then encode the module to the car?
12-31-2021, 07:27 AM | #20 |
Rep 8,364
You can always "temporarily" add cafd to SVT using "detect caf for swe." But, until you select "CODE," it will not be written back to car.
11-25-2022, 08:25 AM | #21 | ||
Rep 9
Hello, due to the fact that my issue is related will expand this thread instead of creating a new one.
I bought PDC front/rear retrofit for my F30, rear is done, moved forward into replacing REM (mine did not have the pins, the new one is from other car - not brand new). After REM replacement some of the car functions stopped working - like rear blinkers, trunk opening, fuel level etc -> ok, some coding is needed. Tried approach as it is explained above, Quote:
But it ends with the same error. I am using E-Sys 3.33.4 (tried also with 3.40.2) with latest full pzsdata. Can you kindly advise please how I can make this REM to be working? Fuses are ok, checked those. Also when I replace it with my old REM all works ok. |
